Old 06-25-2020, 05:38 PM #16
joshik joshik is offline
joshik will become famous soon enough
I found this on Youtube a while back. Was thinking of doing this but ended up not wanthing a drawer system as I sleep in the back of my 4R all the time and have to haul kids. Looks like a solid design though.
YouTube
I too really like the factory look. I ended up making a flush mount slide out shelf/table system instead so I can sit out the table like a tailgate or cook in the back with the hatch open. I sit my kids on there all the time to clean them up, etc.
I completely ripped out floor to the metal floor, cut out a new subfloor, reused the padding stuff on the old carpet and bolted it down using existing anchor points. I didn't drill through the body at all.
There were boltholes towards the front side just behind the seat that I used.
For the mounting points to the rear, I used a small flat piece of wood, a t-nut and a washer (for extra strength).
This could be a good base to mount stuff on to. You can drill holes into this base where you need them and install tnuts on the underside.
This was my end product
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 10:50 PM #17
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
Originally Posted by NativeRunner View Post
that looks really nice, thanks. could I see the front of the drawers and how they pull out?
The drawer fronts are currently off for an upgrade. This gives a good look at the drawers and how the locking slides can be used as handles.
Boort
Rear Double deck storage system-20200625_152926-1-jpg  Rear Double deck storage system-20200625_152914-1-jpg  Rear Double deck storage system-20200625_152837-1-jpg  Rear Double deck storage system-20200625_152818-1-jpg
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 02:42 PM #18
wiz329 wiz329 is offline
wiz329 is on a distinguished road
Boort
This is great. I saw your posts on the other thread as well. The wings are just a single piece of wood (cut with a band saw I'm assuming?), correct? I saw all of the lines on the drawings, but I'm guessing that's just an artifact?
wiz329 is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 12:46 AM #19
Boort's Avatar
Boort's Avatar
@wiz329
Yes, the base plate and wings was designed as a single piece of plywood. The pattern was traced to the 5' wide piece from the full sized cardboard mockup then cut with a circular saw and jig saw then sanded to final dimension.
The lines you see in my sketchup renderings on the "top wings" and bottom "ears" are the contour measurements to get a tight fit with the side of the 4runner. (https://www.toyota-4runner.org/attac...ormlegsiso-jpg) Since my drawer box was taller ~2" over the wheel wells, the than the plans I needed to make my own curve measurements. since the the profile of the interior of the truck was different than the one at the level in the plans. They are an old boat builders trick to copy complex curves into a 2d plan. The wider spacing was 1" and the narrow spacing was 1/4" IIRC. The 1/4" spacing was needed where the curve around the wheel wells changed too quickly for the 1" and I needed more resolution to avoid just cutting a straight line that would not mate up as well as I would have liked. When in Sketchup I drew a straight reference line then I draw out each line to the measured distance, then connect the end points to draw the curve in the Sketchup model.
As mentioned earlier some of the design changes that I made to the plans from TheAdventureIndex Required that I remove the wings from the base plate that tucked in behind the wheel wells to mate with the tie down points.
Since I made my drawer box a single 2 drawer unit to reduce weight and slightly increase storage space in the drawers as well as increased the height over what was in the plans. These 2 changes required that I remove the wings so that the box could be removed from the truck once assembled.
Boort
-- 2006 4Runner v8
Old 10-20-2020, 09:44 PM #20
@wiz329
Boort
Thanks for the detailed reply. I really like how you made the drawer a single unit and increased the height.
A couple follow-on questions:
(1) What is supporting the wings? Are there vertical supports somewhere? It looks like you have a front panel in your plans, but I didn't see one in the picture (https://www.toyota-4runner.org/3162774-post63.html) you posted (I'm guessing it was just temporarily moved at the time?)
(2) Was the increase 2" height of the drawer box to make the entire platform level when you insert the front panels resting on the front seats? How precise did this have to be?
(3) How did you translate the sketchup designs onto the cardboard template? A projector scaled 1:1 using a ruler on the projection PDF?
If you've got a cut list or any plans that incorporated the modifications you made and wouldn't mind sharing, I could definitely make good use of them. Love the look and functionality of what you put together.
Old 10-21-2020, 12:11 AM #21
Boort's Avatar
Boort's Avatar
@wiz329
Thank you.
