Old 06-22-2020, 02:32 PM #1
T4R416 T4R416 is offline
T4R416 will become famous soon enough
All original suspension need refresh!
Hey there so I just want to dot my i’s and cross my t’s here I am getting new upper spc control arms most likely, unless you guys got a better recommendation..?? I was also thinking why not refresh the rest of the old tired suspension and bushings?? What would you guys and girls do as far as replacing suspension mostly from front but of course rear is not to be neglected!! What about sway bar bushings , links? Etc!! Thanks for the help guys!!! 2004 T4R SR5 290000 km!
T4R416 is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 02:44 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I did LCA bushings and made this tutorial here: Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures). After 210k miles (338k km), they weren't really bad, but I figured they needed a refresh. Cams were also seized, so this solved that. Pretty labor intensive, but overall not to difficult. I've only driven like 16 miles on them stuck at home, so can't comment on the ride quite yet. Going on a 240 miles trip this weekend, so I'll have a better idea after then/
All original suspension need refresh! All original suspension need refresh! All original suspension need refresh!
I haven't replaced any sway bar hardware, but I think the bushings and links are pretty inexpensive. I've heard if the links failt, they can fall and damage the CV boots, so might as well replace while down there.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 11:37 AM #3
Looks good to me! Heard of white line before back when I had an 05 xrs and was looking at sway bars ..!! So LCA BUSHINGS AND LINKS... check ! Anyone else ?
Old 06-23-2020, 11:36 PM #4
Epic Ed's Avatar
Epic Ed Epic Ed is offline
Epic Ed will become famous soon enough
Epic Ed's Avatar
Going through this right now. 2007 'Runner with 230K on the OD. My LCA bushings were squeaking loudly on dirt roads - they're shot. The XREAS system is leaking all over the place. I decided to go with aftermarket and do a lift instead of replacing the XREAS, so that lead me down the rabbit hole that comes with lifting it.
I went with Fox 2.5 coil-overs up front with Camburg UCAs; replaced the LCAs and lower balls joints. Sway bar will need to be done soon. CV joints are both seeping and will need to be done, especially after the lift. For the rear, I went with OME (895s) springs and Fox 2.0 shocks.
I'm not doing the work - I don't have the time or patience - but it was supposed to be done today. The cam adjustment bolts were seized so they had to torch them off (see "don't have the time or patience" reference). New bolts will be in tomorrow morning. Hopefully it will be ready to send over to the shop for alignment before noon.
2007 Toyota 4Runner | Sport Edition | 4WD | Fox 2.5 front | Fox 2.0/OME rear springs | Camburg UCAs | 285/70/17 Bridgestone Dueler Revo 3s on TRD Pro wheels | Westcott Designs Sliders | BD S8 30" light bar | Rigid 10" with C4 bracket in hood scoop | BD Squadron Sport ditch lights
Epic Ed is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 01:32 PM #5
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
From everything I read, stay away from cheap LCA's. I found Toyota LCA's for less than $600 shipped and didn't mind since I had 290k on the originals. UCA's I used 20k takeoffs for $100 delivered from a 17 TRD pro and got all new OEM hardware, wasn't cheap, but was only thing left of my suspension that hadn't been replaced. In a few years when my tires are getting replaced/larger I'll look into good UCA's then. Tires stopped rubbing when I got TRD wheels with different offset.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 11:08 AM #6
Sounds good to me so far!!! Any other recommendations???? Thank you guys !!
Old 07-09-2020, 08:51 PM #7
mjg514 mjg514 is offline
Real Name: Matt
mjg514 will become famous soon enough
Real Name: Matt
i just did suspension upgrade on my 2007. along with the new front/rear shocks/springs, i also went with new SPC UCA's. the only other things i changed out were new top mounts for the front struts, and new sway bar bushings. i also just ordered a new set of engine splash guards since the original factory ones disintegrated when taking them off to install the UCA's.
mjg514 is offline   Reply With QuoteReply With Quote
bushings , guys , refresh , replacing , suspension
Suspension refresh kit? dcTR4 4th Gen T4Rs 6 11-28-2018 02:22 PM
Best value suspension refresh for on road use? TFin04 3rd gen T4Rs 21 06-30-2018 05:00 PM
suspension refresh: more confused than ever mhenks05 4th Gen T4Rs 10 01-30-2018 09:08 AM
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
Front suspension refresh radlynx 4th Gen T4Rs 2 03-03-2017 04:20 PM
