06-13-2020, 03:35 PM
Leaking Xreas?
Wondering if this is what i think it is? Hopefully the file attaches, but theres a fitting directly under the steering shaft linkage thats leaking what I believe to be hydraulic fluid.
06-13-2020, 03:48 PM
Real Name: Ed
Real Name: Ed
if those lines go the wheels,then yes, it's the XREAS and yes, the system is screwed. Doubt you will want to replace it with another XREAS. Most like replace them with Bilstein 5100s (stiff ride) or KYBs if you want the OEM ride.
Hope this helps
06-13-2020, 05:25 PM
Real Name: Ron
Real Name: Ron
The system gas pressure has probably leaked out too which makes removing it less of a pain. When I removed mine it had no gas pressure, I replaced with Bilstien 4600's and FJ springs, firmer but not harsh.
06-13-2020, 05:40 PM
I have an old 4Runner with Xreas. What happens when these shocks fail? Or leaks the gas.
06-13-2020, 05:49 PM
Yeah, took the wheel off and that soft coated line goes right to the front shock. Unfortunately it has Xreas and bags, so i need to get rear shocks and coils/with the conversion plates.
06-13-2020, 05:56 PM
Real Name: Brett
Real Name: Brett
Start saving and reading up on shocks and springs. The xreas is not worth replacing unfortunately. Most people put aftermarket shocks and springs on and never look back.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
06-13-2020, 06:38 PM
I would not replace them with the same one. But what I mean was, if the gas leaks out or fluid leaks. Is the vehicle dangerous to operate or inoperable? This is all new stuff to me and my 4Runner has started to show its age the last year or so. My brake line failed, alternator failed, power steering leaked, and AHC failed...all within 3 months. Nothing in the first 15 years.
06-13-2020, 06:59 PM
Real Name: Brett
Real Name: Brett
I took it off my 5th gen before it failed, and the 4th gen already had Tacoma bilsteins on when I got it. So I have no experience as far as safety and being inoperable. I would think it has to be an issue to a certain extent. Lemme guess NE rust belt vehicle?
06-13-2020, 07:04 PM
My truck is actually from CT as well. Has 106k on it. I had planned to replace it. Just not so soon. I liked having the bags in the back but ill probably do bilsteins and FJ coils.
06-13-2020, 07:24 PM
We live up in Rochester NY, and I work in Toronto. So lots of snow and salt. Yes.
06-13-2020, 07:52 PM
Real Name: Brett
Real Name: Brett
My family is from Binghamton and I've worked up in Rochester a few times. Love it up there....May through October lol.
06-13-2020, 10:06 PM
With the XREAS failing as a result of fluid loss, then the shocks definitely need to be replaced. Since it is a closed system, replacing XREAS in its entirety is often cost prohibitive (and usually not recommended, even by Toyota mechanics). There are many other cost-effective ways of replacing with standard shock absorbers of your choice (ride comfort, off-roading).
What is Xreas exactly?
xreas - how does it work?
XREAS Replacement
XREAS Replacement Suggestions
The rear air suspension (RAS) is a system separate from XREAS. If it is still functioning properly, there is no need to replace it. It will work just fine with standard shocks. However, if you are upgrading, you can certainly replace the RAS with standard coils.
03 Limited with XREAS and RAS - need advice on replacement options
RAS without XREAS? Help!
How To: Convert RAS to Coils
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
06-14-2020, 09:54 AM
Originally Posted by Bossman
Oh man this is exactly what i needed to hear! My bags are in great shape and work well under loads still. I woke up this morning wondering why i couldnt keep the RAS and just put bils back there and replace the front struts/coils. Im more excited now.
06-20-2020, 01:52 AM
Once it starts failing it’s a slow process. Nothing catastrophic would really happen. It just starts riding like shit and would get worse. Rip it out and throw it in the garbage where it belongs and replace it all with Eibach shocks & springs.
06-20-2020, 11:23 AM
Real Name: Topher
Real Name: Topher
It wouldn't be unsafe or inoperable. Just a more uncomfortable, harsher ride since your suspension is not providing the cushioning and damping it once did when the system was sealed.
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
