Old 06-22-2020, 12:16 AM #1
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
broken LCA cam bolt, now dash lights are on...
in my struggle to get 35s onto my 4Runner, my latest issue is that 3/4 cam bolts are seized and won't budge. so I PB-Blasted the crap out of them and let it sit for a few days. one started to turn, so I gave it a good knock with a mallet and wouldn't you know, it all started turning...in place...pushing the cam bolt over the bent part that keeps it in place...
anyways, not a big deal as I had already ordered and received new LCAs with the plan of cutting these old ones out.
so I tightened it back up best I could because I needed to drive my truck. but when I went to drive it, the dash is lit up with traction control lights.
is that because the alignment is jacked since one of the bolts basically won't hold the arm in place? will that all be ok once the new arms and cam bolts are in?
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 12:56 AM #2
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
No clue on your dash lights but if you need a set of OEM LCA cam bolts send me a PM.
royal T4R is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 02:13 AM #3
Jayson44's Avatar
Jayson44's Avatar
thanks, but I ordered the SPCs with the sleeve.
J.
Old 06-22-2020, 04:05 AM #4
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Are you sure you didn't damage the speed sensor or the harness to it while you were fighting with the bolts?
importman is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 07:15 AM #5
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
On my first set of LCA's I stretched the thin speed sensor wires. Try a zero-point calibration then inspect/repair/replace your speed sensor wires.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 10:14 AM #6
Jayson44's Avatar
Jayson44's Avatar
I don't think I touched the wires as all I was doing was trying to loosen the bolts on the LCAs. but I'll definitely check them out.
J.
Old 06-22-2020, 10:19 AM #7
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
If it messed up the alignment so much the steering wheel is real crooked when driving straight, it'll turn on a bunch of dash lights from the steering wheel position sensor.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 11:30 AM #8
Jayson44's Avatar
Jayson44's Avatar
bingo! I forgot to mention that the steering wheel was off a couple inches now.
good to know. got my arms yesterday, so I'll attempt the install this weekend.
J.
Old 06-22-2020, 06:17 PM #9
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
I may need a set of OEM LCA Cam Bolts you have all 4 bolts for sale? im in Canada
2005 4R LIMITED V8
FALKEN WILDPEAK AT3W&TRD RIMS
DOBINSONS SUSPENSION 2.5" F 2" R / JBA UCA / POLY PERFORMANCE TACO TAB/ 2ND GEN REAR LINKS
VOLANT CAI/ RA MOTORSPORTS SKID & DITCH LIGHT MOUNT
MAGNAFLOW MUFFLER
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 01:55 PM #10
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
J.
If your alignment is really f***ed, yes - your dash lights will all come on. It happened to me when I hit a rock really hard and knocked my alignment out on the trail. Went to Firestone for my free alignment and all lights went bye-bye!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 11-04-2021, 10:14 AM #11
Cherbear1731 Cherbear1731 is offline
Cherbear1731 is on a distinguished road
I have a question about my LCA cam bolts. Can you help me out?
Cherbear1731 is offline   Reply With QuoteReply With Quote
bolts , cam , drive , place , started
How bad? Broken lbj bolt. TinBucket 3rd gen T4Rs 6 05-15-2017 05:06 PM
broken bolt johnwoo 3rd gen T4Rs 3 10-02-2014 09:58 PM
Broken bolt removal yota-runner General Discussions 5 09-29-2013 11:10 PM
Broken fender bolt mcaz5 3rd gen T4Rs 9 07-25-2013 03:52 AM
Lug bolt broken on a new 07 w only 1K miles tempusage03 Problems & Warranty Issues 8 11-17-2007 12:43 AM
