Old 06-13-2021, 04:35 AM #16
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Limited center console replacement with new buttons/switches
April 2020
Got my Limited center console in with spots for 5 switches now instead of the stock 3. Just replaced all my back lighted switches with orange, which were recently blue (OCD won’t let me keep em blue lol). I wound up just cutting the blue LED’s out of the USB charger since 1-They were blue and 2-I did the full time 12V mod and tied this into the cigarette lighter so it has full time power. Didn’t want any unnecessary power draw.
That gives me enough switches for now. If I need 1 more I can put my USB charging port inside my center console cubby. Problem is my dog would always step on my DAC button and engage it, no biggie though. But don’t want him to step on the rear light button and blind someone behind me. Last step will be to add 1 more switch on the dash somewhere and make it an “ARM” switch to only send power to the light switches once they’re armed
Was able to add 2 to the dash as well
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 04:55 AM #17
Map light, and 12V+ Constant mod
May 2020
*Today I did a few things to my Runner
-Did the map light mod. It is such a dumb design to not have the Map light not turn on when the door is opened. Should have come like that with an on/off/auto switch like a normal vehicle.
Toyota 4Runner Maplight Mod
-I added a basic on/off interrupter switch to turn them off as needed.
-Did the 12V+ constant power for the auxiliary plugs (cigarette lighter) Sure is nice to have constant power and not have to worry about having the key in the ignition.
Toyota 4Runner Constant Full Time 12V Power Outlet Mod
Old 06-13-2021, 06:10 AM #18
Full Monty window tint
August 2020
Just got my windows tinted today, been meaning to for months and had to schedule almost a month out.
He called it “The Full Monty” window tint lol. Did all windows including the windshield with Sun Tex Carbon film.
-55% on the windshield
-30% on the fronts
-18% on the rears including back roll down
Old 06-19-2021, 02:10 PM #19
LED Interior upgrades
September 2020
Here’s the initial kit I started with. I bought it from EBay. Included 2-map lights, 2 for middle and rear cargo lights, all 4 doors, 2 license plate bulbs, and 2 others, think it said for trunk which I didn’t have or not sure where, but are the same as the overhead cargo lights, so worst case I figured I had spares.
12x White LED lights interior package kit for 2003-2014 Toyota 4Runner T41W | eBay
They seem fine and adequate, map lights are very bright. between the addition of the LED map lights and the map light mod makes it very bright when you open the doors, I love it.
I like a lot of light so I did upgrade the 2 overhead lights (rear seat overhead and cargo area overhead) with these and gave me maybe 20% more light
DE3022 CAN Bus LED Bulb - 18 SMD LED Festoon - 31mm - 90 Lumens | Super Bright LEDs
I did have to purchase my vanity lights and glove box light separate to complete my full interior LED swap and used these from super bright led
6612F Vehicle Vanity LED Light Bulb - (1) SMD LED Fuse Lamp - 3022 Base - 30mm | Super Bright LEDs
The factory glove box light is worthless, I didn’t even know I had one much less that it worked. You had to look at the bulb to see if it was on. Makes a big difference
https://www.superbrightleds.com/more...-car/228/1067/
It’s kind of tricky to get out. I have a “custom tool” (needle nose pliers with electrical tape wrapped on tips) for the removal and reinstall luckily lol.
They’re all 6,500K which is a cool white, not a purple color. With this full LED interior swap, footwell lighting & under seat alumination addition the interior is very bright!
Old 06-19-2021, 03:20 PM #20
ran ran is offline
ran is on a distinguished road
ran ran is offline
Great price on the vanity light. the first one I looked at, it wasn't worth it.
____________________
2007 SE V6 Titanium
ran is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 05:11 PM #21
2007 SE V6 Titanium
I agree. Superbrightleds have great prices for their LED’s. Just be careful, you’ll burn the crap out of your fingers when you pull out the old halogen vanity light bulb, don’t ask me how I know Didn’t even think about that little bulb getting so dang hot, so fast since it's the size of a small fuse haha.
Old 06-20-2021, 11:39 PM #22
Exhaust cam Timing gears with 3* Retard
September 2020
Group buy for the cam gears with a lot of good information and how to.
Cam gears for V6. Add power AND mpg | Tacoma World
Bought all new seals just in case and went with the toyota FIPG. My seals would have been fine but rather be safe than sorry. Only thing I didn’t wind up using was the throttle body seal since I didn’t take it apart. Replaced the PCV valve as well, my original seemed like it functioned properly though.
Insides looked good to me, but I’m pretty far from a mechanic so don’t take my word for it haha.
The front bolt for the exhaust cam gear was a BEAR to get off as others have stated. I used another wrench looped over the jaw for leverage and the way they were flexing, I thought for sure one was going to break.
Replaced the spark plugs too while I was at it and gapped them proper. Just used the Denso Copper ones. ALMOST every time I change plugs, I have to buy a new gapper lol. I’m sure I have a half dozen or more if I could round them all up at once.
Seems to have made a difference adding a little pep. Added maybe 1+MPG or so on average but my driving isn’t the most consistent.
Old 06-21-2021, 12:02 AM #23
Pedal Commander PC38
September 2020
Bought and installed a PC38 pedal commander. Have been torn between the Sprint Booster and the Pedal Commander. I bought a Pedal Commander for my 2019 Subaru (now have a 2021) and made a big difference so I stuck with what I know.
They offer coupon codes quite frequently, up to $40 that I’ve seen on holidays. If you add one to your cart and add your email, they’ll usually send you coupon codes as well. That’s where the $40 off came from.
I just tucked it in between my seat and console.
They have a really nice ap that is Bluetooth. This way you can make adjustments of the go and not have to worry about digging the controller out from the seat.
