Old 06-30-2020, 07:54 AM #1
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
what else to replace during timing belt replacement
hi all,
i'm sending my 2005 v8 in for maintenance next week. i'm having the timing belt, water pump, accessory belt and radiator fan clutch replaced. are there any other parts i should typically have replaced during this type of maintenance?
thanks
harry
hankd is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 12:25 PM #2
SumoRerun SumoRerun is offline
SumoRerun is on a distinguished road
I've got the v6 but with something like a timing belt, things I would look at would be rad hoses, spark plugs, oil change, air filter, coolant drain and fill. Of course money is always the deciding factor here but that's what I would at least consider and do if needed.
SumoRerun is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 01:17 PM #3
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
If he is getting the water pump replaced then the coolant drain is a given.
All of the other preventative maintenance stuff is always a good idea though. I wouldnt replace the rad hoses unless they are looking damaged.
royal T4R is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 03:11 PM #4
4thgen_nc 4thgen_nc is offline
Real Name: Taylor
4thgen_nc is on a distinguished road
Real Name: Taylor
Tstat
Sent from my Pixel 4 XL using Tapatalk
4thgen_nc is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 03:23 PM #5
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Bracket
I don't know how many miles is on your vehicle but the fan bracket where the fan clutch mounts on usually goes out around 200k to 250k so if you are over 200k miles i would do it for sure.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 05:31 PM #6
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Don't bother with Amazon spark plugs. Few of us got burnt with knock-offs that we thought were OEM. I'm guessing I got the knockoffs as I get slight shake at idle sometimes still.
gaber6 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 06:43 PM #7
hankd's Avatar
Real Name: Harry
hankd's Avatar
Real Name: Harry
hey thanks a lot, this was the type of thing i was wondering about. the truck has 210,000 kilometers on it. the darn bracket for the fan clutch is more expensive than the actual fan clutch lol.
thanks for all the other suggestions too.
Old 07-03-2020, 12:11 AM #8
T4R416 T4R416 is offline
T4R416 will become famous soon enough
Timing belt tensioner, cam and CRANK seals, thermostat and gasket , idler pulley .
T4R416 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 01:50 AM #9
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Absolutely...Once it starts making noise it doesn't take long to seize up. Left me stranded. Right at 200k. Serpentine Belt Snapped.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
belt , fan , maintenance , replaced , timing
Replace timing belt or run until she dies? montana_jeepn 3rd gen T4Rs 19 05-02-2014 04:56 PM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
timing belt replace? 924runnerSR5 Classic T4Rs 0 11-12-2010 02:58 PM
what else to replace with timing belt ? kennyb3030 3rd gen T4Rs 6 01-14-2010 09:10 PM
Need To Replace Timing Belt, but what else? deckert4r 3rd gen T4Rs 3 05-10-2006 12:56 AM
