Old 07-19-2020, 06:59 PM #1
Texas_4Runner Texas_4Runner is offline
Texas_4Runner is on a distinguished road
Alternator Voltage Question
I had to jumpstart my 4Runner so I drove it to O’Reilly’s and they said my battery was good and the voltage regulator failed.
I drove home, charged my battery to full, cleaned the terminals that were filthy. This morning it struggled to start but I was able to get back to O’Reilly’s. A different person told me the battery was bad. It’s over 3 years old so I put in a new one.
Then they tested the alternator again and said the voltage regulator still failed. I went home and used a multimeter and got the following numbers.
With 4Runner off 12.78V
@idle No lights 13.46V
@2000 rpm no lights 13.55V
@idle with lights 13.42V
@idle with headlights, radio, and AC on high 13.36V
I’m supposed to drive to MT tomorrow and I don’t really want to put in a cheap remanned Ultima alternator from O’Reilly’s. Based on those numbers the alternator seems to be working. And I don’t hear a whine.
What are your thoughts? Should it be closer to 14V?
2008 V8 LTD
Texas_4Runner is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 07:46 PM #2
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Those numbers sound good to me. 13.5 - 13.25 is perfect.
If alternator was bad, cranking the car and using voltage it would go down not up.
Your alternator holds close to 13.5, which is what a voltage regulator is supposed to due.
Battery (car off) could be higher though, over 13, just my 2 cents. If it is brand new it probably needs to charge more.
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 08:29 AM #3
djkurious djkurious is offline
djkurious is on a distinguished road
Those numbers look normal to me also.
2003 4Runner SR5 V8
319k and counting...
djkurious is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 11:27 AM #4
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Get a GM diode to replace the 7.5A Alt-S fuse. You'll gain about 1 volt. Cold start up I see anywhere around 14.8 then settles to about 14.2 - 14.4.
I've done this to my 07 & 19.
Sent from my moto g power using Tapatalk
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 01:37 AM #5
The diode idea is interesting. Any idea why you get an extra volt?
2008 V8 LTD
Old 07-21-2020, 07:10 AM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Is the new battery an AGM? Was the old battery an AGM? They require higher voltage to fully charge, but it shouldn't be an issue in a brand new battery. It becomes an issue after several months of not getting a full charge. A standard "Wet Cell" battery should be charging fine with 13.5v to 14.0v.
The GM diode is an alternative but takes a fuse out of the equation and in an extremely unlikely circumstance it could start a fire. There are fused options, but you have probably already left for your trip, so it won't do you much good now.
Sounds like you might have a parasitic draw or your starter might be having trouble, judging by your volt readings. You could have dirty connections at the starter. A battery voltage of 12.78 at rest for 6 hours or more should be plenty of juice to start your truck. Your lower voltage readings with all accessories on look to be in an acceptable range, but under load while moving they could be dropping lower. I have an Ultima in my 5th gen and it's been doing pretty good, but your right, you never know with remans.
Here is a video I did involving the "Dirty Parts Voltage Booster". It does the same thing the GM diode does, but has a fuse inline for circuit protection. If you have a wet cell battery, the booster might over charge it and cause problems that way. There are a few variables involved with this so more research might be needed. A quality lithium jump booster is a good thing to have as well. Hope it's something simple and your trip goes well with no troubles. Good Luck!
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 09:36 AM #7
mystereons41 mystereons41 is offline
mystereons41 is on a distinguished road
Last time I checked mine it was 12.2V with car off and 14V with car running. But that was March and it was cold. I’m pretty sure the battery voltage will read higher when cold
mystereons41 is offline   Reply With QuoteReply With Quote
Old 08-10-2023, 06:47 PM #8
twa318 twa318 is offline
twa318 is on a distinguished road
Does running the GM fuse stress the alternator?
I read on another post the OEM alternators are specced to accept the higher voltage, however my alternator died within 6k miles of installing the GM fuse to properly charge my AGM battery.
Perhaps a stupid question as I was still running the 16 year original alternator @ 242k miles but it does make me wonder if it hastened the failure.
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 08-10-2023, 07:05 PM #9
Buckaroo's Avatar
Buckaroo Buckaroo is online now
Buckaroo will become famous soon enough
Buckaroo's Avatar
Spec from FSM is 13.2 - 14.0V charging output so seems like you are ok there. Check AC ripple.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is online now   Reply With QuoteReply With Quote
Old 08-15-2023, 05:20 PM #10
Mike07SE's Avatar
Mike07SE's Avatar
I've been running this setup for quite a while now. I had swapped out to an AGM battery on both my trucks and they both ran and charged great. I still have the '19 and no issues to date and my wife drives it daily. The '07 I ironically had the alternator give out on me last year with about ~250K miles on it as well, and to be honest at that age and mileage I wasn't mad nor would've blamed the diode for that. Just wear & tear at that point. I can see with a voltage gauge that the voltage regulator charges these high at startup, and as the battery recharges, it settles to a 14.1-14.4 range. Right where the AGM needs to be.
@idle , alternator , battery , lights , voltage
Alternator Voltage Question derekl123 4th Gen T4Rs 12 07-09-2020 01:46 PM
Battery/Alternator issue. Voltage is OK greif07 3rd gen T4Rs 98 10-05-2019 04:04 PM
Bad voltage regulator on new alternator? KCscout 4th Gen T4Rs 9 06-23-2019 08:14 PM
Anyone Replace Voltage Regulator in Alternator? Bandit Runner 3rd gen T4Rs 11 12-09-2017 02:04 PM
Voltage Regulator on the Alternator Question snowbrdr033 4th Gen T4Rs 3 10-24-2011 08:38 AM