It looks like you have a front panel in your plans, but I didn't see one in the picture you posted (I'm guessing it was just temporarily moved at the time?)
The wings (parts that fill in the sides between the top of the box sides of the 4Runner) are fully supported by a 1"x1"x35" hardwood cleat attached to the side of the box. There is another standoff cut to fit the top curve of the Wheel well on the bottom of each wing keep it flat and level. The support cleats also serve as very nice handles when removing the unit.
You can see a couple of circles on the wings in the Sketchup renderings where I had intended to use Euro hinges like in the Original plans. But I decided that I did not want the wings attached. so Now I can just lift them up and get at what ever is stored inside.
Regarding the front panel, It's there, but I cut 2 big rectangular holes in it to lose about 2 lbs and give me more access when tightening screwing the screws for the drawer slides. The box is ~36" deep and there would have been no way to mount the slides after gluing up the box w/o the holes in the front panel. You can see the holes in this rendering and if you look closely in some of the pics of the sleeping platform.
Not considered in my planning. The 2" height increase was, along with many of the other changes to the plans, to ensure that my gear would fit in the drawers. I have a backpack that I've used for nearly 20 years. That I love and take with me all of the time. One drawer needed to be able to hold it fully loaded. The other drawer holds other camping and recovery gear.
The seat bottoms when folded up are about 1/2-3/4" higher than the top of the box. You don't need to be terribly precise. Just make sure that the seat bottoms are tilted further than 90*, so the down weight tries to push them towards the front of the car. You have a lot of adjustment regarding where you position the front seats, which bear against the folded rear seat bottoms. My sleeping platforms are actually about 2" too short! compared to my original plans. If you are taller than 6" I think you could make them up to 5-6" longer to give you more headroom. I think I get about 73-74" which is just enough for my 6' to fully lay down. Since I had enough room, I did not want to go and buy another sheet of plywood for that 2" so I just move the front seat back to position the rear seat bottom where it needs to be to support the weight.
Nope, just printed full scale and taped the pages together. It can be a pain in the a$$ to get right due to how Sketchup prints. Here is a good video on the process that I used:
Full Scale 1:1 Printing from SketchUp | Multi-page output - YouTube
One thing that I did, that was not in the video was to draw a few squares that were across the places where sketchup was going to split the page. That way I could measure each square and ensure the tape up job was correct and I did not add any skew or taper between the pages. This is overkill for the wings but old habits die hard. I also cheated a bit since I still had the cardboard templates with those line measurements discussed earlier, that were used to create the Sketchup model. So I was able to pull them out and verify the curves in the plan were good. This is only really an issue if you were going to CNC the parts. Since my local makerspace closed up shop I no longer have access to a 4x8 cnc router :'( . If you are cutting by hand it's really a matter of cut outside the line then sand to fit. Since I carpeted the wings and box there is a ~1/8"- 1/4" of room for error before anything gets noticed.
I likely still have the sketchup model as it exists in the renders above. I've not updated it to how I actually built it. I'd be happy to share the SKP file but before I do, I'd like the Ok from Adam ( @bagelsjustbagels ) since my design was based so heavily on his work and parts list.
Boort
-- 2006 4Runner v8
Old 10-25-2020, 03:02 PM #22
@Boort
I likely still have the sketchup model as it exists in the renders above. I've not updated it to how I actually built it. I'd be happy to share the SKP file but before I do, I'd like the Ok from Adam (@bagelsjustbagels) since my design was based so heavily on his work and parts list.
Boort
Thanks much, appreciate it. Have you noticed any sleeping discomfort from the sleeping panels not being 100% level with the top of the drawers? Or would there be any downside you could foresee from making the drawers an extra 0.5" or so to bring everything closer to being level?
Also, if you've got any further pictures of the new drawer fronts, would love to see those as well.
Old 10-25-2020, 04:12 PM #23
Boort's Avatar
Boort's Avatar
@Boort
@wiz329
No sleeping discomfort. The small difference is no big deal as the change is spread out over ~35". I sleep on top of my Klymit backpacking mattress so it's absorbed even further. When camping I'm seldom able to find a place where my truck is parked level. Generally even when I stack rocks under the low tires I'm more than 1/2" out of level front to back, side to side, or Both.
