04-22-2014, 08:34 PM
Real Name: Alex
Real Name: Alex
Resonator Delete Questions...
I've been searching, and have found information on the resonator delete only with pipe welded in its place. Will I have any issues with doing a resonator delete and having the tailpipe end right where the resonator starts? At least for a while, that is.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
- Helpful DIY Videos
04-22-2014, 08:39 PM
It'll rattle around on the axle I think cause there aren't any hangers on the end.
2003 SR5 4WD: V8 TRD Supercharged, TRD Headers, ARB Bull Bar, CBI Rear, OME 886 coils w/ 1/4'' Spacer, AllPro 3.5's w/1.5 DS, 5100's, 285 Cooper STT, Slee SS Brake Lines, Custom Sway Bar Links, 4xInnovations Sliders, AllPro Lower Links, DDM HID's, 30" Light Bar/Duallys, Safari Snorkel, Custom Y-Pipe, Magnaflow, BudBuilt, KurtFab Diff-Brace, Wet Okole's, JL Sub/Amp, KCCO
04-22-2014, 08:44 PM
Real Name: Alex
Real Name: Alex
I guess I could do something for the time being, but will the heat being so close to the tire create an issue?
04-22-2014, 08:45 PM
Surprisingly it doesn't rattle much at all. I cut mine just after the axle and before the resonator so it was pointing downward, its been rattle-free for the most part. I may move it to the side later down the line, but it works fine now; I cut mine off with a cut off wheel, didn't have a Sawzall handy.
04-22-2014, 08:46 PM
Real Name: Alex
Real Name: Alex
Can you forsee an issue with cutting it later than you did, So that the pipe is still pointed back?
04-22-2014, 08:51 PM
Uhm... not really? I mean it'd have more freedom to move about probably, I really don't remember there being that much extra before the resonator.
04-22-2014, 08:52 PM
Real Name: Alex
Real Name: Alex
Well, I guess it's my turn to test!
04-22-2014, 10:20 PM
Real Name: Alex
Real Name: Alex
Pipe cut, but that hanger doesn't want to come off, am I missing some sort of trick you guys use?
04-22-2014, 10:30 PM
Long Screwdriver + Wiggle & Pull is what works for me?
04-22-2014, 10:34 PM
Real Name: Alex
Real Name: Alex
I guess that means stretch around that bigger piece?
04-22-2014, 10:37 PM
Basically I slide the screw driver between the pin and the rubber bushing and wiggle it around until I can pull the hanger off, its usually as simple as that. Worst case, just cut it if you're not using it.
04-22-2014, 10:41 PM
Silicone spray or WD-40 and pull.
04-22-2014, 10:53 PM
Real Name: Alex
Real Name: Alex
Combined both of these, and it's off. Will do a shake down now, to see how rattle-y it is. I'll just ubolt makeshift hanger it.
04-22-2014, 11:38 PM
Awesome! How does it sound with out the resonator and stock muffler? I'm considering doing this to my moms GX470 and getting a nice "Lexus looking" tip welded on in place of the ugly resonator. While my dad appreciates his flowmaster and no resonator on his 4R I don't think my mom would love her Lexus to be loud.
05-05-2014, 10:36 AM
Real Name: Alex
Real Name: Alex
I've got a borla 14" proxs on there. Just... well quite a bit louder than stock.. sorry
