Old 07-03-2020, 08:11 PM #1
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
MAF sensor woes
Hey all,
Last week after getting back from a 6 hour drive, I was sitting in the car wash and the 4runner just died. It wouldn't start the first time I tried, and then it did. CEL and then VCS trac lights came on.
Got home and pulled codes and got:
============1==============
P0102
Raw code: 0102
ECU: 10
Status: Confirmed
OBDII: Mass air flow (MAF) sensor/volume air flow (VAF) sensor - low input
Toyota: Mass or Volume Air Flow Meter Circuit Low Input
============2==============
P0101
Raw code: 0101
ECU: 10
Status: Confirmed
OBDII: Mass air flow (MAF) sensor/volume air flow (VAF) sensor - range/performance problem
Toyota: Mass or Volume Air Flow Meter Circuit Range / Performance
Pulled the MAF sensor and cleaned it using the special spray. No dice. Cleaned the throttle body. No dice.
Ordered a new OEM MAF sensor and just got it today (after waiting 5 days for it to arrive). Threw it in, and tried clearing the codes. No change.
The truck is stuck in limp mode (won't go above 3,000RPM), and every time I clear the codes the truck dies again. It's driveable under 65 otherwise, as it just takes two times to start, no more, no less.
What the heck is going on!? Do I need to reset the ECU again? I'm writing this as the battery is sitting disconnected, so I'm going to head out there after I submit this and try it all again. So bummed.
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 11:53 AM #2
atalarico's Avatar
atalarico's Avatar
Bump? No ones had MAF issues like this?
Old 07-04-2020, 12:57 PM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Cloged up air filter?
Sound like something got wet in the carwash?
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 06:44 PM #4
atalarico's Avatar
atalarico's Avatar
Yeah I tore everything apart from the air filter box onward to the throttle body. Nothing is off.
I’m kind of wondering if the wire harness got messed up but I don’t know how to check that with an ohm meter.
Old 07-04-2020, 07:46 PM #5
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Any past rodent issues? Could the ECU connection have gotten wet? Just reaching here, but maybe a crazy idea will give you one. Definitely curious. I hope you get it sorted out soon.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 08:08 PM #6
atalarico's Avatar
atalarico's Avatar
Nah nothing to speak of. It happened in a car wash so I’m guessing something got wet that wasn’t supposed to?
Old 07-04-2020, 08:31 PM #7
Real Name: Brett
Real Name: Brett
The new MAF is a dealer OEM? or online purchase? I keep hearing stories of counterfeit parts online. Hope it's something simple and not too aggravating.
Old 07-05-2020, 01:35 AM #8
atalarico's Avatar
atalarico's Avatar
It’s dealer OEM. Sigh. So lost. I hate to admit defeat but it’s going to the shop.
Old 07-05-2020, 03:37 PM #9
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Take a few minutes and look for a very large vacuum leak. When unmetered air gets into the engine it can throw a MAF code.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 11:26 AM #10
atalarico's Avatar
atalarico's Avatar
Yeah, I checked and didn't see anything.
I pulled a couple more codes after driving it for a bit related to the O2 sensor:
P0051
Raw code: 0051
ECU: 10
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit low
Toyota: Oxygen Sensor Heater (Bank 2 Sensor 1) Circuit Low
============4==============
P0031
Raw code: 0031
ECU: 10
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit low
Toyota: Oxygen Sensor Heater Circuit Low Input (Bank 1, Sensor 1)
Part of me thinks (hopes) that's just a symptom of whatever is throwing the MAF off. Anyway, I dropped it off at the shop since I'm at a loss, so we'll see.
Sigh.
Old 07-06-2020, 12:42 PM #11
08TxRunner's Avatar
08TxRunner's Avatar
How did you check? Just looked around the engine compartment? If so that's not going to do it.
Old 07-06-2020, 12:49 PM #12
atalarico's Avatar
atalarico's Avatar
I mean, I don't have a vacuum gauge pump, but I checked all of the vacuum hoses for obvious signs of breakage, etc., and used the carb cleaner trick around the usual suspects and listened for the engine idle change.
I didn't check my headers though, and I wouldn't be surprised if there was a shoddy weld on the DT headers that gave out.
We'll see what the shop says since they likely have smoke machine. I'm sure it is a vacuum leak somewhere, just curious where since it's beyond my abilities at this point.
Old 07-06-2020, 04:55 PM #13
atalarico's Avatar
atalarico's Avatar
My go-to shop couldn't fix it. He thinks it's something going on with the computer. Showed me a print out of the MAF airflow rate is just flatlined at .23 g/s whether it's being given throttle or not. He tried swapping another MAF but same results. He didn't see any vacuum leaks either. He said replacing the computer might be the fix, but he can't do that since he doesn't have a way of programming it. That sounds expensive as hell.
Dealership doesn't have openings until the 16th, so I'm taking it to another place in the mean-time to see what they think.
FML.
Old 07-06-2020, 06:25 PM #14
Real Name: Brett
Real Name: Brett
@atalarico Check this guy out from NZ. He is a little hard to understand but knows the UZ platform better than anyone. He just went through the wire loom on a 2UZ in this video. He might be able to shed some light, because he is an expert at ECU swaps. One thing I hear is the security key code is a stumbling block for this. Not sure it affects the older UZs like ours. He shares a wealth of knowledge and there may be something in his videos that might help and he is good at responding to comments in his vids. Good Luck!!
CartuneNZ You Tube
Old 07-07-2020, 02:59 PM #15
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Check your fuses, especially the ones labeled EFI 1 and EFI 2, and A/F Heater. Because this problem onset after a car wash, it's possible water got into a connector and shorted a power circuit to ground.
And by check them, I mean physically remove them and examine the fusible element, then probe them with a meter to verify continuity (infinity resistance reading).
If there's any doubt that each fuse is good, replace it.
If the problem continues, disconnect your battery negative and then remove & inspect each connector on the ECM. Look for corrosion, moisture, bent pins. Spray out the connectors with electrical parts cleaner, let dry, then reassemble.
waypoint is offline   Reply With QuoteReply With Quote
air , flow , maf , mass , sensor
Air Fuel Ratio Sensor and o2 Sensor Replacement - P0136 and P2195 Smurray 4th Gen T4Rs 5 02-25-2019 08:21 PM
FS: Brand New 3rd Gen Air/Fuel Sensor & Oxygen Sensor in Texas (2001-02 V6) SURF RUNNER For Sale: T4R Items 2 01-03-2015 09:41 AM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
96 o2 sensor rounded and rusty nut woes DustyRoads 3rd gen T4Rs 18 09-11-2014 10:15 PM
