Old 06-30-2020, 06:27 PM #1
B.E. Coyote's Avatar
B.E. Coyote B.E. Coyote is offline
B.E. Coyote is on a distinguished road
Intermittent loss of power- No codes?
It is an 04 Limited with the 4.7 if it matters.
2 weeks ago I was driving at highway speeds and I thought it was really down on power, got home fine.
Drove it on short hops around town with no issues until today.
I pulled my approximately 2500 pound boat to the launch. Pulled fine for about 8 miles then a significant loss of power. Could barely go 20 mph.
Pulled over and let it sit for 15 minutes. Back to normal, I was 1 mile from the ramp so of course I went fishing.
I don't think its the transmission. RPMs never spiked like if the tranny was slipping.
No codes according to my BT obd2 and Torque app.
It has 155,000 miles on it, catalytic converter clogged?
B.E. Coyote is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 07:11 PM #2
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I seriously doubt it's a clogged cat. Clogged cats don't act up now and run fine later. I'm wondering if maybe it could be the electronic throttle. When/if it does it again I'd have someone watch under the hood and see if the throttle moves like it should when you work the throttle. Of course there are a lot of other things it could be. Good luck and let us know what you find.
importman is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 07:16 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Intermittent loss of power - need help
Loss of power, no CEL
4.7 intermittent loss of power and loud roaring engine noise
Throttle Response loss
Power loss
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 10:59 AM #4
Thanks, I did see a few of those threads but missed others. I have done research and cats came up often. Unfortunately a lot of times the OP never reports back to confirm that X, Y or Z fixed the problem.
Old 07-18-2020, 06:27 PM #5
I am pretty sure the issue is solved.
Using Torque Pro I found that I was getting a pending fault code. P2714 but that it would dissapear when the truck restarted and never throw a CEL or become a full fledged code.
Turns out the ATF was a hair over 2 quarts low. The P2714 had to do with pressure.
ATF level is correct now and haven't had an issue. This includes pulling my boat on a hot day.
Probably going to have the local transmission shop change the filter and do a complete flush.
Old 07-18-2020, 07:14 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Good to hear....BUT I would forget about having them change out the "filter", there is no filter, there is however a metal "screen", everyone who pulled the pan to change the filter found that screen not clogged whatsoever so no need to change it, also with the V6 it pretty easy to pull the transmission pan and put it back on, but with the V8 the exhaust has to be taken apart to get the transmission pan off causing the labor to be much more and you will risk having an exhaust leak if not put back together correctly which will throw another code!!
Just do a complete fluid "exchange", Do Not do a complete "flush" which is done using pressure which could cause any possible deposits to dislodge and clog any number of the very small passageways in the transmission and or valve body, new fluid will not dislodge any of these possible deposits but instead will dissolve them and not cause any issues.
2004 Limited V8
Old 07-19-2020, 08:22 PM #7
Real Name: Danny
Real Name: Danny
Just to add to what you said: I would also ask the transmission shop to find out where the fluid went. Transmission fluid, unlike engine oil is not usually consumed. For it to be 2 quarts low there almost has to be a leak unless someone serviced it and didn't fill it all the way. Disclaimer: on older vehicles with a modulator valve on the transmission the fluid could be sucked through a vacuum hose and burned by the engine if the diaphragm failed. Luckily, our runners do not have those.
Old 03-10-2023, 10:49 AM #8
printegra printegra is offline
printegra is on a distinguished road
Hi coyote,,, same problem here with code 2714,, did you ever figure it out?????
printegra is offline   Reply With QuoteReply With Quote
codes , fine , loss , power , pulled
Intermittent loss of power - need help fullboogie 4th Gen T4Rs 14 07-02-2020 02:41 PM
Hard start when hot, intermittent codes AntleredRuin 3rd gen T4Rs 9 01-23-2019 02:23 PM
4.7 intermittent loss of power and loud roaring engine noise 4OYOTER 4th Gen T4Rs 10 06-04-2018 11:00 PM
Intermittent Tailgate power loss?? dmalis12 4th Gen T4Rs 0 03-01-2015 06:29 PM
Intermittent Loss of Brakes FirstGenRunner Classic T4Rs 2 05-28-2010 11:53 AM
