Old 05-26-2020, 10:30 AM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Tips on finding a rear locker?
I've been watching carpart, but it doesn't look like many of the local junkyards use it. That, or all the FJ Cruiser owners are really good drivers (Ha).
Anyone have any tips on where to source an 8 inch toyota e-locker?
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 01:19 PM #2
rich dog rich dog is offline
rich dog is on a distinguished road
I snagged a tacoma elocker off of craigslist. Same gear ratio and was about 180 for the harness from low range offroad. lkq might have some on hand. check tacoma world's classified also.
rich dog is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 03:57 PM #3
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I apologize for hijacking gimlithepirate's thread but I'm curious; How much trouble is it to make the switch to the factory locker, running harness and stuff, and is it basically plug and play? And what year Tacoma and/or FJ will work for an 05 V6 model, (if you know). Thanks
importman is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 04:28 PM #4
Quiero Quiero is offline
Quiero is on a distinguished road
I decided that if I take the plunge on mine I'm just going ARB air locker
Quiero is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 08:47 PM #5
You need to grind out a small portion of the housing to fit the motor and purchase a few longer studs. Lowrange sells all the equipment needed. I found a 3.73 from a tacoma. Pretty sure the fj autos have the same gear ratio. v6 runners may be a 3.90? the v8s are 3.73.
I think all second gen tacomas and first gen fj cruisers are plug and play minus the grinding. E lockers are great for a daily driven rig. I've got a detroit in my first gen and while its fun to chirp corners I think it would get old on a daily driver.
Never had an arb but I always hear of people having issues with air lines popping loose and then you need onboard air as well.
Old 05-27-2020, 09:43 AM #6
Didn't realize some of the Tacomas were 3.73's. That's good to know.
I would definitely do the low range off road kit. Most stock looking option for these.
Toyota e-lockers have a pretty great reputation, and I think it's a better option than dealing with all the potential problems an air locker system brings.
Old 05-27-2020, 09:51 AM #7
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I would agree that a rear Toyota elocker is a pretty good and reliable option.
If you are eventually wanting a front locker, an ARB makes more sense, as you'll need the compressor and air components anyway.
If you can't find a used elocker diff, might try emailing ECGS and see if you can swap yours plus some money for their rebuilt elocker diffs. You could get it rebuilt with a solid pinion spacer at this time too. Not sure if they stock elocker motors or if you'll need to find one separately, those can be expensive.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 12:47 PM #8
ECGS will do the swap, and the nice part is you get a high quality rebuilt unit as opposed to a junkyard one. The problem is the actuator motor, which does not come with that package, and as mentioned gets seriously pricey.
A local shop is swearing high and low that Eaton makes an e-locker for a Toyota 8 inch, which I can't find anywhere online. Only other e-locker option I've found is Harrop, which is pricey
Old 05-27-2020, 02:16 PM #9
I think eaton/harrop is the same thing if i'm not mistaken. If you're going to regear i think your best bet is to go east coast gear. If you're planning on staying with your stock setup its probably better to find a used setup. all in i'm at $550 for the third member and gaskets/studs/harness.
Old 05-27-2020, 02:25 PM #10
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Doesn't the 8.2 FJ 3.73 elocker rear axle just swap directly in with no modification needed?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 02:26 PM #11
Inv4drZm's Avatar
Inv4drZm's Avatar
The entire axle assembly w/ housing, yes.
Old 05-27-2020, 02:38 PM #12
Which years should I be searching for?
Edit: looks like 2010-2014.
Old 05-27-2020, 02:43 PM #13
Inv4drZm's Avatar
Inv4drZm's Avatar
Yes, and as far as I know 5th gen 4Runners axles can swap over too, they are all 8.2 but not as many w/ elocker as FJ's.
Old 05-27-2020, 04:52 PM #14
I'm just running 33s so no need to regear. I would run the used one, but I cannot seem to source one. The ones on eBay tend to be absurd, and I have not had any luck local yet.
Old 05-27-2020, 07:55 PM #15
Look up rancho toyota recycling. They are in sacramento and have a ton of inventory. I'm sure they could source a diff and ship it. not sure on the pricing.
cruiser , good , owners , tips , toyota
Would finding a second hand rear axel from an FJ be the cheapest way to lock the rear bassmacka 4th Gen T4Rs 25 01-27-2018 03:08 AM
Rear Locker vs Center Locker in Practical 4x4 Uses?? Xx_Black-out 3rd gen T4Rs 46 11-24-2017 10:43 AM
Any difference in rear axle shafts between e-locker/non locker? 99Runnr 3rd gen T4Rs 4 02-25-2016 09:19 PM
Installing Spartan locker tomorrow, Tips? kolbydmc 3rd gen T4Rs 29 08-09-2014 11:17 PM
Requesting tips for finding clock problem greyrock 3rd gen T4Rs 6 11-07-2009 12:45 PM
