Old 06-02-2020, 09:50 PM #1
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Engine Problem
So I’ve got the P0171 and P0174, I’ve cleaned the maf (DONT know if it’s oem or not it looks pretty new). Put new PCV Valve in, sprayed carb cleaner all over engine nothin. Fuel pressure is around 42Psi. I inserted a new right side exhaust even cat and 02 sensor. And my car is hesitating on take off, terrible mpgs, and fuel trims are at about 26% right off start
Engine Problem-b9215ac1-eca4-4f8c-a440-94f3f6726e88-jpg
BigMike18 is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 01:52 PM #2
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
i ahd a similar problem with LTFT bank 2 getting as high as 36 percent and bank 1 18. changed all injectors with cheap ebay remans, problem solved, though i sometimes get the CAT codes..so i think i may have damaged the CATS from driving with such high fuel trims for a long period
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 01:54 PM #3
I’m leaning towards vaccum leak? Because I watched this video.
YouTube
And I have the exact same numbers and problem and I don’t know where it at
Old 06-05-2020, 01:06 PM #4
YouTube
in mine, the 2 bank fuel trims dropped to below 1..immediately after i changed the injectors.
if you suspect a vacuum leak, maybe you try the smoke bomb kit or soapy water spray.
Old 06-05-2020, 01:24 PM #5
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Given the bank 2 fuel trims showing excessively high, and no reaction to VOC spray at the intake seals, this reads like a fuel injector problem.
I'd remove the spark plugs on bank 2 (driver side) and read them, post pics here showing the insulator cone and electrode surfaces.
waypoint is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 04:06 PM #6
AceSpades AceSpades is offline
AceSpades is on a distinguished road
Actually, he is getting high fuel trims at both banks. That would lead me to look at the fuel pressure regulator. I know you measured 42psi, but that may read good at idle only and may possibly be dropping when under load
AceSpades is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 07:54 AM #7
waypoint's Avatar
waypoint's Avatar
Good catch, thanks for the correction while I re-read with coffee on board.
Old 06-10-2020, 12:27 PM #8
i had high trims as well on both banks, with bank 2 being higher... exactly the same scenario, OP is facing. my money is on the injectors.
mine, bank 2 went as high as 39 percent, bank 1 19 percent
42psi , engine , fuel , inserted , i’ve
Engine problem? Kev4runner Classic T4Rs 2 09-16-2012 07:38 PM
Engine electrical problem jcpaoli 4th Gen T4Rs 11 02-28-2012 04:30 PM
engine problem??? miggyhdt Classic T4Rs 0 06-12-2011 02:21 PM
Engine problem! HELP PLEASE imryannn 3rd gen T4Rs 8 03-30-2011 05:21 PM
Engine Problem Paxton Problems & Warranty Issues 5 03-17-2006 08:39 PM
