Old 07-20-2020, 04:54 PM #1
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Does a failing CV sound like failing bearing?
2005 v6 4x4.
I have a hummm. Same hmmmm on accel and decel but not left and right.
I have replaced the front right bearing twice in 2 days thinking I messed up the first bearing replacement.
I replaced the right rear today because the noise goes away when you veer right. The left was replaced when I bought the car with a similar symptom 2 years ago but opposite.
The differential is 100% new as of 1 month ago.
Sure the car has 190k on it so I don't feel too bad replacing parts that need it, but dang.
Can it be the front right CV? Or somehow the differential unweighting and making less noise as the right rear would be the primary drive wheel?
Thanks!
gaber6 is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 04:56 PM #2
I still have the first front wheel bearing I installed and might just update the front left on to narrow it down even farther, and would give me 4 new corners, but the direction of my steering didn't imply it would be the left.
Old 07-20-2020, 06:30 PM #3
montijo505's Avatar
montijo505's Avatar
If you steer right and the noise goes away, it's the left.
Sent from my SM-G986U using Tapatalk
Old 07-20-2020, 07:16 PM #4
Yeah, that's what's happening. So more weight on the bearing quiets it down or changes the geometry enough to quiet it. I'll stick my spare hub in there tomorrow morning. I'm down to 1.5 hours in and out now. Lol
Old 07-21-2020, 10:56 AM #5
[email protected] Shawnbk1@gmail.com is offline
Shawnbk1@gmail.com is on a distinguished road
wheel bearing
I have a similar hummmm. does yours sound like this as well?
VIDEO
Mine I fairly found when I go straight or turn right. If I veer to the left it will stop so I am assuming its my front right as that seems to be where the sound is the loudest as well.
Shawnbk1@gmail.com is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 01:21 PM #6
That's it. Mine isn't that bad at 70 yet. I just noticed it last week. So likely it could be the front or rear because when I swore my front left was bad when I purchased it, the dealer replaced the rear left. It is a little more of a pain due to the emergency brake springs and having to take the axle to a shop to press out the bearing.
Old 07-21-2020, 04:08 PM #7
montijo505's Avatar
montijo505's Avatar
Good time, after doing it so many times I'm not surprised. Yes when the weight shifts on to the bad bearing it quiets down. It starts off as a hum and then gets louder until you can feel it in the steering wheel/foot well.
Old 07-22-2020, 11:55 AM #8
Ok, for sure it was my left front making the noise.
Took it off this morning and it sounded like an old metal rollerskate. Now I just have to wait for NAPA to call back because they gave me the hub to bearing seal instead of the driveshaft to hub seal.
Old 07-22-2020, 02:34 PM #9
It is soooo quiet now. Wahooo
bearing , front , left , rear , replaced
Pinion Bearing Failing? richamc01 3rd gen T4Rs 9 01-25-2020 04:21 PM
LBJ Failing?? RunningForNow 3rd gen T4Rs 25 11-10-2019 08:58 PM
Any way to differentiate between failing double cardan joint or a failing rear most u Anthrax 3rd gen T4Rs 29 04-08-2019 09:49 PM
Front Diff Drivers Side Bearing Failing gstai 3rd gen T4Rs 7 10-10-2018 11:34 AM
failing in the winter corrado 4th Gen T4Rs 62 01-18-2012 12:32 PM
