Old 06-08-2020, 01:15 PM #1
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
CV axles
So, I've been using CVJ CV axles for almost 10 years since they're local to me. I had them in my 3rd gen, and now I use them my 4th gen. I just saw that the red silicone boot has a small tear after two years and it's starting to spit grease. I called CVJ to see if there's a warranty and there isn't since "lifted" etc.
I'm a little disappointed, since I don't even wheel this truck hard at all, and there's a 1" diff drop so the CV angles are pretty solid even with the 3" lift. I want something that's going to last longer than that, and I feel like even the ones I had on my 3rd gen tore after 4 or 5 years, but I can't recall specifically.
I was thinking of just going for OEM CV axles, but the tech there said they don't last long in lifted vehicles. Can anyone confirm this? I feel like I see a lot of new lifted 5th gens with OEM CV's and they seem just fine. I know they're spendy, but I'd rather just cry once and be done with it.
Maybe this was just dumb luck and something punctured the silicone and I should just get another one again?
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 04:56 PM #2
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
From what I have gathered after doing research in this topic was the the OEM Toyota 4th Gen CVs are one of the strongest you can have. If your silicone boot is destroyed id just replace the boot and go on about your day, switching out the entire CV seems overkill.
royal T4R is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 05:05 PM #3
montijo505's Avatar
montijo505's Avatar
Get new OEM boots, only ones I haven't had problems with. To be clear I've never had the red ones but their regular ones tear in about a year or two with 3" lift. OEM boots are plastic instead of rubber, much stronger. For the side that touches fins just do the boot slide mod.
Sent from my SM-G986U using Tapatalk
Old 06-08-2020, 05:42 PM #4
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Agreed. Get new OEM (or lowpro) boots for your existing CVs. I did all the research, was all gung-ho to do it, and then crawled under there and realized that the previous owner had put cheap Chinese ones on it -_-
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 06:21 PM #5
atalarico's Avatar
atalarico's Avatar
Normally for most parts I'd agree, but I've rebuilt CVs...and never again. haha
Old 06-08-2020, 06:22 PM #6
atalarico's Avatar
atalarico's Avatar
I wonder why duder at CVJ said they don't work well with lifted trucks then. I'd hate to think he just said that to salvage a sale, but...a sale is a sale.
How long have you had yours and how do they do with the lift? Do you have a diff drop?
Old 06-08-2020, 06:39 PM #7
montijo505's Avatar
montijo505's Avatar
Yes diff drop, about a year on the most recent since OEM boots, before that junk CVJ rubber ones that suck.
I dreaded rebooting big time, but as long as you take your time and use gloves/ trash bag/ lots of napkins, it's really not too bad.
I sit on my garage floor, cut open a large thick trash bag and use that as destruction zone lol. When you're done, wrap up the bag and straight to the trash.
Old 06-08-2020, 07:26 PM #8
truestorydl truestorydl is offline
truestorydl is on a distinguished road
I have a tear in an OEM Axle/boot and all I have heard is to stick with the OEM axles whenever possible! Apparently they are the strongest and last the longest. Mine also spits grease and I want to reboot ASAP.
truestorydl is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 11:48 AM #9
atalarico's Avatar
atalarico's Avatar
Yeah, I've rebuilt CVs before, I just don't want to do it again. I think I might just call around to see if a shop will rebuild it with OEM boots. If not, I might just get an OEM axle, and see about selling this one.
Old 06-09-2020, 12:03 PM #10
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
If you got 2 years out of that red boot you did good. I know a guy that got 6 months and he's only running 2.5" of lift.
My 4runner still has original OEM boots/axles at 235,000 miles. I did have to put new clamps after lifting. I have over 100,000 miles at ~3" lift on this setup.
It's interesting he said no warranty because the lift, the red boot is an up charge for "higher angle". Makes me think twice about using them when my axles go out.
9808 Archives - CVJ Axles
HIGHER ANGLE INNER BOOT
BOOT RT08 $57.00
Red Silicone Inner Boot
You install it on your OEM axle
Includes adapter ring, grease & clamps
ktom3001 is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 12:23 PM #11
atalarico's Avatar
atalarico's Avatar
BOOT RT08 $57.00
So yeah, the warranty thing irks me for exactly that reason. The way the red silicone is sold, it's specifically for lifted vehicle applications. As in...modified suspension with a lift over factory angles.
I've been using CVJ for the past 10 years or so, and the boots seemed to last pretty long (4+ years) in my 3rd gen. However, I think I'm done now that I realize that OEM boots last for a super long time unless their angle is severely changed when they're older (like when you lift an older truck on the factory CVs). Maybe I'm wrong, but so many new buyers who lift their trucks right away don't have issues with their OEM CV boots, right?
Old 06-09-2020, 12:58 PM #12
montijo505's Avatar
montijo505's Avatar
You can also get a CV from CVJ with OEM boots and return your busted one as a core. I don't know what the price difference would be. The OEM boots are about 60 from eBay, plus labor if you're unwilling to do it yourself.
Just checked and the OEM boot option from CVJ is $200 after you return the core. You could be in that ballpark depending on your mechanics labor cost. Just food for thought.
Old 06-09-2020, 01:14 PM #13
atalarico's Avatar
atalarico's Avatar
Yeah, that was my initial thought, but when I asked the tech there about it he said not to do that. He said the OEM outers were good to use since there isn't a lot of movement on that end, but the inners are bad because there are only 3 something or another's (ribs maybe?) and that they lasted less than a month for someone else, etc.
I also remember seeing something on here about rebuilding a CVJ reman'd axle with the OEM boot kit and running into issues. So, if that's the case, I might call them up and see about just getting the core deposit returned without buying a new one.
Old 06-09-2020, 02:58 PM #14
montijo505's Avatar
montijo505's Avatar
OEM boots on CVJ axles for about a year now. I did the "boot slide mod" where you take off the clamp, slide/stretch the boot and replace with a smooth edge worm clamp. No issues what so ever.
Also its pretty hard to find new OEM cv axles if i remember correctly, did you source them already?
Old 06-09-2020, 03:18 PM #15
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
I'm convinced that's what killed my NAPA boots in 2-3 months, my angles looks similar to yours. I ordered the smooth band worm clamps and am gonna give it a shot.
I might just use all the clamps - I'm rebuilding my OEMs at the moment (messy but easy job), just waiting on the smooth clamps.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
axles , gen , lifted , silicone , years
CVJ Axles rpontbriand 5th gen T4Rs 1 12-11-2018 01:19 AM
CV Axles Tooltime19 4th Gen T4Rs 20 09-07-2016 12:41 PM
cv axles dudes4runner Southwest 1 08-15-2014 08:52 AM
