Old 06-01-2020, 05:43 PM #1
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
LEDs on HVAC help
Hello,
So, I recently "redid" my HVAC assembly using new 12v LEDs for the HVAC display. (long story). Anyway, as you may now, the factory backlight is 6v, I did a reverse polarization to my screen and am using (trying) 2 LEDs rated at 12v (I tapped the radio power). 12v+ coming from the radio power and the negative from the assembly's negative.
Following are the "sockets" for the factory bulbs that illuminate the HVAC display. Note the + and - . (positive side not used, but negative is for dimming)
So then, because my assembly was butchered (too much solder was placed onto the contacts, so a factory bulb or LED can no longer be "inserted"), an LED or bulb has to "sit" on top of it. For the negative part to make contact, I taped it hoping it would secure it. I was wrong.
I tried removing the excess solder, but was unsuccessful.
I used tape to secure bulbs in place.
Here is a picture when I hooked up the LED to the 12v wire. Obviously, no light.
Here is a picture when I put pressure on the bulbs. Doing this obviously makes the base make contact with the negative thus turning the LED on.
My question to ya'll is:
1) How/what should I use to adhere the bulbs? Soldering came to mind, but I'd rather not do that.
If you guys have any suggestions, let me know!
CookieRoe is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 02:05 AM #2
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Originally Posted by CookieRoe View Post
Hello,
So then, because my assembly was butchered (too much solder was placed onto the contacts, so a factory bulb or LED can no longer be "inserted"), an LED or bulb has to "sit" on top of it. For the negative part to make contact, I taped it hoping it will secure it. Wrong.
I used taped to secure bulbs in place.
Honestly if the rest is butchered so bad with solder, then you might as well just solder that negative contact so it works, LED’s last so long there’s a good chance you may never have to replace it.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 09:11 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i just use some high temp hot glue. you can try the gorilla glue, that gel stuff, i use that on my dash kit to keep the trim ring in place.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 10:22 AM #4
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
After looking up what adhesives to use, I went back to thinking about soldering it. I'm not good at it, but I'll try to apply some solder onto the base of the bulb and see how that goes. It's not that it's butchered, there is a GLOB of solder on the bulb contacts that it is extremely difficult for me (non-expert and little experience) to get it all off. I got some wix and a desoldering pump, but that didn't work. I gave up early b/c I didn't want to fry the circuit board.
That is what I was thinking. There is some electric conductive adhesives, but MAN those are expensive. As long as the negative is making contact with the negative side base I should be fine.
Old 06-02-2020, 12:40 PM #5
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
@CookieRoe i didn't do that did I? Wait, i remember, i fixed the cluster. I can work on your HVAC if you want. I actually just acquired a spare. I would suggest putting the led's in place, use a hot glue gun, see if that works. Easily removable if doesn't work.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 02:54 PM #6
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
No Mark, it wasn't you, it was emiliankov who did that. He's no longer here, nice guy, but his work was sloppy. BTW, cluster is still going strong! I've been doing a lot of soldering lately (installing lots of mods during this covid-19 crisis) and let me tell ya, SCREW soldering those TINY LEDs in the cluster, more power to ya!!
HOT GLUE GUN......................
DAMN, why didn't I think of that. Rubbing alcohol takes it off, right?
so, yeah, I was going to lay a little bit of solder onto the base of the LED (touching the negative wire, of course), smooth the "glob" of solder and hope they make better contact that way. The hot glue will definately insure a secure fit.
THANKS!
Old 06-02-2020, 04:13 PM #7
I would have thought with wix and a soldering pump, you should have been able to get it off. Soldering is an art though and I’m not very good at it either. Pretty crude but can I get the job done in basic scenarios.
I was going to suggest hot glue but have had many bad experiences with it coming right off in warm to hot temperatures for many applications. Didn’t realize they made a high temp hot glue though. That would be pretty easy.
Old 06-02-2020, 08:14 PM #8
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
The pump seems to be good for taking small "circular spots" of solder off of circuit boards, not the way it was applied onto my bulb contacts. I tried and tried, but I noticed not a lot was coming off. Unless I had to use flux or something (I didn't have). Anyway, I didn't want to overheat it so I backed off.
As far as the hot glue gun idea, my wife has a basic one (nothing fancy), but I've seen it work. Like I mentioned, it can always be removed safely by using rubbing alcohol (good luck finding it nowadays, LOL). I was honestly considering getting a silver epoxy, but that is mad expensive and permanent (yikes).
I'll be tackling this tonight and report tomorrow. If I come back cursing in German, ya'll will know how it went.
Old 06-03-2020, 07:50 PM #9
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Success!
So, I ended up getting some solder on my trusty iron and attempted to solder the led negative wire to the bulb base (negative side). They stuck of course, but I wasn't feeling easy about them, so I got a hot glue gun and secured them in. Soldering and glueing took about 5 min. Went to my rig to hook up the 12v wire and BLING BLING!
These are 12v LEDs, bright white. Last time they were amber LEDs and they didn't do much to illuminate the display. This was about 5-6 years ago. During the day, especially with the bright sun, the display was virtually dark. However at night, they were the perfect color. Oh well. With these white LEDs, they are brighter and retain (somewhat) the yellow color that is true to the factory. I'm a happy camper. Oh, and b/c they are connected to the negative base of the bulb, they dim with the dimmer.
Thanks everyone for their help!
Old 06-04-2020, 11:29 AM #10
Real Name: Mark
Real Name: Mark
@CookieRoe Soldering??? I used hot glue on your entire Cluster!! Its Duct tapes long lost cousin! I keed i keed. I will say, I tried my cluster when i started the whole deal without flux. it was the worst experience ever. I use this now
MG Chemicals 8341 No Clean Flux Paste, 10 milliliters Pneumatic Dispenser (Complete with Plunger & Dispensing Tip): Soldering Cleaning Products: Amazon.com: Industrial & Scientific
I would never solder circuits or anything without it. Makes the process so simple.
'04 Sport V8
Old 06-04-2020, 11:34 AM #11
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Wow, you made me nervous for a minute there, LOL!
A neighbor LONG AGO told me never to solder without flux. Many others told me that was BS. I haven't used and will now in the future. Maybe that is why soldering is a PITA for me.
MG Chemicals? Nice, I used their conductive epoxy to pot my HID ballasts. Best stuff on earth for that!
Old 06-04-2020, 12:44 PM #12
Real Name: Mark
Real Name: Mark
Well, it all depends on what your soldering. The 3 years i worked at Circuit City and installed car stereos, i used a torch and nothing else. Obviously make sure your not burning holes in someones car!
When its small wires or anything else use flux for ease!
Glad my job is still holding strong!
'04 Sport V8
Old 11-12-2021, 03:16 PM #13
Real Name: Mark
Real Name: Mark
Originally Posted by Connoleib View Post
Is it worth paying someone to do this for you?
Yes, absolutely! I know a guy!
'04 Sport V8
bulbs , factory , hvac , led , negative
HVAC illumination, specific question other than replacement neo LEDS. randy88fj62 4th Gen T4Rs 14 05-19-2020 06:57 PM
Hvac panel leds wracks03s 4th Gen T4Rs 2 05-05-2020 05:04 AM
WTB: who can install speedo cluster and hvac leds? philskeeter Want to Buy/Trade 7 06-12-2014 10:14 PM
LEDs not the right fit? murdarunna19 3rd gen T4Rs 1 01-17-2013 01:09 AM
Where to buy LEDs cdoyle 4th Gen T4Rs 0 06-09-2004 11:26 PM