At any height it can be hard to move about on top so for me every 1/2" is welcomed. So far I've only used the sleeping platform solo. It's possible to sleep 2 on this setup. But you'll need to be traveling light. I generally put all of my gear in the passenger seat and on the 40% side then sleep on the 60% side. I'll leave the small back seat set up so I have more room to swing my legs out and into my boots. Make sure you have easy access to your key fob to unlock the doors, before opening a door, so the fn horn does not go off. (Not sure if this is a standard "feature" on 4th gens or part of the Dealer addon Security system that is installed on mine. IIRC the horn does NOT stop beeping until you START the fn truck!) It was not fun to learn that it rearms itself when unlocked, with you inside, while camping in Ouray during FJ Summit! Very few things ruin a morning of camping than being the dude who wakes up everyone in the backcountry with your car horn going off.
Sorry no new pics of the updated drawer fronts. I've had limited access to the shop tools due to the current situation so all of my updates have been on paper and trying things out in Sketchup. The fronts from the plan and the little side "block offs" are sitting in the garage waiting for me to decide just what I want to do exactly.
The good news is I took the time to update the SKP to the current setup. Including the updates we've discussed on this and other threads.
Boort
-- 2006 4Runner v8
Old 10-25-2020, 04:32 PM #24
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
@wiz329
Boort
I'm just replying to edit part of the quote above, I put a space between Adam's user's name and the parentheses so it mentions him properly, without the spaces it doesn't notify him that he was "mentioned" and thusly he will miss your post.
2004 Limited V8
Old 10-25-2020, 05:12 PM #25
@Boort
Thanks. How thick is your mattress? I was thinking about getting a [foldable] memory foam mattress to put on top of the platform, likely 6-8" or so. Too cramped?
Old 10-25-2020, 05:13 PM #26
How do you properly tag people? I had to manually look up the profile ID in my response above. I imagine there's a much more efficient way of doing this.
Old 10-25-2020, 05:43 PM #27
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Put an @ in front of the username.
@wiz329
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 05:54 PM #28
Boort's Avatar
Boort's Avatar
@Boort
My mat is about 3" when inflated. It is the older version of this one ( Klymit Static V Luxe Ultralight Camping Sleeping Pad - Klymit )
Yes I think that 6-8" would be overkill. An 8" mattress would put you at the same level as the bottom of the rear window. This would would leave very little room on top. Also a memory foam mattresses of that size would be very heavy. The full platform is roughly a queen size so you'd be talking about 80-100 lbs for the 8" mattress, maybe more. I know my memory foam mattress at home is way more bulk and weight than I'd like to deal with on the trail.
In the A-frame camper I have 4" mattresses made from 2" high density eggcrate foam, topped with 2" memory foam that I cut from a king bed topper. They are comfortable and the eggcreate helped to lighten the mattress over using all memory foam.
Boort
-- 2006 4Runner v8
Old 10-25-2020, 06:00 PM #29
Boort's Avatar
Boort's Avatar
Thanks @AuSeeker
I fixed it in my original post as well.
Boort
-- 2006 4Runner v8
Old 12-29-2022, 11:46 PM #30
blackjackck's Avatar
blackjackck blackjackck is offline
Real Name: John
blackjackck will become famous soon enough
Real Name: John
Originally Posted by BoostinZX View Post
I didn't build them. Bought them used from a 5th gen owner and just painted them to clean them up, they ended up fitting perfectly under my rear deck lid. Its such a tight fit that the deck lid holds them in place pretty much.
It measures 41" wide x 30" long x 9 1/4" tall.
This looks great, I have 2 questions:
1) could tell but does the sides fit snugly against the wheel well?
2) you mentioned that the Double Decker fits right on top of the shelf, you would you say that its now strong enough to sleep on top of the double decker if you build something to go over the 2nd row and extend from the double decker shelf?
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is offline   Reply With QuoteReply With Quote
cargo , drawers , rear , system , tray
Double deck/non-double difference in Cargo Liners? Okie 4th Gen T4Rs 8 05-31-2018 05:44 PM
Removed Double Deck Cargo System markt 4th Gen T4Rs 0 05-09-2015 05:08 PM
FS(VA)- Double-decker storage tray(gray) system with trim panels(out of 200*) Cutlr7 For Sale: T4R Items 1 03-25-2014 11:41 AM
FS: 4th gen 2003-2009 cargo mat (with double deck system) txt4r For Sale: T4R Items 0 02-06-2012 10:58 PM
