Old 06-27-2020, 11:56 PM #1
philipalberti_'s Avatar
philipalberti_ philipalberti_ is offline
philipalberti_ is on a distinguished road
Front suspension "loose change" noise
Hey all. My front suspension has a loose change noise when driving below 30mph. Sounds just like a bad ball joint except, I have TC UCA and LCA with uniballs and no sway bar. My CV axle boots have been torn for a year ish and I'm thinking they might be the issue. Also have Kings 2.5 ext coilovers cranked to about 2.5 ish inches of lift. Any ideas on what might fix it would be appreciated.
05 limited 4runner 4x4 Philip Alberti's 05 4Runner Build
philipalberti_ is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 12:51 AM #2
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
This may sound silly, but I had the same issue and it turned out to be that shiny piece of metal that fits over the outer CV castle nut. My cotter pin wasnt large enough to keep it secured.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 02:52 PM #3
Not silly at all. I appreciate the idea, but everything in there seemed secure with no play :/
Old 06-28-2020, 06:20 PM #4
4Climber's Avatar
4Climber 4Climber is offline
Real Name: N/A
4Climber is on a distinguished road
4Climber's Avatar
Real Name: N/A
I have the same noise, I couldn't figure out what it is yet but I'll give your suggestion a try.
4Climber is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 12:54 PM #5
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Are you sure it's coming from the front? I had what I would consider a loose change noise over bumps, but it was from the star key/emergency brake adjuster in the rear. I took it off and took it apart, pumped grease in there and put it back together and adjusted appropriately, no more noise!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 02:39 AM #6
Yeah I'm sure it's coming from the front. I try to listen and figure out every noise that appears and this one I can't get. I've been told it's my CV axles because they're ripped and have been for the past 2 years :/ but I'm gonna change them in the next month or two.
Old 07-06-2020, 10:05 AM #7
Bernardchan96 Bernardchan96 is offline
Real Name: Bernard Chan
Bernardchan96 is on a distinguished road
Dude i had the same exact noise, sounded like loose change or two washers kinda clinking against each other over bumps. i tried replacing the Sway bar bushings and everything. Turns out my UCA boot was leaking replaced them with JBA and it was fine.
2005 4R LIMITED V8
FALKEN WILDPEAK AT3W&TRD RIMS
DOBINSONS SUSPENSION 2.5" F 2" R / JBA UCA / POLY PERFORMANCE TACO TAB/ 2ND GEN REAR LINKS
VOLANT CAI/ RA MOTORSPORTS SKID & DITCH LIGHT MOUNT
MAGNAFLOW MUFFLER
Bernardchan96 is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 03:51 PM #8
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
I just did my passenger wheel hub today and that fixed 90% of my clunking. I just need sway bar bushings and I think I'll be quiet. I was sure to get that cotter pin tight on the castle nut though. Sounded like a jar with a few nickles when going through parking garages slowly.
gaber6 is offline   Reply With QuoteReply With Quote
change , front , ish , noise , suspension
Front End "Feels Loose" dmccarthy 4th Gen T4Rs 5 06-29-2016 02:15 PM
"knocking" sound after suspension change jdkilroy 4th Gen T4Rs 8 04-02-2016 08:29 AM
Front End "Clunk" and (separate) Steering Noise thirstyturtle 3rd gen T4Rs 10 06-01-2014 06:28 PM
What could cause a "squeak/creek" noise in the front end? maxspeed96ct Classifieds - buy & sell (no commercial ads please) 2 05-03-2011 10:23 AM
metal "clank" noise from front suspension? V8Limited4wd 4th Gen T4Rs 2 04-20-2006 08:20 PM
