Old 07-02-2020, 10:32 AM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
LFD vs RCI vs Coastal Offroad Skid Plates
My next mod is probably going to be skid plates. I was noticing the armor thread sticky is not particularly detailed on this account, probably because they are (relatively) simple.
Main ones I'm considering are LFD, RCI, and taking the plunge and welding the coastal offroad ones myself. I noticed that the RCI and coastal offroad options have a drop pocket for the front diff. Does this increase the overall clearance of the skid plate (except in that place)? Also, do any of these have problems with exhaust rattle? I was noticing that the exhaust hangs low behind one of the cross members.
From looking at pictures, the RCI option seems to have the best clearance/coverage, but any opinions/experiences are appreciated.
I just wish RSG made more armor for the 4th gen. I love their rock sliders!
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 06:36 PM #2
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
I'm currently running the RCI skids front to back (minus gas tank) and love them. They've saved me from quite a bit of damage and have held up great. I opted for the powder coat, and the finish turned out great. I occasionally pull them and just spray them with flat back Rustoleum. You can get them for 20% off every couple of months.
BendRunner is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 04:20 AM #3
montijo505's Avatar
montijo505's Avatar
My Coastal Off-road ones took a lot to fit the rear one on my V6. I think they used a V8 to model them and therefore the skid was too long and holes didn't line up with the crossmember. Had to cut about three inches off and notch for the bolts.
Also the front allows no room for a sway bar. I would definitely check with them to see if they've made the necessary adjustments, if not buy somewhere else.
If I could go back I'd spend the extra on RCI and not have to mess with them.
Sent from my SM-G986U using Tapatalk
Old 07-03-2020, 03:35 PM #4
Any issues with exhaust rattle on the RCI? V8 or V6?
I nearly pulled the trigger on the tax day sale. I'm thinking about catching the next one.
Old 07-04-2020, 04:31 PM #5
Caldizzle's Avatar
Caldizzle Caldizzle is offline
Real Name: Calvin
Caldizzle will become famous soon enough
Caldizzle's Avatar
Real Name: Calvin
RCI skids on my V8. Had a small amount of contact on the drivers side skid further back causing a rattle. Cutoff wheel and problem solved. I like them.
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
Caldizzle is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 05:39 PM #6
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Running full set RCI 1/4 5052 Aluminum no issues.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 09:25 PM #7
What did you cutoff? I am no stranger to the magic of the cutoff wheel. It's how I got to my fuel pump in my Isuzu with a full tank of gas xD
Old 07-04-2020, 09:33 PM #8
montijo505's Avatar
montijo505's Avatar
I also, like to live dangerously.....
Old 07-07-2020, 10:20 AM #9
I have a v8 and no rattles or trimming needed. Running everything but the gas tank skid.
Old 07-07-2020, 04:49 PM #10
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
After much research I settled on the RCI mainly because of many very positive reviews on fit, finish, and durability, but also because they offered them in 1/4” aluminum, which I wanted for both weight savings, as well as lack of rust. I also opted for the black powdercoat, which was awesome, and the bumper filler plate. I don’t do a lot of off-roading, but it’s nice to know I have the protection if needed. My vehicle had the factory one missing when I bought it, and having a real plate just made sense when pricing out a factory replacement, which is just stamped sheet metal. Fit and finish are perfect. The only real issue I had was that I had to drill out where the original bolts had been sheared off and re-tap the holes to be able to install the RCI. I coated the hardware with anti-seize so hopefully I’ll be good to go from here on.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 06:10 PM #11
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Hmmm...I was pondering the Coastal set, I have the V8 so it should line up, but I'm curious on the sway bar clearance. Would it fit with some grinding?
RCI makes the cheapest gas tank skid I can find so it'll probably be that out back.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 09:04 PM #12
montijo505's Avatar
montijo505's Avatar
I honestly don't know, it tucks so tight. I had a guy message me about having trouble on his GX with the V8 and the sway bar. I took my sway bar off a while ago so no issues.
It might fit with modification, but I can't say whether it will or won't for sure. May be worth a shot to message them and ask.
Old 07-08-2020, 06:22 PM #13
I reached out and was told they will fit with stock sway bar mounting. I run the drop spacers so his recommendation is to space the front of the mounting point up front around the same height of the drop spacers in order to clear the sway position.
My thought is to just notch the skid where there is interference, seems easier if it's possible. I emailed him back with the followup question so we'll see.
Old 07-08-2020, 06:52 PM #14
montijo505's Avatar
montijo505's Avatar
Notching should work, its gonna depend if it hits on articulation or not. Report back if you end up getting them. They are BEEF thats for sure.
Old 07-08-2020, 07:15 PM #15
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Full RCI skids front to back... Front, Transmission, Transfer Case, Rear Differential, Fuel Tank, A-arm, Lower Link skids and Rock Sliders. Everything bolts up with no issues and great fitment, currently running DT headers, stock y pipe and Gibson Side Exit Exhaust.
Highly recommend!
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
coastal , exhaust , offroad , rci , skid
Coastal Offroad Skid Plate gimlithepirate 4th Gen T4Rs 3 05-05-2020 06:50 PM
OEM TRD Offroad premium skid plates $40 Bakersfield ca DZtrd For Sale: T4R Items 0 09-28-2019 05:25 PM
Coastal Offroad Skid Plates - Anyone using them? absalom 3rd gen T4Rs 0 07-22-2018 09:04 PM
