Old 06-27-2020, 02:30 PM #1
drace51 drace51 is offline
drace51 is on a distinguished road
08 limited 4.7L not charging
Replaced alt due to alt noise and not charging ( not from the P/S pump) Also replaced Battery due to age and very low CCA and volts. Apon replacement of said parts, KOEO noticed No bat light on instrment cluster ( I did not notice opperation of Bat light (on or off) light prior to parts replacement . Voltage are as follows,KOEO, 3 wire conector W12.3v,GR 7.5v, Y-R 12.3v Main bat lead 12.3v . All 4 fuses are good , 140amp fuse,50 amp,7.5 gauge fuse , 15amp IG1 fuse. I did not check for a voltage drop between the 7.5 amp fuse and the combination meter as of yet and or the body ECU. any help would be great
drace51 is offline   Reply With QuoteReply With Quote
bat , fuse , light , parts , voltage
Solar charging? yotaguy674 General Discussions 14 07-05-2020 08:07 PM
Charging AGM batteries tigger 5th gen T4Rs 13 04-11-2016 06:44 AM
Battery not charging hondarcb 4th Gen T4Rs 3 03-29-2015 08:41 PM
Not charging help please!!! Kandee_man Classic T4Rs 8 10-18-2010 06:48 AM
Charging system help.. AlPalusky Classic T4Rs 2 07-30-2007 11:54 AM