It makes a big difference, the 4Runner drive by wire is super delayed. You realize just how much once you replace it. Have to be careful of how sensitive you make it because it will get you in reverse. Gets a little jumpy
Old 06-21-2021, 12:22 AM #24
EimKeith Panhard bar correction extension
January 2021
Had this for probably at least 6 mos. Finally found a buddy that had a 220v welder.
Didn’t get any before pics but definitely very close to level now for the pan hard bar. Had a pretty bad angle previously. 4Runner handles better on bumps, and bounces more vertical at higher speeds instead of wagging like it did. Feels more stable in higher speed turns as well.
I need to get under there with a wire wheel and clean the whole underside up and then paint.
Old 06-21-2021, 01:33 AM #25
Heated seat pads added
January 2021
-I used these from Clazzio, since I have their leather seat covers.
Clazzio Leather Seat Covers - Heated Seats Page
-Here is the link I initially followed to tie into a 25A fuse in the engine bay.
non-OEM Seat Heater with Factory Fuse - How To
-I wound up using the green wire in the driver kick panel that ties into the 25A fuse into the engine compartment labeled as seat heaters. Green wire ends at the IC4 and goes no further.
-Did the Relay swap from the Tow to the IG to give it power. Bought a couple relays to fill the tow spot. Found a pair pretty cheap on eBay, I’ll have an extra when I need it…… IF I can find it at the time lol.
-Here’s my fuse box after I filled the missing IG relay
-Pulled the seats out and the Clazzio seat covers back to insert the heating pads.
-Drilled out the back side of the center console to add switches. I put them towards both edges which turned out to have clearance issues with the main console support underneath. Had to get after if with my cordless Dremel.
-Ran the wires and mounted the Relay for the kit under each seat.
-Definitely makes a huge difference as the leather Clazzio covers sure are cold in the morning in the winter! Went ahead and drilled a spot for my future “armed” power button for my push LED buttons in center console for when the dogs step on them and we’re not aware.
Old 06-21-2021, 10:08 AM #26
awhitney1 awhitney1 is online now
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
Great updates! Thank you!
awhitney1 is online now   Reply With QuoteReply With Quote
Old 06-22-2021, 10:10 PM #27
Thank you!
Old 06-22-2021, 10:45 PM #28
thight's Avatar
thight thight is offline
thight is on a distinguished road
thight's Avatar
Great build thread! Love what you've done with the rig so far and thank you for including all the links to everything you've done. Super helpful!
thight is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 10:58 PM #29
Speedohealer and new gauge cluster lens installed
January 2021
*Speedohealer installed and calibrated
-Followed the install link thread by @BlackWorksInc for the install.
SpeedoHealer v4 in 4th Gen
-Bought the universal V4 kit as described in link. Found mine on EBay for a great price
-Didn’t bother with many pics. Here’s with it all apart.
-Here’s with it all wired in
-Speed is right on now, it was about 3-1/2 MPH off before. Not a biggie but nice to have it accurate as well as my Odometer and can get an accurate mpg rating. I had a couple MPH aps I used to double check speed.
-Replaced my scratched old original lens cover for my instrument cluster. Figured I might as well do it at the same time since I’d have it out anyways.
-How the new clear cluster gauge lens looks when brand new
Stoked about both. Not sure which I’m more excited about. Very nice to have such a transparent gauge cluster now. I’m trying hard not to scratch it and brush it off first before I wipe it off to help avoid all the swirly scratch marks that were on the old one. Toyota part#83852-35E50
Old 06-23-2021, 02:33 AM #30
Airlift 1000 airbag install
January 2021
-Airlift 1000 air bag kit install
-Finally bought a tire deflator and a big tire plug kit for my soft side case as well. Here’s the air bags I bought.
Amazon.com: AIR LIFT 60728 1000 Series Rear Air Spring Kit: Automotive
-It says not compatible with my 4Runner, because it’s an 8-1/2” bag and not a
6-1/2”. I went 2” longer due to my 2” rear lift.
-Used the bottle jack method on top of the axle to get the extra separation to get the spring out/in easier.
-Cut the bump stop in the last groove. It cuts pretty easy but you have to push it away from the knife to prevent pinching. I read where a lot of people had a hard time cutting it.
-Drilled out the base to route the airlines through. Deburred sharp edges when finished.
-Had a hell of a time getting the air bags into the springs. Took a lot of lube, prying and “influencing”! Spent a couple hours getting them in and a lot of hitting with 5lb sledge.
-Getting the springs back in and the airlines ran
I put the Scrhader valves underneath on the outside of my aftermarket HD tow bar to keep them out of sight. I used a Pneumadyne air valve switch to run them together or separate with the flip of a switch. I keep them running common all the time unless I need to load up with weight and need more stability. It makes it nice when airing up or checking psi. You can flip it to shared and you only have to use one valve, then flip back to single as needed.
I used JA’s method here from this link and got the idea about the air switch. Plus it has good information for the install as well.
https://www.top4runners.com/ja/2007/airlift.html
installed , i’m , purposes , start , stock
Silver Supra's build thread Silver Supra 3rd gen T4Rs 134 07-06-2020 07:21 PM
Yeah...it's another millennium silver 3rd gen build jmferg 3rd gen T4Rs 83 08-17-2019 12:27 PM
Tex's 2015 silver trail build yotantexas 5th gen T4Rs 3 04-15-2018 06:13 PM
Silver Fox Build From Scratch MNTNRNNR 4th Gen T4Rs 5 07-28-2015 12:39 PM
Silver 3rd Gen in Florida - Build Thread antighboatye 3rd gen T4Rs 10 10-13-2012 08:17 PM
