Old 06-17-2020, 03:50 PM #1
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Power steering gone after pump and rack replacement
I have followed the procedures of moving the rack back and forth from near lock to lock for around 5 minutes straight with the tires off of the ground. I have tried doing this with the vehicle on as well.
After replacing the rack with a remaned unit from the rack doctor I have not had power steering. I have cleaned the reservoir and it is spotless.
I am using the correct DexIII ATF as the fluid.
Anyone have any guesses?
royal T4R is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 04:31 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
Do you see fluid returning to the reservoir? You may want to try calling Rackdoctor for advice. I've never had an issue with these. Any chance you have the hard lines mixed up?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 06-17-2020, 04:58 PM #3
Hard lines aren’t mixed up and I see the atf weeping out of the return line when I move the wheel. How forceful should it actually be?
Old 06-17-2020, 05:08 PM #4
Real Name: Skip
Real Name: Skip
Did you get an OEM pump or aftermarket?
It sounds like the pump isn't producing pressure.
2004 Limited V8
Old 06-17-2020, 05:20 PM #5
It’s an aftermarket remanufactured pump. The OEM pump did the same thing and that’s why I replaced the pump.
Old 06-17-2020, 05:26 PM #6
Real Name: Skip
Real Name: Skip
You say you clean the reservoir, so the original reservoir was used on both pumps?
Ask because there's a screen in the bottom of the reservoir and if it's clogged it could be greatly reducing or blocking fluid from getting into the pump.
2004 Limited V8
Old 06-17-2020, 05:34 PM #7
The reservoir was cleaned prior to the new pump install. I can see there is no blockage in the reservoir.
Old 06-17-2020, 05:55 PM #8
Real Name: Skip
Real Name: Skip
Well if indeed the pump is producing pressure and since you say there fluid "weeping" out of the return line it would seem that there's a blockage in the rack, I would as was suggested contact Rack Doctor and explain your issue, I know that they are highly recommended and reviews are great on their products, I have never read of a bad review, so I would think they would want to do whatever is needed to make things right if it's indeed an issue with the rack.
2004 Limited V8
Old 06-17-2020, 06:27 PM #9
Just spent the past hour doing the bleeding procedure again to no avail. Ive tried contacting RackDoctor last week about shipping my old unit back and they havent responded back.
Old 06-18-2020, 04:52 PM #10
MikeinNH67's Avatar
MikeinNH67's Avatar
The fluid should flow out at a steady rate when not touching the wheel as it bypasses internally in the rack. Should be enough to see movement in the reservoir. Try calling Rackdoctor to see what he thinks but if you had this issue beforehand then you may need to disconnect the lines and try blowing compressed air through them. Sounds like you have a blocked or collapsed line. Do these things have power steering coolers on them?
Number is at the bottom of the FAQ link:
Commonly Asked Questions
Mike
03 4runner Limited
Old 06-19-2020, 07:40 PM #11
Got a new rack coming in from them. I’ll run some compressed air through it and see what comes out.
I do not see a ps cooler and as mentioned earlier I do see fluid flowing in the reservoir when not touching the wheel.
dexiii , lock , power , rack , steering
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Power steering pump replacement 97 4runner Viking 3rd gen T4Rs 2 12-14-2014 12:23 AM
Power steering pump replacement Fiddynut 3rd gen T4Rs 3 08-19-2014 12:05 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
power steering pump replacement jlfindley74 Classic T4Rs 0 12-28-2008 04:06 PM
