Old 07-12-2020, 02:40 PM #1
moonbayb moonbayb is offline
moonbayb is on a distinguished road
Battery drain by after-market remote starter
I just tried doing a search in this forum, but could not find my problem, and also need to say that I did not know much about working on cars.
I have a 2003 TOYOTA 4RUNNER SR5 V6 4X4 in which I had an automotive stereo and alarm company install a remote starter/alarm system a couple of years ago (I can't find my paperwork for the model). Since then, I've had to replace my battery 4 times because they test dead (the starter tested ok). I did take it back to the company and the guys there could not locate the problem. They suggested either a trickle charger or solar panel, but I do not have a secure place to hook up my trickle charger and my truck does not have an always-on outlet. Full disclosure, since I retired, and especially during the COVID-19 pandemic, the truck sits as I do not drive much. Also, the battery is too heavy for me to take out and trickle charge in my basement.
My question is, is there a heavy-duty battery that will withstand the remote starter leeching? I am willing to spend more for it within reason. If not, is there a mod I could have done to alleviate the problem?
Thank you in advance
moonbayb is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 09:28 PM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if the truck sits that long and not driven much, the battery would be low, i would suspect the start kill relay is working correctly if installed right, the alarm/remote start still need some power to make it all work.
depending on how old your battery is, it might be low or a dead cell.
the newer alarm system is nicer, has a voltage sense, if it goes below a certain voltage, it just turn off a few things.
try to manully lock the truck up and let it sit with no alarm activated, see if that helps. you should be able to still remote start.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 11:37 PM #3
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
The only "mod" is to install a battery cutoff switch and use it after parking the truck. The downside is that all your radio presets will be wiped out and your driver window, rear hatch window, and sunroof will have to be put through the reset cycle to learn their closed and open positions. All your trip odometer and MPG data will be wiped as well.
Personally, I'd find a trusted auto electrical guy to tear out the remote starter and restore the wiring to OEM quality condition. I would not trust the techs at the car accessory store to properly restore wiring.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 01:00 AM #4
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
I had the same issue with my security system with remote start but my battery would just drain down but never completely die. I started using a Noco trickle charger and no more problems with battery drain.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 04:01 PM #5
stephan07 stephan07 is offline
stephan07 will become famous soon enough
This is a real PITA with Toyota remote start
In NE, in the cold winter months I hit Hawaii for 2+ weeks. Every time I com back my upgraded odyssey battery is dead, from the remote start.
Not worth the effort.
2017 TRD PRO Barcelona Red,RCI Sliders,RCI Alum Skids +C4 Fuel Skid, 285 Nitto Ridge Grapplers, Icon Rebound 17x8, HID, SSO Slimline Front Bumper/Warn Zeon 10s Plat, SSO High Clearance Mod, ..King 2.5 Res, Total Chaos UCA & LCAs, ARB Fridge, Battle Born Second battery with RedArc& Solar, ARB Drawers..Frontrunner Full Rack and CVT Mt Ranier RTT, C4 Ladder, Sprint Booster
2021 Audi RS6-Tuned 820hp
2017 F12 Berlinetta
stephan07 is offline   Reply With QuoteReply With Quote
battery , problem , remote , starter , trickle
Remote Start-Even dealer said go after market! joneser 5th gen T4Rs 47 11-20-2014 11:38 PM
HELP! No start, batt drain, rebuilt starter, new alt greif07 3rd gen T4Rs 9 05-04-2014 10:02 AM
Remote Starter for 97 Jeff277 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-16-2004 01:11 PM
