Old 05-26-2020, 03:24 AM #1
Sithrebel15 Sithrebel15 is offline
Sithrebel15 is on a distinguished road
Cheap OEM Headlights?
Looks like they're about $230 pretty much everywhere, anyone seen them cheaper?
I'm installing a set of '06 in my '05 and having some morimoto projectors installed.
Sithrebel15 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 04:15 AM #2
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Check at Rock Auto. They have assemblies that are insurance certified replacements.
2006 TOYOTA 4RUNNER 4.0L V6 Headlamp Assembly | RockAuto
Sent from my Pixel 2 using Tapatalk
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 02:03 PM #3
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Are you wanting “cheap” or “OEM”? Because cheap OEM Toyota parts isn’t something that’s used in the same sentence (an Oxymoron lol) as they are not cheap unfortunately. If you want an inexpensive headlight alternative replacement then I bought these a few months ago and look great. I wasn’t able to (Nor did I want to) spend around$460 for and OEM set then. Amazon.com: ACANII - For 2006-2009 Toyota 4Runner 4 Runner Projector Headlights lamp Driver + Passenger Side 06-09: Automotive
So far so good but we’ll see.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 02:57 PM #4
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Why not retrofit the oem ‘05 housings. The retrofit into the old housing is easier than using the bracket into the facelift housing in my opinion. I had to grind the bracket and housing to get everything tidy. Plus the bracket doesn’t allow for much fine tuning.
Here’s what my oem housing look like after some grinding.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 05:51 PM #5
I'm having the work done for me. And putting projectors into a reflector housing is a ******* move.
I acquired a set of new oem's for $200 a few years back after I hit a tree.
Old 05-26-2020, 06:23 PM #6
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Do you mind expanding on this?
royal T4R is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 06:27 PM #7
joshik joshik is offline
joshik will become famous soon enough
do they have to be new OEM? Ebay has used OEM at various prices depending on condition.
I have an 06 RIGHT side for sale on here. It was an extra that I got while doing my 03->06 conversion.
$20 picked up if you are local to socal. Or shipped at your expense. I'm in 92081.
06-09 4Runner OEM Headlight - Driver Side
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 10:02 PM #8
Berty_K's Avatar
Berty_K's Avatar
I think @Sithrebel15 is confused.
HIDs in a reflector housing is a shithead move. Nothing wrong with a projector retrofit into a reflector housing.
Old 05-27-2020, 09:44 AM #9
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
another route you can take if you want "new" ones is get a cheap used set of oem ones with cracked or hazy lenses. Then buy a cheap set off ebay or amazon and transfer those lenses over. I just did this and saved a whole lot of money and now I have oem housings with new aftermarket lenses
__________________________________________________ ___
If you are looking for custom 4runner parts, then look no further!
iannaconeautoaccessories.com
Johns06yota is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 09:57 AM #10
Southpaw07 Southpaw07 is offline
Southpaw07 is on a distinguished road
I bought a set of new aftermarket headlights for roughly $125 on eBay. I haven't installed them yet so I don't know their longevity. I was contemplating transferring the new, clear lenses to my OEM 2007 headlight housings but I'm concerned with properly sealing them so there's no condensation.
Southpaw07 is offline   Reply With QuoteReply With Quote
cheap , installing , morimoto , projectors , set
Good, Cheap LED Headlights/Fogs that fit 2016 T4R axisbogner 5th gen T4Rs 32 11-18-2018 11:33 PM
Girlfriend's daughter wants to get a cheap car - what are some good cheap options jayhat Off Topic 41 08-04-2018 10:38 PM
FEELER: Used '99 Headlights w/ defects. *CHEAP* JWaldz Classifieds - buy & sell (no commercial ads please) 3 04-02-2011 02:46 PM
**SOLD** Crystal Black (JDM) headlights+corners fo sale cheap bricebones Classifieds - buy & sell (no commercial ads please) 8 03-15-2010 12:40 PM
Want 2 Buy: 2003-2005 Stock Headlights - Cheap As Possible sharp4runr Classifieds - buy & sell (no commercial ads please) 0 12-27-2005 11:43 AM
