Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 08-30-2020, 07:03 PM #31
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by BagiMT View Post
Got this done over the weekend. Was not as bad as most make it out to be. Took me 3 hours for the first side, and 2 hours for the second, beginning to end including removing and installing the CV axle. About 1 hour for the reboot part. I think the most frustrating part was removing the dust cap! To get the CV out I used a large screw driver and a 4lb hammer. With the screw driver in on of the groves it took only a couple of hits with the hammer to get the CV out. Requires removing the skid plate, but well worth it.
The 5th gen boot kit (04427-60131) is a perfect fit. The inner boot is the same material as the outer boot and has more fins compared to the 4th gen boot. Hopefully it will be more durable. The grease capacity is a bit larger, that's why there is an additional small tube of grease. Given that both kits are the same cost this seems like a nice free upgrade. I did get the worm drive clamps from Amazon (or eBay) since they are easier to install and allow for adjusting the inner boot on the truck (boot stretch). Snap ring pliers are definitely a good recommendation, make removing and installing the snap ring really easy.
Dude, those look fantastic! I really appreciate the pics too, those are a great addition. I've already linked it on the first page and made the recommendation to go the 5th gen kit!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 08:26 PM #32
BagiMT's Avatar
BagiMT BagiMT is offline
BagiMT will become famous soon enough
BagiMT's Avatar
Yes, I like them. Thanks for your write-up, that helped a ton.
Sent from my HTC 10 using Tapatalk
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
BagiMT is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 08:36 PM #33
y=mx+b's Avatar
y=mx+b's Avatar
No problem, glad it helped you out!
Old 01-28-2021, 01:54 PM #34
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
I was wondering, since the 5th gen boot has more fins wouldn't that make them rub against each other more that the 4th gen? I have a torn boot because of the rub. I already ordered the 5th gen boots though lol.
I just wanted to know how yours are holding up.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 05:39 PM #35
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Great write up, thank you!
How tight did you tighten the clamps? I know it's hard to say exactly but I used a 1/4" drive ratchet/socket but didn't want to go too tight. Got a little leakage and used a screwdriver until I couldn't turn anymore. No leakage since. I also wrapped electrical tape around the clamp seat on the boot to protect the boot.
Does that seem good or should I tighten more with the socket?
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
702tripgen is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 06:23 PM #36
y=mx+b's Avatar
y=mx+b's Avatar
Thanks dude, glad it was helpful!!
I did mine with a screwdriver first and noticed it was leaking a tad bit after probably 300 miles of driving
I then followed up with my mini impact like this one below and cranked on it pretty good. I think it can only do like 65ft-lbs max on a fresh battery in ideal conditions, so it probably wasn't close to that. Its really intended for woodworking stuff but good for small automotive tasks. I'd say if after a few miles of test driving you don't notice any extra leaking out, then its good to go! Good call on the electrical tape, extra protection can't hurt!
Old 01-28-2021, 06:29 PM #37
y=mx+b's Avatar
y=mx+b's Avatar
Hopefully @BagiMT will chime it, but I think the main benefit is the 5th gen inner boot is the plastic material like the outer. So when/if it does rub on itself, it doesn't chew through the more robust material. Also I think the more pointed shape of the 5th gen boot fins helps them to compress better than the thick and rounded off ribs on the 4th gen. This is just speculation though, since I haven't run the 5th gen kit myself. I have a spare CV I want to reboot with the 5th gen kit, so definitely let us know how it goes!
Old 01-29-2021, 02:08 AM #38
BagiMT's Avatar
BagiMT's Avatar
Yes, the 5th gen inner boot is more like the outer boot. Same material, thinner finn's than the 4th gen boot. I stretched mine a bit and have not noticed any rubbing (3" lift). Might be interesting to look in the 5th gen section to see if people still have torn boots. I just assumed Toyota changed the design for a reason and went with it. Time will tell how it holds up, so far so good.
Old 01-29-2021, 11:25 AM #39
phatcheeks's Avatar
phatcheeks's Avatar
Thanks thats good to know. Il be doing mine soon. Its has a small tear for a while now, hopefully i haven't ruined the actual joint.
Old 02-27-2021, 08:57 PM #40
phatcheeks's Avatar
phatcheeks's Avatar
So I finally did it. Just on the passenger side. Now I want to do the driver side to be even lol. But its fine for now. The whole process took me some time since I was taking breaks and going slow. Im sure the next time will be much faster.
I had to do the knuckle seal too because for some reason it was torn and the little circle spring came out with the axle.
5th gen boots.
Old 02-28-2021, 05:22 PM #41
y=mx+b's Avatar
y=mx+b's Avatar
5th gen boots.
Nice work dude, looks good! Appreciate the pics too, those will really help for people to compare the 4th and 5th gen inner boots!
Old 01-09-2022, 09:37 PM #42
rayoo rayoo is offline
rayoo is on a distinguished road
Tackled this and the CV replacement this weekend. (Thanks for the detailed writeups y=mx+b )
Couple of questions:
1. I swapped out the inner/diff side boots (kept the outer/knuckle side boots as is). I 200% need to stretch, correct?
2. I did the reboots with the factory setting where there's a small "notch". Is the consensus to pull the boot past that? Any potential leaking problems with that?
IMG_20220109_165706.jpg - Google Drive
IMG_20220109_165657.jpg - Google Drive
rayoo is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 12:02 AM #43
y=mx+b's Avatar
y=mx+b's Avatar
Thanks for the kind words!
As far as boot stretching, looks like you're running those longer red boots. Since they're rubbing, I'd probably recommend stretching them. For the one I stretched, I pulled the boot (actually pushed it with my hand inside the boot) past the factory slot and used one of the worm drive CV clamps to clamp it good on the axle. They're similar to regular hose clamps, but their edges are rolled to prevent cutting of the boot. I had one little issue with it not sealing in the beginning, but that was because I only tightened it with a screwdriver. I went back and tightened it further with a 12v impact and it hasn't leaked since.
Old 01-10-2022, 08:48 PM #44
Got it boot stretch done without a hitch, thanks for the tips!
Old 01-10-2022, 09:29 PM #45
y=mx+b's Avatar
y=mx+b's Avatar
Excellent!
boot , clamp , clamps , joint , step
Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures) y=mx+b Maintenance/Detailing 62 02-16-2024 08:44 PM
Napa Maxdrive CV inner boot stretch? Drift Monkey 4th Gen T4Rs 3 05-21-2022 06:51 AM
Used OEM CV AXLE "to reboot or not to reboot?" that is the question mrwinkle13 4th Gen T4Rs 4 10-28-2018 11:52 AM
How far can you stretch $100 Toymaker General Discussions 9 05-24-2015 01:00 AM
New CV Axle Boot Stretch krmccour 3rd gen T4Rs 3 12-20-2012 05:09 PM
