Old 08-31-2020, 04:21 PM #31
montijo505's Avatar
montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of
montijo505's Avatar
Originally Posted by miller507 View Post
Luckily I have a friend that has been getting good results on ecu reflash alone on several brand cars, obviously having a stand alone tuner like an HP or Ucom will work alot better but that's a bit out my budget for the moment.
Invested too much time over the weekend lurking around the taco forums.... Kinda hate that place now.
2005 - 2015 Toyota FJ / Tacoma / XRunner Pulley Kit NST06150K
i'm a sucker for bolt ons that actually work.
Damn, I don't get how they improve anything if they're the same radius and such. Any good threads on TW about it? Never heard about these until now. Might be nice to just pretty up my engine bay.
Sent from my SM-G986U using Tapatalk
Old 08-31-2020, 06:36 PM #32
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
It’s the weight reduction in the lightweight pulleys basically reducing resistance. Plus that red anodized aluminum would probably look sharp.
Btw. Thank you for starting this thread. Been watching it for weeks since the group buy #2 was ongoing. I just got in for the group buy #3. This seems pretty intimidating to me, but then again so has everything else I’ve done on my 4Runner so far.
Thanks to this great site with tons of experience, it’s a lot easier to have the confidence to get this kind of stuff done.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 09:48 PM #33
montijo505's Avatar
montijo505's Avatar
Originally Posted by cwilliams563 View Post
Its the weight reduction in the lightweight pulleys basically reducing resistance. Plus that red anodized aluminum would probably look sharp.
Btw. Thank you for starting this thread. Been watching it for weeks since the group buy #2 was ongoing. I just got in for the group buy #3. This seems pretty intimidating to me, but then again so has everything else Ive done on my 4Runner so far.
Thanks to this great site with tons of experience, its a lot easier to have the confidence to get this kind of stuff done.
It's seriously not that hard at all. Just take your time, plan for three to four hours. Stay organized, lots of bolts come out. The valve cover bolts that go around the covers are finicky. They're like 8 lbs torque value. Be careful I snapped one. I was using a milwaukee M12 3/8 ratchet, accidentally squeezed the trigger past the lowest setting and boom. I'd do them by hand for sure. The mercedes engine mount tool was perfect for torquing the gear bolts.
If i could go back, I'd budget more time and paint the valve covers while they're off. I'll probably do that eventually anyway.
I would do the blue, my plenum spacer is blue. I bookmarked them for later......
The timing is what scared me the most. I turned the engine to the 0 mark on the crank pulley probably three or four times until the cam gear timing marks lined up. Once it was all perfectly lined up, I was careful to not move anything anymore. The gears are a bit tricky to get in, but not impossible. Just be patient.
Old 09-02-2020, 04:21 PM #34
Iceman710 Iceman710 is offline
Iceman710 is on a distinguished road
I jumped on the latest group buy, have been eyeing them for a while but wanted to see first hand experience. Any thoughts on these cam gears and the XTP Manifold Spacer. Wonder if that would be a good combo with some positive results.
Iceman710 is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 06:04 PM #35
montijo505's Avatar
montijo505's Avatar
I installed both at the same time so kind of hard to gauge what improvements each gave. My truck drives loads better now though. Better skinny pedal feel, lower idle, even the exhaust note changed. Definitely worth the time to do it.
Old 09-13-2020, 10:14 PM #36
montijo505's Avatar
montijo505's Avatar
Finally have some mpg data to report. I always fill up until the pump stops, and calculate the mileage by writing down the mileage at fill up and mileage at half tank (10 gallons).
Here is the last few before the gears and the ones since. The first one had a bottle of Lucas injector cleaner. The last one included an easy Sunday drive on the highway to a local waterfall picnic spot loaded up with cooler, disc cooker, propane tank, two kids and wife. Not bad for the price of the gears!
Old 09-13-2020, 10:25 PM #37
y=mx+b's Avatar
y=mx+b y=mx+b is online now
y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold
y=mx+b's Avatar
Dang, thats a solid 2mpg upgrade! Would be interesting to see how much improvement there would be on a stock 4runner, which makes me tempted to hop on the buy. Where I am right now, speeds are all over the place 25-65mph, so I've gotten as low as 14mpg on a completely stock 4runner.
y=mx+b is online now   Reply With QuoteReply With Quote
Old 09-13-2020, 11:03 PM #38
montijo505's Avatar
montijo505's Avatar
Before my Falkens/Ray 10's I had heavier wheels and Nitro Trail Grapplers (MT's). I had no plate bumper, skids, sliders or hitch carrier with full size spare and she was doing in the 13's around town, it was atrocious lol
Old 09-13-2020, 11:24 PM #39
Heck yeah, thats awesome! Did you also do your spark plugs too or anything else with the gears at the time?
My should arrive tomorrow. It sure when Ill get around to it. Still have to get everything else that goes with it.
Old 09-14-2020, 01:58 AM #40
montijo505's Avatar
montijo505's Avatar
I did install a manifold spacer at the same time and new spark plugs and PCV valve.
Old 09-14-2020, 11:29 AM #41
084RUNNAH's Avatar
084RUNNAH 084RUNNAH is offline
084RUNNAH is on a distinguished road
084RUNNAH's Avatar
I installed mine last weekend. Have not gone thru a full tank yet so it'll be a while. I just did the gear install and nothing else since I did the spark plugs earlier this year.
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
084RUNNAH is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 12:47 PM #42
montijo505's Avatar
montijo505's Avatar
Maybe yours will be a fairer account of just the gear install. Mine is hard to gauge exactly because of the spacer. But it drives so much better!
Old 09-23-2020, 06:51 AM #43
@montijo505 can you post a link to the spacer you used? I might as well get one as well and just do it once. Also did the spacer come with a gasket as well or should I order the plenum gasket in addition?
Can you also post a link to the Mercedes engine tool you talked about as well?
I don’t recall seeing that info but wouldn’t surprise me if I overlooked it.
Old 09-23-2020, 11:50 AM #44
montijo505's Avatar
montijo505's Avatar
Here's both, the spacer comes with just a paper gasket that goes between the spacer and plenum. You either reuse your existing plenum gasket or buy a new one, I opted for a new one.
Toyota Gen2 Products | eXtreme Truck Performance – XTP IMS intake manifold spacers for Nissan, & Toyota with 4.0 engines for performance gain! Made in USA!
Mercedes Benz Offset Engine Mount Wrench 17mm | eBay
Old 09-23-2020, 12:16 PM #45
Sunn4Runner's Avatar
Sunn4Runner Sunn4Runner is offline
Sunn4Runner is on a distinguished road
Hey guys, are there any future plans for another group buy?
Sunn4Runner is offline   Reply With QuoteReply With Quote
@momo.75 , advance , breaks , rules , set
Dana SVL vs. Revolution Gears vs. Nitro Gears VernySanders 3rd gen T4Rs 0 02-10-2020 08:03 PM
Big Sexy just went full retard on the highway!! Code P0021 proz07 4th Gen T4Rs 11 09-08-2016 10:47 AM
Help me decide between Sonoransteel 1.2 or 7.2 lift, 33 vs 35's, gears or no gears??? 240m3srt 3rd gen T4Rs 19 11-14-2014 03:33 AM
My gears/ new gears and a locker porkchop401 Classic T4Rs 16 08-25-2011 07:56 PM
Do you think Bush is a retard? 934runner Off Topic 2 04-07-2005 04:24 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
