Old 07-01-2020, 06:24 PM #1
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Question Alternative to Toyota SAE LF 75W
Any Good alternative to Toyota SAE LF 75W for the Transfer Case that isn't $$$$$. Thought 75W-90 was good for Front/Rear Diff and Transfer Case as well
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 07:07 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
From the 5th Gen (which uses the same 75W transfer case fluid):
Transfer case lube.
Transfer Case Fluid
transfer case fluid
Redline 75w85 GL5 Gear Oil : Would this be safe for use in my transfer case????
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 12:01 AM #3
Az4runnin's Avatar
Az4runnin's Avatar
Originally Posted by Bossman View Post
Damn seems like more questions than answers
Old 07-02-2020, 09:22 AM #4
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I used mobile 1 synthetic 75w-90 in diffs and the t-case after seeing a few others on here using it. It does seem to be a debated topic without a conclusive answer or explanation
I bought the 4 x2 packs on amazon, since it was the cheapest and most reasonable at the time. The 12 pack is about as much as 4 x2 packs, but I decided I didn't need 5 extra qts. Anything $10-12/qt seems to be a decent price for gear oil in a reasonable quantity. I also got an off-brand crush washer set that is doing fine.
Mobile 1 gear oil I used: Amazon.com: Mobil 1 104361 75W-90 Synthetic Gear Lube - 1 Quart (Pack of 2): Automotive
crush washers (currently unavailable for whatever reason): url=https://www.amazon.com/gp/product/B07Q3R7TWG/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
y=mx+b is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 10:59 AM #5
Syr4RinNC's Avatar
Syr4RinNC's Avatar
That’s what I’m planning to use when I do it next week. Hopefully all my drain bolts come off.
No one knows is the answer. General consensus is it probably needs to be changed and there’s not really any reports of harm with any 75w fluids
Old 07-02-2020, 11:34 AM #6
4th gens call for 75/90 in transfer case & front diff. any brand 75/90 is fine. i use valvoline some use mobil1.
Old 07-03-2020, 02:40 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Maybe I've missed it but I haven't seen a thread about Tcase problems at all other than the box on the back that may leak. My guess is 90% of 4Runners on here are running some type of 75W90 synthetic with absolutely no lubrication issues. So take your pick of name brands and don't look back.
Old 07-04-2020, 09:08 AM #8
Bogrun's Avatar
Bogrun Bogrun is offline
Bogrun will become famous soon enough
Bogrun's Avatar
For another data point, the 2005 (and I'd assume all 4th gen) manual calls for 75W-90 gear oil in the transfer case. I use the same 75W-90 gear oil in the front differential, transfer case, and rear differential and have had no issues.
Bogrun is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 12:02 PM #9
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
I've read elsewhere the same thing--that 75w90 works fine and it is what I am planning when I do my change over the summer.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 12:29 PM #10
all 4th gens call for standard 75/90 for the xfer case.
its the 5th gens that use the straight 75w, probably something to do with the advanced features they have like crawl control etc.
alternative , case , good , sae , transfer
Alternative to TAN Toyota Inner CV Joint Grease? Yoter 3rd gen T4Rs 2 03-30-2017 11:27 PM
Alternative Toyota shocks for less than 3" lift? Dezert4Runner 3rd gen T4Rs 21 08-19-2016 01:17 PM
Any alternative to the $80 Toyota intake duct? drmoreau 3rd gen T4Rs 26 10-27-2015 07:00 PM
5th Gen Bra or alternative? bofa 5th gen T4Rs 8 09-27-2012 06:35 PM
Pics of alternative Toyota Wheels on 4runner. Go~Rilla 5th gen T4Rs 5 06-28-2011 06:21 PM
