Old 05-25-2020, 07:57 PM #1
chris.817's Avatar
chris.817 chris.817 is offline
chris.817 is on a distinguished road
chris.817's Avatar
2004 V6 Random Misfire
Hey folks. My 4runner has been sitting for several weeks for some projects and finally back on the road this weekend. Drove it twice for 15-20 miles with no issue. Today, i head out and at first stop light it dies. Starts right up but won't idle without my foot on the gas a bit but otherwise seems fine. After several miles it seems to have cleared up (idles around 5-600 rpm). I get on the highway and it starts to run rough. Engine light comes on.
Codes present are P0300 and P0302. Cleared codes and drove home. Same rough running. Read codes again and just the 300 this time.
Only things I've done in last 24 hours is a tank of gas (87 octane which I usually don't do but I'm questioning that) and I tried in vain several times last night to do the zero point calibration to include disconnecting my battery for several minutes.
Anyone ever have this happen so suddenly and severally?
Thanks.
1999 4Runner Highlander (original owner) 225k miles - all original
2004 4Runner Limited 4.0 170k miles - DIY inside OEM bumper 12k winch, DIY tire carrier
chris.817 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 08:34 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold
Real Name: Skip
A member here had a similar issue recently, the links are for his topic on his issue and then his other topic on fixing the issue.
Really, really weird misfire problem
Update on Weird misfire problem
2004 Limited V8
Old 05-25-2020, 08:50 PM #3
Burt Burt is offline
Burt is on a distinguished road
Due for set of plugs?
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2005 F250 SuperDuty 6.0PSD FX4 Lariat
Burt is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 01:38 PM #4
chris.817's Avatar
chris.817's Avatar
Misfire resolved
Thanks folks.
Sad that it takes an OBDII scanner and the power of the Internet to tell me I need to change my spark plugs... I've only owned this vehicle for about 3k miles. Maintenance history shows they have about 90k miles on them. Picture is #2 plug. #4 similar. The rest not near as bad.
As you can see, the dealer did not sell me Iridium plugs...
Misfire gone. Idle is still low at about 500 rpm.
2004 V6 Random Misfire-old-plug-jpg
Old 05-26-2020, 03:31 PM #5
importman importman is offline
Real Name: Danny
importman will become famous soon enough
Real Name: Danny
Originally Posted by chris.817 View Post
Thanks folks.
I'm the one who had the weird misfire that someone linked above. Funny but my #2 spark plug was bad and that's all it took to fix it. But mine had codes for 1 and 2 which is what made it so weird. Anyway, I wouldn't fret about the non iridium plugs. Toyota calls for standard plugs on our vehicles. My understanding is the only benefit to iridium or platinum is longevity. So they stick them in any vehicle that requires extensive labor to replace them. And as you've probably figured out by now the plugs in ours are fairly simple to replace. Glad you got yours fixed. Oh, and about that low idle. If you've had the battery unhooked the idle will be low for a little while until it relearns where it needs to be. If you haven't had it unhooked I'd suggest cleaning the throttle chamber and plate. That will pick it right back up to where it should be. Good luck.
importman is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 07:00 PM #6
sailgreatlakes sailgreatlakes is offline
sailgreatlakes is on a distinguished road
I like seeing these mystery problem threads pop up, even if the solution ends up being something simple, it's a good reminder to consider some of the more obvious problems! I may have to inspect my spark plugs now, just to be sure haha
sailgreatlakes is offline   Reply With QuoteReply With Quote
codes , drove , gas , light , miles
Random Misfire - 1998 SR5 3.4V6 Mopar_Mike 3rd gen T4Rs 4 02-20-2014 03:37 AM
Random misfire at idle only Rhouse 3rd gen T4Rs 4 05-28-2013 12:19 PM
PLEASE HELP!!!!!! Random Misfire Detected!!! ryankmasuda Maintenance/Detailing 3 04-10-2010 08:44 PM
Random Misfire... The Godfather Maintenance/Detailing 1 01-26-2008 09:28 AM
Causes of random Misfire JP4RNR All Other Vehicles 0 02-02-2007 11:05 PM
