Old 05-27-2020, 09:45 AM #1
newsithlord newsithlord is offline
newsithlord is on a distinguished road
2005 V6 Passenger Side Upstream O2 sensor replacement
I have a 2005 Sport model with the V6. I am getting a PO420 code as well as the check engine light and VSC lights. I replaced the downstream O2 sensor and lights went out for about 240 miles then came back on. New gas cap and zero point calibration done. So, I guess my next step is to replace the upstream passenger side O2 sensor.
I can't get the upstream O2 sensor unplugged. Has anybody got any tips? I haven't tried to loosen O2 sensor yet. That one looks to be a pain as well. Any tips on that?
If that doesn't fix it, I guess I can put on a new passenger side manifold and catalytic converter.
Running out of options and I really don't want to take it to the dealer.
Any help would be great!
Thanks!
newsithlord is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 10:10 AM #2
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Check the exhaust gaskets for leaks and look for holes before the down pipe.
Itís not likely to be the upstream sensor triggering that code.
2004 4Runner Limited V6 4WD
369,000 Km
Titanium Metallic
Other Vehicles: '17 Acura TLX SH-AWD Tech, '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 12:37 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a jewel in the rough Bossman is a jewel in the rough Bossman is a jewel in the rough
Bossman's Avatar
Toyota Parts | P0420 Diagnostic Code - Trouble Code Diagnosis Guide
Check Engine Light Code P0420
Another P0420 thread
the dreaded "P0420". Mechanic's answer needed
Code P0420, Cat or O2 sensor?
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 05:13 PM #4
Thanks for the help! I'll look for exhaust leaks at the gasket. I know there are no holes in the exhaust pipe itself.
My mileage is about 20.8 mpg and it runs great. Just throwing that code.
I replaced the plugs and coils to rule them out.
My biggest thing right now is I just can't seem to get the upstream O2 sensor unplugged from the harness. Limited space but I can get my hand all over it. Can't feel a tab or anything to release the plug.
I'll keep trying. Any tips would be great.
Thanks again!
Old 05-27-2020, 06:47 PM #5
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Thanks again!
I know other people have said the upstream sensor isn't the issue, but if you're set on taking the sensor out here's what I remember. The upstream sensor is the same plug type as the lower sensor. I used a small flat blade screwdriver to press down on the tab. You could also try getting a pair of long-reach needle nose pliers in there to pull on the plug.
As a last resort, would pulling off the big plastic intake on top of the engine give you more room to work? Maybe the sensor is low enough that it doesn't matter, but itt's pretty easy. Just unclip the air filter section, then unscrew the two bolts holding it on. You'll also need to loosen the clamp at the very top/front of the engine where the MAF is and pull off the thin vacuum hose behind the big plastic intake. Keep in mind if you've never taken this piece off, you may need a new gasket for the bottom of this piece if you're current gasket is dry or cracked.
Are you thinking about swapping the upstream sensors so the passenger side is on the driver side and the driver side is on the passenger side? That would definitely help rule out the sensor. The driver side is a little harder to get out, but they can both be done with the right tools and a lot of patience.
djpope09 is offline   Reply With QuoteReply With Quote
lights , passenger , sensor , side , upstream
Passenger side oxygen sensor BigMike18 4th Gen T4Rs 1 02-14-2020 01:43 AM
3rd. Gen passenger Side Bumper Replacement Last Man Standing 3rd gen T4Rs 9 09-29-2019 08:42 PM
ABS sensor wire harness passenger side for 97 4Runner yota_addict Want to Buy/Trade 0 09-18-2015 07:28 PM
WTB: 2005 Passenger side mirror glass and remote fob skategoat Want to Buy/Trade 0 01-19-2009 11:35 AM
