Originally Posted by 4RunnerAquasport
If the reservoir (overflow tank) is dry it might be a little low. You can also wait until the truck is cooled off for a couple hours and open the radiator cap. Fluid should be right at the neck or at least visible above the fins of the radiator.
Thanks for the help. Can you help me a little more?
I looked in the rad, it’s a little low, not up to the neck , but I can definitely see fluid closer to the top when I flash a light. If I add a new overflow hose, will fluid be drawn from the overflow tank? At that point, I should know if I need to add more fluid? Does my question make sense?
Thanks
J&T
