Old 10-05-2021, 04:10 PM #16
ukrsindicat ukrsindicat is offline
ukrsindicat is on a distinguished road
All this is a good info.
My hatch motor also sometimes quite and just wouldn't pull the hatch into locked position, but also wouldn't release the hatch.
Same time my driver window loses the auto-open/close ability.
And YES, the 30 min disconnected battery reset works and and hatch motor lock works again. But I'm getting tired of having to continuously reseting it and would like to see some more permanent fix.
Is this a sign of rear ECU failing? Do I need to replace it? Any troubleshooting steps?
ukrsindicat is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 07:38 PM #17
jamesbob jamesbob is offline
Real Name: james
jamesbob is on a distinguished road
Real Name: james
hi folks, i am having the same as ukrsindicat above on my 2004 4RunnerSR5. How do we troubleshoot if it is the ECU or the actual motor? would rather not buy both
jamesbob is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 06:29 PM #18
bookooc bookooc is offline
bookooc is on a distinguished road
Originally Posted by BackOff View Post
Ok so...the rear tailgate ecu.
Unplug the bottom right side plug, power.
Plug it back in.
Then hit the key fob, unlock 2 times.
With the tailgate closed.
Wha La now the switch should work, bam!
I had to replace the rear window when the defroster exploded it a couple weeks ago. While putting the window in, the hatch partially engaged the latch. When I tried to open it, the button is dead. Nothing when unlocking the doors. I have to manually reach in with the window all the say down to release the latch.
I checked the connectors, all good.
I am going to try this in the morning, hope it works!
2005 V8 SR5 4WD
bookooc is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 06:40 PM #19
I couldn't wait. This was easy since I left the interior panel off as I am running a camera wire this weekend.
It worked!!!
Thanks so much! This forum is a great resource!
2005 V8 SR5 4WD
Old 03-05-2022, 03:57 PM #20
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
It worked!!!
Something else.
That rear latch seems to get mucked up over the years.
Cheap to replace the mechanism nowadays too... Under $100.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-17-2022, 06:32 PM #21
ccoats38 ccoats38 is offline
ccoats38 is on a distinguished road
Did you figure out what was happening? I am currently having the same problem.
ccoats38 is offline   Reply With QuoteReply With Quote
Old 07-17-2022, 06:33 PM #22
Did you figure out what was going on? I am having the same problem.
Old 08-08-2022, 10:09 PM #23
Hey, brother. Sorry for late reply.
I did figure it out. It was all in the hatch lock assembly. I replaced it and everything worked just fine
Old 08-09-2022, 12:53 PM #24
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Something else.
Dang, that's totally affordable. What is the thing called? I'm looking on Claremont Toyota parts diagram and found options.
This one is called "lock assembly with motor B" for $253
2003 Toyota 4Runner SR-5 Sport Edition 4.7L 4WD Lock assembly, with motor b. Body, door - 6911035090 | Claremont Toyota, Claremont CA
this guy did a great job Stuck open or closed rusty Tailgate Latch fix for 2003-2009 Toyota 4Runner - YouTube
Saw this on eBay and the latch is brand new AND it comes with an emergency latch release rope!!!
Toyota 4Runner Avalon Tailgate Latch power Lock Motor Genuine 69110-35090 | eBay
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 08-09-2022, 04:37 PM #25
MikeinNH67's Avatar
MikeinNH67's Avatar
I bought one of these back in October. Still working as it should and way cheaper.
Amazon.com: Bicos 69110-35090 69110-35062 Rear Tailgate Liftgate Lock Latch Actuator Assembly Compatible with To yota 4Runner 2003-2009 Replacement# 69110-35060 6911035090 : Automotive
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-10-2022, 01:56 PM #26
Thanks amigo, even come with its own emergency release rope!!!
Originally Posted by MikeinNH67 View Post
hatch , motor , power , rear , reset
98 4 runner rear hatch window motor Grauadler 3rd gen T4Rs 2 08-01-2015 05:00 PM
Rear Hatch Motor - Questions MDVDuber 4th Gen T4Rs 3 07-21-2015 02:42 PM
Rear Hatch Motor ChellaBella Classic T4Rs 11 12-23-2014 12:38 PM
Im having a real problem finding a painted grille and rear hatch piece ExJeeper 4th Gen T4Rs 5 11-26-2008 06:59 PM
Rear hatch motor reset? 808BMW 4th Gen T4Rs 2 08-18-2008 09:30 AM
