Old 06-27-2020, 12:28 PM #1
zu13 zu13 is offline
zu13 is on a distinguished road
Fix for error code P0113 P0102
Hello all, I just got my first OBDII scanner and tried it on my new to me 4runner it is throwing 2 codes and I want to make sure that I fix them properly. As far as I can tell the truck is running fine and I dont hear or see any issues.
Once I have replaced the necessary parts will the code go away or how do I clear it out?
New Kid - 2008 4Runner Limited (Salsa Red) V8, 135,000, HCAF Removal.
Sold in 2013 - 2007 4Runner Sport Edition V8, Black on Black on Black, 80,000 miles, Westin Brush Guard, 2 Harbor Freight Off Road Spot Lights, Bilstein 5100 (1.75)/ FJ coils, Yakima Roof Rack with 4 Harbor Freight Off Road Surrounding Lights, Plasti Dipped Emblems and wheels (silver hub caps with black accents), Westin Step Rails, Hyrdo Carbon Air Filter Removal.
zu13 is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 02:09 PM #2
OzarkRunner's Avatar
OzarkRunner OzarkRunner is offline
OzarkRunner is on a distinguished road
If your scanner doesn't have the ability to clear codes, you can just remove the negative cable from the battery for ~20 minutes to reset. Otherwise, the ECM will clear the code on it's own at some point.
2008 Sport / V8 / Bright Silver FN FX Pro / 255/75 Duractracs / Fox 2.5" Factory Front Coilovers / JBA / Superpro / Fox 2.0" Rear / Wheeler's T12 / Limited Grill / Rigid Duallys / Flowmaster 70 Series / ScanGaugeII on Blendmount / 5k LEDs / Homelink Upgrade
OzarkRunner is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 04:42 PM #3
Awesome thank you ill read through the manual and see if it has that feature. Any clue how to fix those error codes?
Old 06-30-2020, 07:30 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
P0113 - MAF high voltage?
MAF Cleaning now have DTC's
I desperately need a picture of a v8 MAF plug wiring picture
CEL Code P0101 MAF Sensor
P0102, P0430, P0420 error codes
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 06:32 PM #5
03v84Running 03v84Running is offline
03v84Running is on a distinguished road
@Bossman I have seen you update many threads with search results pertaining to the issue at hand which is much appreciated! I have also attempted to use the search function on this site and honestly find better results when I use google. Soooo any suggestions/tips you have to use the search function here and get the results your looking for?
03v84Running is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 06:57 PM #6
Bossman's Avatar
Bossman's Avatar
Thanks for the appreciation
Truth be told, I also use "external" Google to search out the relevant previous threads located here on T4R.org. The key is to specify the year or generation of 4runner that the issue pertains to. I have tried to use the internal search function, but Google seems to work so much better for me.
How To Search T4R (far more accurately than standard method)
Alternate Search for T4R - 4th Gen Section
code , fine , fix , hear , running
error code p0430 kevinnem 4th Gen T4Rs 7 11-12-2016 02:47 PM
CEL / Error Code ... what do to? OrbeaRider 4th Gen T4Rs 5 05-29-2009 02:52 PM
CEL error code 71 MichiganFan82 Problems & Warranty Issues 0 02-20-2008 01:31 PM
P0102, P0430, P0420 error codes a77boy Problems & Warranty Issues 3 03-09-2007 06:27 PM
error code help!!! jamesek9 3rd gen T4Rs 2 03-29-2006 11:42 PM
