Old 05-28-2020, 09:27 PM #1
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Dobinsons + JBA UCA + RAS Swap
So finally got the front springs on, needed to borrow my friends shop as so many bolts seized, had to basically burn the castle nut on uca off.
Front
bilstein 5100 set at 1st perch (before at 0.85)
Dobinsons c59-314 + 10mm spacer drivers side
JBA UCA
Rear
Removed rear air suspension
Metal tect 4x4 stage 1 swap
moog k160061 Isolators
Now dobinsons c59-325
New sway bar end links
Bilstein 5100
Finnally got rid of the front clunking noise on bumps, guess it was the leaking UCA ball joint.
A little pissed at the alignment guy brought it in right away and he only corrected toe, said i had to tell him to correct caster. Anyways no big deal will be waiting for springs to settle for another proper alignment. What caster should i be aiming to get with new JBA uca?
Also are you guys using standard red lithium grease for the Jba UCA?
Next up: new windshield, transmisson cooler line, bumpstops, maybe skids/sliders.
Imgur: The magic of the Internet
2005 4R LIMITED V8
FALKEN WILDPEAK AT3W&TRD RIMS
DOBINSONS SUSPENSION 2.5" F 2" R / JBA UCA / POLY PERFORMANCE TACO TAB/ 2ND GEN REAR LINKS
VOLANT CAI/ RA MOTORSPORTS SKID & DITCH LIGHT MOUNT
MAGNAFLOW MUFFLER
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 07:05 PM #2
SumoRerun SumoRerun is offline
SumoRerun is on a distinguished road
Looks nice man! Most shops near me only do a toe set unless told otherwise. I found a shop about an hour from me that does alignments real old school with paint, scribes, and tape measures. I've exclusively used them for my alignments and have had no issues.
SumoRerun is offline   Reply With QuoteReply With Quote
caster , dobinsons , front , jba , uca
FS: Dobinsons C59-300/C59-327 Springs (used) Anand For Sale: Suspension/Wheels/Tires 8 03-04-2020 02:05 PM
Dobinsons vs OME? cmorrow 4th Gen T4Rs 15 03-07-2019 07:34 PM
Dobinsons vs Bilstein 6112/5160 (+ Dobinsons ?s) MossJenks 5th gen T4Rs 14 09-19-2017 10:58 PM
Dobinsons Lift Kit albertomc 4th Gen T4Rs 0 03-01-2013 12:06 PM
