Old 06-28-2020, 10:48 PM #1
luke87gt's Avatar
luke87gt luke87gt is offline
luke87gt is on a distinguished road
luke87gt's Avatar
Brake Job Didn’t Go As Expected
Whoops, accidentally posted this in the 5th gen forum. Mods can you help move here? Thank you.
https://www.toyota-4runner.org/5th-g...-expected.html
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
luke87gt is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 12:41 AM #2
montijo505's Avatar
montijo505's Avatar
Give 'er a good whack with a small sledge lol. I have a 3lb sledge that has never let me down. Got it for about $20 at Lowe's. Worth it.
Sent from my SM-G986U using Tapatalk
Old 06-29-2020, 11:52 AM #3
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
This. And re-install with anti-seize after cleaning it up lol.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 11:58 AM #4
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Have you tried threading 2 bolts into the jacking locations on the rotor and using those to push the rotor off? I had to do that for both of mine and it basically destroyed some of the parking brake parts but a rebuild kit was in stock at a local parts store and fairly cheap.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 01:02 PM #5
SumoRerun SumoRerun is offline
SumoRerun is on a distinguished road
I'll probably be hung, drawn, and quartered for this, but I'm a huge fan of eliminating the parking brake. Living in the rust belt, it gets expensive real quick to start fixing parking brake cables and whatnot.
SumoRerun is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 03:21 PM #6
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
If there is a hole there you should still be able to rotate it until they line up.
unlikely that anyone would buy/install a rotor that isn't designed for the vehicle.
But +1 for the 3lb maul and another for eliminating the P brake altogether..
It took me a good hour at least to beat my old rears off and after installing everything new I just left it loose since they commonly sieze. Plus, I've never had an issue with the brakes not holding enough on some pretty steep incline park jobs.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 08:56 PM #7
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
3lb usually gets it off...
but there was this one time broke the entire brake disc off leaving the center hat of the rotor still fused to the Hub!
I cut the rotor right down the center but not right thru where the hub was and split it with a cold chisel. Rotor came off in 3 pieces.
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
5th , brake , forum , mods , move
Brake Job Didn’t Go As Expected luke87gt 5th gen T4Rs 16 06-29-2020 12:41 PM
Not what i would have expected Ruiner 3rd gen T4Rs 23 04-17-2015 10:09 AM
seafoaming didn't go as expected newmexrunner Maintenance/Detailing 1 07-09-2012 02:40 PM
New to the forums, I have a brake question I didn't see answered in a sticky thread.. BlackCat914 3rd gen T4Rs 10 07-06-2012 10:41 PM
AC not as cold as expected machinewars 4th Gen T4Rs 35 06-29-2010 07:50 PM
