Originally Posted by blkexp98
I just wanted to see if this was a normal occurrence for everyone else before I tried to fix something that wasn't broken. Basically my 4runner will lose the majority of its braking if it hits a bump while braking. Let's say they are doing road work and I start braking on smooth pavement and then drop off slightly to where its been ground up or washboard, my braking ability is almost gone. If I brake on the good surface, let off and then rebrake once I'm on the other surface then its normal. Is it just that the system sees any interruption as a possible lock up and reacts?
Sent from my SM-G975U using Tapatalk
ABS issue, bump or once engaged
Brakes Giving out
5th Gen Brake Failure - 17 TRDP
I've read a couple threads on this, the last one I linked is fairly long.
Its mostly normal I think.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
