Old 06-03-2020, 07:20 PM #1
blue-r6 blue-r6 is offline
blue-r6 is on a distinguished road
2006 4Runner AC issues
I noticed my ac was not working on the driver side but my passenger side was working ok. I looked at my blend doors and they were working and also took them apart and they seem ok. I hooked some ac gauges up and I had 75psi on the low side and 60psi on static pressure (car not running). I start car and turn the ac on and the low side drops to 0psi and the high side went to 85psi. I turn ac off and the low side goes back to 75psi. It sounds to me like I have a clog somewhere. Maybe the Oriface tube or expansion valve? Any ideas.
blue-r6 is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 08:08 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Sounds like a low charge or plugged expansion valve. Both sides are reading low. Without knowing ambient temp the OK range for lownside is 25 to 50psi give or take, high side would be 150 to 210. My guess would be a low charge. Check the state of charge before doing anything... Mine had a slow leak at the bottom on the condenser where the dryer sits. A new oring took care of it. I put in a new dryer while I was there for short money. Let us know what you find!
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 09:59 AM #3
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
I had a similar issue, cold on passenger and hot on driver and like you, the blend door was not my issue. Question, are you using the gauge that comes with the refill bottles like from Autozone? That's what I used, and it was extremely inaccurate. I ended up taking it to a shop and it was simply a low charge, even though my gauge was reading something like 75psi with the car turned on. Charged up over a year ago and working fine ever since.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 01:19 PM #4
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I had all those symptoms in my 2005 4runner (124000 miles). Mechanic charged the AC system, but it cooled for less than a week. Did this two or three times. He then checked with dye.
Then he said get a new compressor (was leaking there). Bought one off Amazon for $200. He installed it for $200 and recharged the system.
Been cooling good for two years. Not like when the car was new, but good and the same cool for two years.
Not going to throw parts at it, as they are expensive, and cheap compressor (new) got it cooling again.
Captsolo is offline   Reply With QuoteReply With Quote
75psi , low , side , turn , working
Need advice with 2006 V6 brake issues rwmille 4th Gen T4Rs 12 02-27-2020 08:18 AM
2006 V8 AWD limited brake issues sticking caliper Mayhem988 4th Gen T4Rs 0 08-22-2017 06:49 PM
2006 AC issues help!!! kristir77 4th Gen T4Rs 7 07-08-2017 05:04 PM
93 4Runner radio issues and door actuator issues. 128keaton Classic T4Rs 2 05-10-2015 10:11 PM
Serious Snow Issues 2006 Sport Edition V8 4x4 aeanderson87 4th Gen T4Rs 30 03-15-2013 11:12 PM
