05-28-2020, 02:55 PM
Not the headgasket!
Hey guys,
I've suspected my 06 (V6, 230k miles) of having a bad head gasket for ~6 months now. It would randomly misfire on startup and sometimes show a P0302 (Cylinder 2 Misfire). I made that assumption, and started ordering parts to replace the gaskets.
I finally started to work on the truck today and decided that I needed to confirm the head gasket before I tore into it. I performed a leak down test on all 6 cylinders. No cylinder had more than 7% leakage and the Cylinder 2 plug was soaked in fuel, the other 5 were dry. It looks like I'm returning some parts and buying an injector!
I've found a few threads that have had the same issue. I feel like an idiot jumping right to the head gasket failure.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
05-29-2020, 09:54 AM
Real Name: Danny
Real Name: Danny
Originally Posted by RivMan
Hey guys,
-Rob
I know that's a relief. Hope I never have to deal with headgaskets either.
05-29-2020, 10:32 AM
Leaking Injector seal? I've seen couple of thread where the leaking injector seal caused the same symptoms as the leaking headgasket.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
05-29-2020, 10:52 AM
Seems to be a leaking injector. I have a new set of six on order, should be back up and running next weekend!
-Rob
05-29-2020, 10:56 AM
Real Name: Kevin
Real Name: Kevin
Had the same issue with mine! Apparently the injectors on 1GR-FEs (especially injector 4 and 6) like to stick open as they get older/go through lots of heat cycles. Fuel then dumps into the cylinder when the vehicle is turned off for a few hours and causes a misfire on startup.
Make sure you get a quality set of injectors. The first set I got were eBay specials and didn't work out of the box. The next set were OEM remans from Rockauto and are perfect.
I'd also recommend changing your oil, as it's likely pretty contaminated/thinned by gas.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
05-29-2020, 01:50 PM
Did you get the BeckArnley or GB Remanufacturing injectors from RockAuto? They both say Denso, but the BeckArnley injector is almost twice as much and looks like crap in the picture lol.
05-29-2020, 01:56 PM
Real Name: Kevin
Real Name: Kevin
I went with GB. They came super well packaged and work perfectly.
05-29-2020, 02:14 PM
I ended up ordering some cheap eBay ones. We'll see how they do, the seller has been around forever and seems to have legit feedback.
6x OEM Denso Fuel Injectors 03-15 Toyota Tacoma 4Runner Tundra FJ Cruiser 4.0L | eBay
-Rob
05-29-2020, 02:18 PM
Real Name: Kevin
Real Name: Kevin
Those are about twice as much as I paid for my eBay ones, so hopefully you have better luck than I did!
06-09-2020, 07:55 AM
Hey guys,
-Rob
did you notice a drop in your coolant level?
i think 100 percent of all hg issues, exhibit a drop in coolant levels.
i went with ebay remanns, and they are doing great, 7 months down the line
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
06-09-2020, 10:40 AM
When I first checked the coolant level after owning the truck for a year or so, it was a little low. It doesn't seem to have dropped at all since then.
I'm still waiting for my injectors to show up, they seem to be in USPS limbo.
-Rob
06-10-2020, 12:21 PM
-Rob
the odds of having a head gasket leak, without drop in coolant level is ultra slim. its a surefire way to rule out HG issues, if/when you have a misfire.
park on the same spot and observe your coolant level frequently
