Old 08-26-2024, 09:30 AM #16
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough
ArthurKotb's Avatar
Real Name: Rich
Originally Posted by dasx86 View Post
After a cold start, alternator will read ~14.3v for a few minutes, after which it will drop to ~13.6v.
It is normal for these trucks to read ~13.6v most of the time. That is NOT a sufficient voltage to keep an AGM battery happy. While I'm now aware of the GM diode, and the Texas Slim mod..... I had idea no idea about the special considerations of an AGM battery at the time, nor it's (in)appropriate applications for a 4Runner/Tacoma
My issue was so bad that the car would intermittently lose power for a brief moment in motion, throwing code P0607 - control module failure. My theory is that the AGM battery has the ability to soak up a lot of power quickly, and it was intermittently (very briefly) starving the ECU of the necessary voltage to run. Switched back to a lead acid battery and no problems since.
I meant to write up a thread about my experience, but it's been a few months and the above is the best detail I can remember. Tossing the info in this thread, maybe it'll inform someone
Cars run off the alternator, not the battery. The battery is to provide starting power and power when the engine isn't running. Cars haven't run off of the battery since generators. Way back in 1969 I started my car and then disconnected the battery. It ran fine. (Don't do this today. The battery needs to be in the circuit to prevent damage to other electrical components.)
An AGM's advantage is that it can be placed in any position, even upside down, and never needs to have water added. Other than that, it's just another wet cell battery. I use 2 in my travel trailer, which has a power supply to properly charge them. At 100% on a normal day the voltmeter reads 12.7. A regular charger will get them close to full, enough so that I wouldn't worry about missing .1V. I have used a regular charger on my 4 (2 in the trailer and 2 backup in the garage) and they top off at 12.7.
The AGMs I have used or seen are deep cycle, not starting batteries. There may be AGM starting batteries but I don't see the advantage to them. A normal wet cell, maintenance free or regular, is more than sufficient if you properly maintain it.
Battery voltage is affected by temperature, another thing to consider.
Alternator Voltage Question-state-charge-chart-temp-s-jpg
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 08-28-2024, 11:00 PM #17
dasx86 dasx86 is offline
dasx86 is on a distinguished road
No disagreements from me. I went back and edited my post to better explain my story. My AGM starter battery, with lack of any diode mod, caused me terrible intermittent electrical issues. Issues that I couldn't find anyone else on the internet referencing. This seemed like a decent thread to drop the info into. Maybe someone will find it useful in the future.
2005 Limited V8 4x4
dasx86 is offline   Reply With QuoteReply With Quote
Old 08-29-2024, 09:58 AM #18
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
That's really strange. I don't know why an AGM battery would cause intermittent electrical issues. It's really just a regular lead-acid battery but instead of liquid electrolyte it's wrapped in a fiberglass mat and the case is sealed. There's no electronics involved like there is with LiFePo4 batteries. Maybe there's a bad / broken internal connection somewhere? I've seen all kinds of strange electrical issues and the best way to resolve them is to swap parts with known good parts, like you did.
Regardless of what the voltage shows on a battery, the best test is a load test. Harbor Freight sells a very simple battery load tester. I have found it to be invaluable in determining the actual strength of a battery. If you still have the AGM you might want to try that, unless they did that at the auto parts store. Still, a good tester to add to your workbench.
Access to this page has been denied
Rich
Kentucky
Old 08-29-2024, 11:38 AM #19
I did have the battery tested at an Autozone, and the CCA it was putting out was 15-20% under the battery's rating. Which (I assume) tracks linearly with it being 15-20% undercharged, on account of the alternator's voltage output being too low, with my lack of diode mod.
I can only speculate that there was some transient voltage/amperage dip happening that caused the ECU to not be fed enough power, only for the briefest moment. I assume with a diode mod, and >14v in the system while running, I would not have had the issue
Anyhow I plan to use a DC to DC charger and turn that 24f AGM battery into a leisure battery for camping, etc.
2005 Limited V8 4x4
Old 10-09-2024, 12:55 AM #20
missionman missionman is offline
Real Name: Jake
missionman is on a distinguished road
Real Name: Jake
Anyone here use a voltage booster pro Texas slim? It adds either 0.4v-0.5v on low setting or 0.8v-1.0v to your alternator charge. I got 2 Weize AGM batteries wired in parallel (dual purpose type for starting and rv).
My 2003 4runner v6 charges at 14.1v to 14.9v At idle (voltage climbs higher for a while then falls to max idle, usually around 13.2 volts).
If you're concern is idle charge on a AGM like many truckers or 4x4 off road campers like me you want that AGM charging with that 14.1 volt minimum.
Instead of buying a custom alternator, keep your 130amp alternator and buy a simple Texas slim pro. Pull your 7.5amp mini fuse for your alternator and replace it with this thing. See photo. I'll solve your issue on LOW setting making your idle 14.1 instead of that weak 13.1 volts that ruins it. The good news is even when your drive it doesn't send the charge into the danger zone. The high setting would mess your AGM up charging it at 15-16 volts depending on your alt charge in motion.
I bought one just as a backup. It solves having to lug around a AGM charger. Its not unsafe and is dependable. I bought 2 (1 to use 1 for a backup)
Alternator Voltage Question-img_20241008_223438-jpg
missionman is offline   Reply With QuoteReply With Quote
@idle , alternator , battery , lights , voltage
Alternator Voltage Question derekl123 4th Gen T4Rs 12 07-09-2020 01:46 PM
Battery/Alternator issue. Voltage is OK greif07 3rd gen T4Rs 98 10-05-2019 04:04 PM
Bad voltage regulator on new alternator? KCscout 4th Gen T4Rs 9 06-23-2019 08:14 PM
Anyone Replace Voltage Regulator in Alternator? Bandit Runner 3rd gen T4Rs 11 12-09-2017 02:04 PM
Voltage Regulator on the Alternator Question snowbrdr033 4th Gen T4Rs 3 10-24-2011 08:38 AM
