Old 07-07-2020, 01:22 PM #1
ls1says ls1says is offline
ls1says is on a distinguished road
2017 TRD Bilsteins on 03 4Runner V8
Hey all,
I recently picked up a set of 2017 TRD Bilstein front struts/coils and rear struts. Does anyone know what is involved with making these work on the 03' 4th gen? I read somewhere that i need 9.8108G energy suspension poly's for the front struts and can I use stock coils for the rear along with the TRD bilstein struts?
2017 TRD Bilsteins on 03 4Runner V8-struts-jpg
ls1says is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 01:32 PM #2
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
The bushings are needed for the Rear Shocks not the Front.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 02:19 PM #3
Thanks for the clarification. Are these the right bushings to use? and would you happen to know what the lift size would be by going with this setup?
2017 TRD Bilsteins on 03 4Runner V8-poly-jpg
Old 07-07-2020, 06:10 PM #4
harl harl is offline
harl is on a distinguished road
Im following your post as I just got 2019 TRD front coils/shocks and rear coils/shocks , but do not think they will fit my wifes 03 V6
harl is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 06:59 PM #5
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
I have 2019 front TRD Bilstiens/coils from a Tacoma on my 2003 V8 runner. They will fit your wife's vehicle just fine. As will the rear shocks with the Energy Suspension bushings in the lower shock eyes. I'm also running 2007 FJ rear coils. There are many threads on the forum covering this.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 07:02 PM #6
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Originally Posted by ls1says View Post
Hey all,
Take those giant spacers off the hats and they will bolt right up.
Old 07-07-2020, 07:07 PM #7
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Yes, those are the correct bushings. Same as what I used.
Amazon.com: Energy Suspension 9.8108G 3/4" Hourglass Shock Eye Bushing: Automotive
Old 07-07-2020, 11:10 PM #8
Hahaha yea forgot to mention those will gone
Old 07-08-2020, 11:33 AM #9
So when I press out the old bushings with the metal sleeves do I just press these ones right in without any sleeves?
Old 07-08-2020, 06:57 PM #10
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Yes. The old ones might be a biatch to get out but if you have a vice and some sockets, you can do it. Clean the empty hole good and lightly grease it and the new bushings and you can almost put them in by hand. I still had to use a vice initially and then further adjusted by hand.
Old 07-08-2020, 10:53 PM #11
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
I didn't swap the bushings when I did mine.
Why are they "required"?
The fronts had to be filed a fraction of an inch to for into the front LCA.
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 11:07 PM #12
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Did you use rear Tacoma shocks? They are required if you do that since the 4runner lower shock mount is a larger diameter than the bushings that the Tacoma uses.
My 2019 Tacoma front shocks and springs bolted right in without any modifications.
Old 07-08-2020, 11:25 PM #13
Ahhhh... Missed that little detail, mine are off a 4runner.
bilstein , front , rear , struts , trd
2017 4Runner TRD Off Road Premium (my 5th 4Runner 83-2017) nikilicious General Discussions 22 09-12-2017 12:06 AM
99 tall 4runner front coils with Tundra or Tacoma Bilsteins? DPR64 3rd gen T4Rs 18 02-12-2015 01:44 AM
99 4runner highlander coils and bilsteins bullcrew For Sale: Suspension/Wheels/Tires 3 05-29-2012 04:54 PM
FS 4runner 3rd Gen Bilsteins jrm For Sale: Suspension/Wheels/Tires 1 04-27-2012 02:53 PM
Will these Bilsteins work on a 4runner? runrunner 3rd gen T4Rs 2 07-05-2010 06:46 PM
