Old 05-27-2020, 11:59 AM #1
joshik joshik is offline
joshik is on a distinguished road
03->06 Projector with HID hot spot issue
I finished the 03-06 projector install a few weeks ago and have been battling an issue with the passenger side performance. I can't get a nice hotspot. The hotspot is pretty funky. The driver side is fine.
I'm pretty sure this is not how the hotspot is suppose to be, right?
This is from the first headlight but the second one is pretty much the same.
I am running HIDs and switched bulbs between the driver and passenger and still the same . I swapped out the passenger side headlight with another one and same thing. I doubt I have two faulty headlights housings....?
I haven't done the squirrel finder mod yet on the passenger side but that shouldn't affect the hotspot yeh?
I am getting a 9006-H11 adapter so I can try a halogen bulb.
2003 4Runner Limited 4wd V8. JBA UCA, Bilstein 6112 & 5160. Icon 2" springs. Cooper AT3 275/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 02:22 PM #2
Gen4SR5 Gen4SR5 is offline
Gen4SR5 is on a distinguished road
wait, so you are using 9006 HIDs in the projectors right now? I think that may be your problem. The housings can only fit H11 bulbs
Gen4SR5 is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 03:23 PM #3
sorry, no, i'm using H11s. I have some H11 halogens but cant try them as my connector is 9006. I'm getting connector adapters so I can connect to a H11 halogen.
Right now, I'm using DDM HIDs which have a universal plug.
Old 05-27-2020, 05:26 PM #4
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is a jewel in the rough Drift Monkey is a jewel in the rough Drift Monkey is a jewel in the rough
Use proper projectors designed for HID and it won't be a problem.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 06:40 PM #5
The driver side doesn't have this issue.
But we will see, I will put halogens in tomorrow once I get my connector adapters.
Old 05-28-2020, 01:35 AM #6
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C is a jewel in the rough Ed_C is a jewel in the rough Ed_C is a jewel in the rough Ed_C is a jewel in the rough
Ed_C's Avatar
Real Name: Ed
OEM or aftermarket headlight?
Originally Posted by Bumbo:
I can just visualize you beating someone down with a pork roll after a botched alignment.
Old 05-28-2020, 10:19 AM #7
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
its ddm bulbs, i would use the morimoto h11b bulbs.
but of course you cant compare these to true hid retrofits.
03->06 Projector with HID hot spot issue-img_20190125_043403-jpg
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Bridgestone Dueler A/T REVO 2 265/70r17. retrofited S2000 projectors,Osram 66240CBB,Morimoto 5Five Ballast.2 pairs of Hella Supertones.Blue cluster and climate controls.Full led conversion on interior and exterior.HAWK LTS pads f+r, Stoptech slotted rotors and stainless steel lines f+r.Firestone CoilRite 4135.Bilstien 5100 @0.85, MOOG FJ Springs.
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 04:02 AM #8
oem headlights.
i put in halogens today and still the same thing, so it's not the bulb. The driver side is fine, it's just the passenger side, whic is weird....
Old 05-29-2020, 04:04 AM #9
Attachment 362312
Agree. It ain't a balla setup but still doesn't explain the weird hot spot. Should still work. :T
Old 05-29-2020, 09:49 AM #10
riceandpho's Avatar
riceandpho's Avatar
having the correct bulbs will help also.
there is 2 kinds of h11 hid bulb.
the regular one will have the return wire in the top position,
the h11b will have the return wire at the correct position for the h11 halogen projectors.
the pic you have seems like the ground shadow effect when using the wrong hid bulb.
H11B: Morimoto XB HID
the website usually describe it, also how far was the light from the wall? to get accurate visual, must be 25 feet away.
Old 05-29-2020, 11:53 AM #11
ah yeh i was just thinking that! I was going to check on the return wire today. The picture was of the 4R close up to the garage to just get an idea of light output between the driver and pass side. I went on an aiming session run the other week and followed the manual and thats where i discovered the output differences.
I'll report back on the H11 vs H11b.
Old 05-29-2020, 06:53 PM #12
So I checked and the HID bulbs I have are in fact h11B. The return wire is on the opposite side of the wide tab.
I stopped by DDM anyways and changed out the bulbs and same issue.
Thinking about it, if it was the H11A vs B, the driver side should see the same issue.
I got some new halogens and will try them out tonight. Using halogens, everything should work perfectly as these proj were made for halogens, right?
If not, then I'll have to try another headlight.
Old 05-29-2020, 09:45 PM #13
riceandpho's Avatar
riceandpho's Avatar
the more i look at the main pic, it possible that the projector is shinning through the dot of the headlight lens, usually they use them alignment box thingy.
Old 05-30-2020, 12:04 AM #14
yeh i see those little dots. I don't think its that. You can see that the way the light refracts off the lens that it's not very "full".
You can see the diff. Not sure what to do. Even the halogens (Osram Night Breakers) do the same thing. I'll prob try another pass side headlight.
Driver Side:
Pass Side:
Old 05-30-2020, 09:01 PM #15
riceandpho's Avatar
riceandpho's Avatar
could also be burned bowls.
Driver Side:
Pass Side:
headlight , hotspot , passenger , pretty , side
ARB bumper mount modding. Anyone spot an issue with this? masphx 3rd gen T4Rs 1 01-27-2015 04:35 PM
TRS projector retrofit issue... can anybody help? bimrunner 5th gen T4Rs 19 07-20-2014 11:33 AM
Can you spot the mod? tamerunner 5th gen T4Rs 4 09-07-2013 11:16 PM
Blind Spot COarcher 5th gen T4Rs 14 04-24-2010 12:10 AM
