Old 05-27-2020, 11:01 PM #16
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Originally Posted by Inv4drZm View Post
I would agree that a rear Toyota elocker is a pretty good and reliable option.
If you are eventually wanting a front locker, an ARB makes more sense, as you'll need the compressor and air components anyway.
If you can't find a used elocker diff, might try emailing ECGS and see if you can swap yours plus some money for their rebuilt elocker diffs. You could get it rebuilt with a solid pinion spacer at this time too. Not sure if they stock elocker motors or if you'll need to find one separately, those can be expensive.
Tacoma Elocker 3rd member
I'm looking into this since 8.2 axles aren't really that easy to find. Looks like assembled 8" rear elocker + front 8" reverse IFS clamshell with 4.56 gearing (and solid spacers front and rear) will run about $1400...then I'd have to source the elocker motor and a harness (no idea whether I'd need a high pinion or low pinion plug)...
Would all this simply bolt up and go?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 11:52 PM #17
rich dog rich dog is offline
rich dog is on a distinguished road
You will need the low pinion plug I believe. One thing to keep in mind is I think you will need to send them an elocker 3rd as your core in order to get it for that low of a price. I would probably give them a call and see If they will accept an open third member as a core. I'm sure you can find a motor on ebay
rich dog is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 02:39 AM #18
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Originally Posted by rich dog View Post
Look up rancho toyota recycling. They are in sacramento and have a ton of inventory. I'm sure they could source a diff and ship it. not sure on the pricing.
I have been there in person, id steer clear unless you are in DESPERATE need of parts. They like to overprice their items.
royal T4R is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 08:36 AM #19
63PGP 63PGP is offline
63PGP is on a distinguished road
Another vote for ARB.
I've had one in the front of a 92 Bronco since 2001. Works every time.
My son had one in the front of a 79 Bronco. Dana 44, RCV axles and CV joints. He beat on that truck and the only thing he never had to work on was the ARB. He broke a rear axle at one point, pulled the driveshaft and drove 50 or so miles in the desert back to his house on the front axle with the arb locked.
Mike
63PGP is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 09:09 AM #20
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
ECGS sells a 8.2 elocker conversion kit for $3500.
8.2'' FJ Cruiser/ 4runner / GX470 Elocker Complete Swap
And like mentioned, the one you linked, you'll need to call them on because you will be sending in your non-elocker 3rd member.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 02:07 PM #21
I saw that....at that price I'd way rather wait on a wrecked 8.2...or even skip it! I could do a rear Harrop/regear and regear the front for $800 less than that price! Or even go triple locked ARB for +$200 less!
I wonder how much money on top...
Their assmbled 8" elocker housings shoulda just bolt up no?
Old 05-28-2020, 02:22 PM #22
Inv4drZm's Avatar
Inv4drZm's Avatar
An 8" housing will bolt up, the 8" 3rd member w/ elocker will require you to notch your housing and I think add a stud or something like that.
All depends on what tire size you run and how hard you wheel.
Old 05-28-2020, 02:35 PM #23
Ah, I had assumed the assembled 8" elocker ones would just bolt right up - not a whole lotta info on people bolting those up I guess. I'll have to dig some more.
"34s" right now, possibly "35s" later. Moderate wheeling - would likely go harder if I had a rear locker doe hahaha.
Old 05-28-2020, 03:55 PM #24
smyles1632 smyles1632 is offline
smyles1632 is on a distinguished road
Does it matter if elocker comes from 4x2 or 4x4 Tacoma?
smyles1632 is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 04:01 PM #25
Inv4drZm's Avatar
Inv4drZm's Avatar
The elocker motor itself? Probably not.
The 3rd member might have a different style driveshaft flange for the 2WD. This is true for 4Runners at least.
The 4Runners have a different driveshaft flange between 2wd/4wd but the 4wd driveshaft still bolts up. The thicker 2wd harmonic flange is thick enough the 4wd bolts thread into the flange itself instead of using nuts on the backside.
Old 05-28-2020, 04:45 PM #26
KrazedJD's Avatar
KrazedJD KrazedJD is offline
KrazedJD is on a distinguished road
KrazedJD's Avatar
I never realized that there was a Toyota rear E-Locker that would work with my V8 4Runner, this is perfect! I would love to fit one into my rig over the air locker.
KrazedJD is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 08:35 AM #27
I know re 4runners, that's I'm asking if RWD and AWD Tacomas have different 3rds as well.
Old 05-29-2020, 10:07 AM #28
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
It's not easy to find (thus the thread) and requires some grinding to get it in. But it is a good option.
Supposedly at SEMA last year Eaton announced their own e-locker release for the Toyota, which might be more cost effective than Harrop.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 12:03 PM #29
Good to know, I always see there ads on craigslist so figured they have a pretty big inventory. Yotamasters has a used elocker motor for 250 if anyone is on the hunt. I've bought through them numerous times and they are super helpful.
Old 05-29-2020, 01:05 PM #30
nosfanatic2006 nosfanatic2006 is offline
nosfanatic2006 is on a distinguished road
Trade your 4runner in for an '09 Trail Edition
2009 Shadow Mica Trail Edition - 2" Dobinson lift, 285/75r16 Cooper ST MAXX, gunmetal FJ Cruiser 16" TRD wheels, 1.25" Spidertrax spacers, Powerstop rotors and pads, Rola roof rack with 4xInnovations low pro mounts and LED's front and rear, NAPA awning, Rago ditch light brackets with Caliraised side shooter led pods, Caliraisedled 2012-15 Tacoma fog light mounts with amber led pods
nosfanatic2006 is offline   Reply With QuoteReply With Quote
cruiser , good , owners , tips , toyota
Would finding a second hand rear axel from an FJ be the cheapest way to lock the rear bassmacka 4th Gen T4Rs 25 01-27-2018 03:08 AM
Rear Locker vs Center Locker in Practical 4x4 Uses?? Xx_Black-out 3rd gen T4Rs 46 11-24-2017 10:43 AM
Any difference in rear axle shafts between e-locker/non locker? 99Runnr 3rd gen T4Rs 4 02-25-2016 09:19 PM
Installing Spartan locker tomorrow, Tips? kolbydmc 3rd gen T4Rs 29 08-09-2014 11:17 PM
Requesting tips for finding clock problem greyrock 3rd gen T4Rs 6 11-07-2009 12:45 PM
