Old 05-24-2020, 04:06 PM #1
Quiero Quiero is offline
Quiero is on a distinguished road
Billstein 5100's & 1" springs. Much floatier handling normal? *Alignment sheet edit*
I had Billsteins at the highest setting and 1" rear springs installed and had the truck aligned.
On the freeway it feels much floatier now. Like the wind is blowing it around when the wind is not blowing hard.
Still on factory tie rods and balljoints as well as bushings. In my older truck it drove similar to this before I replaced all of the front end components. Then again, I didnt notice this until the lift.
I've never owned a lifted vehicle. Is this normal?
Quiero is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 11:41 PM #2
Ebolavirus6 Ebolavirus6 is offline
Real Name: Tyler
Ebolavirus6 is on a distinguished road
Real Name: Tyler
What springs are you using and how many miles on stock components?
I would venture to say that something is not right.
Ebolavirus6 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 01:28 AM #3
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Mine is the same way. Bought it this year with 154K mi. and was stock height. Put basically a 3”/2” on mine with 5100’s front and back and Eibach front springs and super flex rears. Right after I lifted it, it felt very floaty as well and that was with the exact same tires and wheels so I compared apples to apples. With new tires (bigger) and wheels it still felt exactly the same so it’s not my tires like some say. It felt pretty sketchy on the hwy or fwy and still kinds does.
I did replace the rear sway bar end links with Moog 2nd generation (1”longer than our 4th gen) More Information for MOOG K80380 and energy poly bushings. This definitely helped some as it stiffened it up a bit and helped bring the rear geometry back a bit. After that, I did a sway bar relocate kit and drop as well as energy poly end link bushings and sway bar bushings. Didn’t notice much improvement in squirellyness there but feel the bumps more so may have helped a bit. It still floats and I know exactly what you mean. Not sure if somethings wrong with mine either. I just deal with it now and try to pay very close attention to the road, if not I have a tendency to end up on the other side pretty quick (happened just a few hours ago lol!
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 01:01 PM #4
bigmoose's Avatar
bigmoose bigmoose is offline
Real Name: Ray
bigmoose is on a distinguished road
bigmoose's Avatar
Real Name: Ray
The light handling may be caused by the upper control arm. When you raised the suspension the UCA drooped causing the wheel to be out of camber. Some of the aftermarket UCA's compensate for this or are adjustable. The higher the lift, the more the camber will be affected.
bigmoose is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 04:36 PM #5
I posted on another group which said that adjustable CAs are really needed to balance caster/camber.
I have the print out from my alignment shop below.
This seems to be a common thing based on my google fu.
160k miles
Old 05-27-2020, 11:33 PM #6
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Low caster will lead to wander and constant driver input needed.
3.5*+ caster will track better... less floaty, less the road surface will push you around.
Steering starts to get heavier as you get up up 5*... tracks great though, like your on rails.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 11:59 PM #7
Not trying to hijack this thread by any means, but how does my alignment look? Anything unusual or way out of whack?
Billstein 5100's & 1" springs. Much floatier handling normal? *Alignment sheet edit*-a8e1fa51-64a0-43ef-aded-f95c9d8817db-jpg
Old 05-28-2020, 12:23 AM #8
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
you want more caster you have .6
the OP was not even to the min at 2.3
try for 3.5 or more
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 05-28-2020, 03:04 AM #9
try for 3.5 or more
Oh geez.... .6*, thought I saw 6* lol. Guess I'm way off huh? Was hoping to get away without having to get new adjustable UCA's with my lift not being over 3" but guess I will have to start looking more into that. Thank you.
Old 05-28-2020, 10:24 AM #10
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
with stock control arms, you will get the max of 3 for caster i think, have your alignment guy go to 3 or more.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 03:48 PM #11
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
...and if your LCA cam bolts are rusted/seized good luck getting improved caster without a small headache... cutting the cam bolts out.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
blowing , floatier , normal , truck , wind
completed Bilstein 5100 w/ toytec 2.5" springs and Daystar 2" spacer Warwicke36 4th Gen T4Rs 5 02-09-2020 09:15 AM
Rake after lift - Billstein 5100 question JeffMerr 4th Gen T4Rs 8 06-11-2018 12:30 PM
Do these inner CV boot fins look normal for 5100's set @ 2.5"? timelapse 5th gen T4Rs 16 09-12-2017 07:01 PM
KDSS W/ Billstein 5100's and 285/70/17 ScottsdaleT4R 5th gen T4Rs 7 02-05-2013 10:49 AM
