Old 06-29-2020, 03:35 PM #1
Renol Renol is offline
Renol is on a distinguished road
Rear bilstein 5100 install issues
Working on installing these in the rear but the top stud is too short. I just managed to get one nut threaded, but the other side is so short that the top of the stud doesn't clear the washer even with the shock fully compressed. Anyone else have this issue? I'm about ready to bring it in and just get a different brand shock.
Renol is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 05:24 PM #2
newton22 newton22 is offline
newton22 will become famous soon enough
So you jacked up the axle and it's still too short? I had no issues once I jacked up thr axle. Are you running big lift springs?
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 05:43 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yes, to the above and if you have the correct P/N for your application then it doesn't matter who's shock you use they should all be same.
Old 06-29-2020, 08:25 PM #4
Maybe I did get the wrong number, its the only thing I can think of. I had checked it before but mistakes can happen I guess.
Edit
Double checked bilstein website for part # and they match the ones I got off amazon. I had to temporarily reuse an old bushing just to get the car driveable.
Old 06-30-2020, 03:26 PM #5
PedroV PedroV is offline
PedroV is on a distinguished road
Edit
I was unable to use the "new" rubber grommets that go on top of the shock, along with the new washer. I ended up having to use the original grommet and the new washer, which worked fine. I would have loved to put some new rubber in there, but it just was too thick and didn't work. I don't notice any issues with it.
PedroV is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 10:44 PM #6
RobD RobD is offline
RobD will become famous soon enough RobD will become famous soon enough
Edit
I had to use needle nose Vise Grips to clamp the rubber bushings enough to start the threads on my 5160s. I got enough compression to get a few threads started.
RobD is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 08:05 AM #7
Derekv Derekv is offline
Derekv is on a distinguished road
Did you remove a tacked on washer from the underside of the shock mount?
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 05:01 PM #8
Apparently one washer came off along with the shock (driver's side) which is why I was able to get that one started. I noticed one on the pax side but didn't think anything of it. How essential is that washer?
Old 07-03-2020, 08:43 AM #9
Remove them. for sure.
Derek V
Old 09-21-2020, 03:37 PM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Yesterday, I had the same problem with there not being enough thread on the shock bolts showing to install my 5100 rear shocks and Toytec 2” lift springs. I even jacked up the axle (one side at a time), but the lower bushings didn’t compress enough to get the bolts to stick out.
Thanks to this forum, I knew to look for the washers stuck to the bottoms of the top shock mounts. Earlier today, I was able to pry the washers off and get the nuts onto both rear shocks. Years ago, I installed stock length 4600 rear shocks, and I don’t remember having any trouble installing them.
This is at least the third or fourth time I have found answers to my questions on this forum.
Thank you to everyone here who is more than happy to share their experiences/give free advice! Whenever I can, I do the same.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
rear , shock , short , stud , top
Bilstein 5100 rear shocks install question, not enough thread. Otgixxer 4th Gen T4Rs 8 10-23-2023 05:32 AM
Tundra TRD Springs / Bilstein 5100's, OME 890's in Rear - Slight Issues Koko4 3rd gen T4Rs 6 11-19-2015 12:54 PM
Bilstein 5100 Rear Shock install Problem hrod79 5th gen T4Rs 5 09-09-2014 08:31 PM
Bilstein 5100 rear install kit RCs4Runner 4th Gen T4Rs 2 09-21-2013 02:26 PM
Bilstein 5100 Front and Rear Install Height on the 5th Gen ct221933 5th gen T4Rs 5 02-22-2011 12:59 PM
