Old 06-18-2020, 02:12 PM #1
SeaTowner221 SeaTowner221 is offline
SeaTowner221 is on a distinguished road
Appreciate help picking a Tire for my 3" lift 4th Gen
Hi all,
I would appreciate any thoughts/experiences with the following tires on your 4Runners. I have a 2008 SR5 V6 and I am soon receiving my OME 885/895 2.5-3" lift and need a new tire to go with it!
My goal is: C rated 32(ish) inch tire that will fit in the stock spare location (normal v6 hitch).
Right now my top choices are:
255/75/17 K02 (C Load) -- (the most expensive and least aggressive option).
255/75/17 Grabber X3 (C Load) -- (Never owned a MT, but I have heard good things about the X3 and the XO team is moving to them).
275/70/17 Falken AT3W (C Load) -- (Really like the look of these, but worried about rubbing and fit in the spare location. Also heard they are hard to balance).
If you have any experience with the above tires, or have suggestions for an OME lifted truck, I am all ears! Appreciate any feedback folks are willing to share.
Cheers!
SeaTowner221 is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 02:49 PM #2
Fl_tigers's Avatar
Fl_tigers Fl_tigers is offline
Real Name: Nick
Fl_tigers is on a distinguished road
Fl_tigers's Avatar
Real Name: Nick
I have run Falken AT3W for over 40,000 miles so far and have not had a single issue balancing them. I had them installed at discount and they rebalance every 5000 miles. Never very far out if at all when I go back in.
Originally Posted by SeaTowner221 View Post
Hi all,
Cheers!
Fl_tigers is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 03:24 PM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
You can’t go wrong with the ko2 tires. They’re a best seller at tire rack, and there’s a short video about them on the tire rack website.
Mud tires aren’t designed to be used every day on pavement. They’ll be loud, and wear out faster than AT tires.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 05:53 PM #4
montijo505's Avatar
montijo505's Avatar
I have AT3W's right now in 285/70R17. I like them because they are quiet and are wearing great. I will likely get some cooper STMAXX's next round. Hear great things about them also
Sent from my SM-G986U using Tapatalk
Old 06-18-2020, 09:53 PM #5
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
Hi all,
Cheers!
K02's are the best way to go in my opinion. They've never let me down. Road noise is barely noticeable, overall great traction, plus they look great - I love them! My experience has been with E load, but that doesn't change too much in this aspect
Also on lift suggestions - at 3", I think it's definitely worth investing in some high caster UCA's to help with the alignment (if you haven't already).
I also suggest some spacers or new wheels with a decent amount of backspacing, but that's personal preference because a skinny stance with a 3" lift just looks kinda weird to me. If you think it looks ok though, save the money and don't get them
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 11:47 PM #6
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
Have you looked into 255/80/17's. Just push the fender liner foreward and you're gtg. They'll fit aired down in the spare tire location.
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 12:03 AM #7
Alainzen Alainzen is offline
Real Name: Alain
Alainzen is on a distinguished road
Real Name: Alain
Falken Wildpeak ATW3 265/70-17 AKA 32" x 10.5" mounted on 5th Gen OEM Toyota wheels so 15 mm offset instead of the original 30 mm which caused rubbing on the upper control arm. I have a full size spare tire too, no issues.
I was looking at Method and aftermarket wheels to fit my Toytec / Bilstein 3" lift kit, something to keep my rig on the narrow side, but I could not find anything. Moreover, the 5th GEN Toyota 4runner rims look good, are cheap, replacements are easy to find, and fit without a lug nuts kit.
I did some serious off-roading in the Eastern Sierras and cut a tire wall... Discount Tire put a new one without questions for about $25
Alainzen is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 02:10 AM #8
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
lower positive offset means the wheel is sticking out further from the UCA. How did that cause rubbing? It doesnt make sense.
07 SE V6, Front: Dobinsons LT GS59-220 + C59-302 w/ ICON UCAs;
Rear: GS59-575 + C59-677V w/ ICON Trailing Arms; PCK;
Coastal-Offroad bumper and sliders; ASFIR aluminum skids;
255/80r17 Falken AT3W on Toyota Trail edition wheels;
andreylights is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 08:51 AM #9
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Smile
I’ll also vouch for the 255/80/17s. I’m running toyo open country AT2s with a 3” lift and love them. I’ve even gotten the spare to fit fully inflated
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 09:16 AM #10
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Another vote for the AT3W's. They are quieter, lighter, and better on wet pavement than a KO2. For all of that you give up a very small amount of durability you won't notice unless you are doing crazy rock crawling.
Size wise the 275 size you picked will definitely fit, and the spare will be just a hare thicker. That said, my vote would be on a 255. Tall skinnys just work well with our rigs.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 09:24 AM #11
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Sticking out further from the UCA means it swings outward further and can rub the body mount, fender, or frame. However, not enough offset it can rub the UCA when turning or the spindle preventing you from mounting the wheel.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 10:25 PM #12
Real Name: Alain
Real Name: Alain
I went from 30 to 15 positive. The 07 4runner OEM 30mm offset wheels with the 265/70-17 were rubbing on the OEM upper control arm. Not sure why but I had rubbing marks to prove it.
Swap to +15 offset = problems solved without ruining my ride
Old 06-20-2020, 02:03 AM #13
I see, I guess I misread your post.
fit , load , location , spare , tire
FS: DFW, TX 96-02 4runner swingout tire rack for 35" tire and hi-lift jack 240m3srt 3rd gen T4Rs 2 07-14-2014 01:45 PM
3" OME lift + FJ 17" Rims = What Tire? mycrobyte 4th Gen T4Rs 1 03-29-2012 09:12 PM
"Best" tire size after lift/leveling kit install? NAdams65 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 07-05-2010 09:38 AM
I need help picking out a size and winter tire! *AK2006* Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-01-2006 04:10 PM
