Old 07-03-2020, 11:21 PM #1
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Re-Packing OEM Wheel Bearings
Hey folks,
I'm getting ready to replace my OEM wheel bearings/hubs with complete units after I started noticing the telltale growl while driving plus the wheel being a little shaky during the wiggle test.
My question is, can I clean out the old units, repack them with grease and keep them as usable trail spares?
I've got 223k on them, 15k of that has been on larger tires and wheels with more offset than stock which I think sped up the wear.
My friend also just got stranded quite a few hours away from home when hers went out after wheeling for several days with me here in CO so Im a little nervous about mine.
Any input is appreciated!!!!
Thanks guys
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 08:20 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by MrSeth View Post
Hey folks,
Thanks guys
If I'm not mistaken the bearing itself is a "sealed bearing", meaning there's no good way to get new grease in there let alone getting the old grease out without removing the seals, to do that you would have to press the old bearing out of the carrier, remove the seal and then regrease the bearing, replace the seals and then press the bearing back into the carrier, also the bearing having play in it means it's worn out so not a good backup replacement IMHO.
BUT...
Here's a YouTube video on regreasing a sealed bearing.
YouTube
In the end that's a lot of work and needing a 20 ton press just to have the old worn out bearing as a backup, I would rather have a new bearing assembly as a backup even if it's a cheap one, but I would personally get the best, that way if you have to replace it on the trail it's a done job not needing to be done again when you get home.
2004 Limited V8
Old 07-04-2020, 09:11 AM #3
Real Name: Skip
Real Name: Skip
Hey folks,
Thanks guys
BUT...
YouTube
I was rethinking my opinion I wrote above....I actually think I would just keep the better or both of the 2 old wheel bearing assemblies as is as the trail backup, it should get you off the trail and back home instead of spending another couple of hundred bucks for a new assembly as a backup that may never be needed!
Also you may actually be able to get to at least one side of the bearing without pressing it out to remove one of the seals to try and get some new grease in there.
2004 Limited V8
Old 07-04-2020, 07:16 PM #4
Rambler2005's Avatar
Rambler2005 Rambler2005 is offline
Real Name: Alex
Rambler2005 is on a distinguished road
Real Name: Alex
When mine failed yesterday They were able to reuse the hub and put on the wheel bearing on the old hub it was the only choice i had because Napa didn't have the hub they are two separate part numbers but lucky I got it fixed
Alex
Rambler2005 is offline   Reply With QuoteReply With Quote
input , oem , stranded , units , wheel
wheel bearings lwd03 Maintenance/Detailing 0 12-09-2014 09:01 PM
Wheel Bearings samdajellybeenie14 3rd gen T4Rs 3 08-20-2011 01:10 AM
Wheel bearing re-packing Nelsonmd 3rd gen T4Rs 7 06-15-2011 07:01 AM
Wheel Bearings DIY HELP 2K34R Problems & Warranty Issues 2 04-16-2008 04:07 PM
wheel bearings robstibz 3rd gen T4Rs 2 03-15-2007 09:04 PM
