Old 07-02-2020, 12:46 PM #1
jumpjet's Avatar
jumpjet jumpjet is offline
jumpjet is on a distinguished road
jumpjet's Avatar
A/C Troubleshooting... before I go buy the tools
T4R,
I'm trying to see if I missed any initial troubleshooting steps before I go buy gauges and a vacuum pump to do it all the way.
Symptoms:
It's a 2005 V6 SR5/4WD. Following a multi-day road trip towing a load, the 4R sat for a couple days. On the next drive, the AC was blowing ambient air, regardless of setting (tried in Auto and LO). The AC light was not blinking. Visually, the compressor clutch is engaging/disengaging depending on selecting the AC on or off. This leads me to believe the relay is ok. There is a small blackish/burnt-looking spot on the corner of the relay (pic attached), but googling seems to tell me that's normal.
The sight glass looks like this:
4Runner Sight Glass Video (should be a link to a 5sec video of the sight glass during AC operation). Which tells me there's at least some refrigerant in the system.
The next steps seem to be getting my hands on some gauges to check the pressure, then draining and filling the system with dye to check for leaks.
Am I missing any other potential obvious cues?
Thanks in advance.
A/C Troubleshooting... before I go buy the tools-img_2384-jpg
jumpjet is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 08:17 AM #2
Auditechnician Auditechnician is offline
Auditechnician is on a distinguished road
Your process sounds solid. Sight glass definitely looks low, but that the compressor is still functioning. If you can’t find any leaks in the system, it may have purged through the relief in the compressor if pressure got to high during your trip. Of course I’m just speculating Toyotas even have relief valves in compressor (I know a lot more about Audi design than Toyota).
Auditechnician is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 09:48 PM #3
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Check line
If the compressor is cycling on/off check your low pressure hose/line if it's cold,cool or just ambient that will tell you if your issue is with your A/C system or an issue with the controls inside the cab. Since you mentioned you have an Auto feature you likely have actuators that control your doors for the housing directing the air out of your vents.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 08:40 AM #4
Captsolo Captsolo is offline
Captsolo will become famous soon enough
I have a SR5 2005 (150,000) miles and had to replace the AC Compressor after 12 years in Bahamas where it ran 24/7. Have it dye tested for the leak. Forget fixing the clutch. Get a new Denso at Amazon for $200.
Amazon.com: Denso 471-1413 New Compressor with Clutch: Automotive
DENSO IS THE OE SUPPLIER FOR THIS VEHICLE, w/NEW COMPRESSOR, OE-SPECIFIED O-RINGS AND OIL INCLUDED
Captsolo is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 09:45 PM #5
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Having a similar issue, what do the various temperatures on the low pressure line mean?
Symptoms
• The last few nights after I shut the truck off, I hear a hissing/breathing sound from behind the dash. AC is on when vehicle is shut off.
• Tonight it was blowing cool (not cold) air (very high humidity in the area, temps in the mid-80s, truck had been sitting in the sun for an hour +)
• Tonight I turned off the AC before shutdown and heard no hissing/breathing sounds
• Noticed a larger than normal puddle of water/condensation from the AC under the vehicle
Any AC experts have thoughts on where to start? Thanks in advance
eleven14 is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 03:24 PM #6
jumpjet's Avatar
jumpjet's Avatar
Finally got around to picking up a set of gauges and a vacuum pump. Static pressure on the system with the engine off was ~30psi both sides. When the clutch engaged on the compressor the low side pulled a vacuum and the high side only went to about 60psi. Since it had a static pressure that didn't seem to indicate a leak, I figured the worst that could happen recharging it would be that I'd be out the $16 for a couple of cans of 134a.
Pulled a vacuum and let it sit for a while with no apparent leaks. Vacuumed it down again for another 30 minutes, then put two cans of 134a in and a 1/4 oz of dye. The system capacity is a hair under 24 oz (23.98 oz according to FSM). Blowing cold again for now. If it holds, great. If not, I'll fix the leak if I can find it. If it's under the dash, I may try some leak stop until it cools down and I feel like tackling that pain in the ass.
check , glass , sight , system , troubleshooting
Your favorite tools for wrenching / tech tools for special applications Jhelms 3rd gen T4Rs 340 09-19-2021 10:20 PM
Tools: what's good between the Chinese crap and "truck tools" i.e. Snap-On, Mac, ... xyzzy Off Topic 13 06-23-2020 06:23 PM
Kobalt tools seem to be getting phased out. What mid-level tools do you guys prefer? repo Off Topic 12 04-20-2019 11:24 AM
MOVING SALE IN NH: Tools, drill press, yard tools, etc clemson4r For Sale: Non-T4R Items 0 06-16-2016 08:49 PM
FS: Mac tool box, tools, cart, diag tools lot. IL Nikkshepherd For Sale: Non-T4R Items 16 04-20-2016 05:34 PM
