Old 07-23-2020, 06:01 PM #16
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Originally Posted by Harlock View Post
Thank you! As mentioned, I did replace the bottom weatherstrip, which was stupid-easy. Installing it took less time to do than taking the part out of the plastic bag. Mine was really worn out, but replacing it did nothing to stop the water.
It seems odd that the plugs at the bottom are solid since some moisture would have to get in due to the window. My 4Runner is also an 2007 (SR5 4WD). Did Toyota make different plugs with drain holes for other years/generations? If so, I wonder if they'd fit ours.
Pics from today
Is water supposed to get into the rear hatch/tailgate?-plug-1-jpg  Is water supposed to get into the rear hatch/tailgate?-plug-2-jpg  Is water supposed to get into the rear hatch/tailgate?-drain-jpg
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 06:13 PM #17
EHNWI's Avatar
EHNWI EHNWI is offline
EHNWI is on a distinguished road
EHNWI's Avatar
Yep mine aren't like this either. They are just straight solid plugs. I too wonder why some of us have solid and some with drains.
EHNWI is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 07:54 PM #18
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I would of thought all the "plug/drains" would be the same, but apparently not...BUT I see it as a easy fix with a small drill bit....drill two small holes in the "plugs" which would make them drains!!
2004 Limited V8
Old 07-23-2020, 08:58 PM #19
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
i damaged the window seal scraping ice a few winters ago and started getting water into rear hatch. Replaced with OEM. No problems since.
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 10:33 PM #20
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
Originally Posted by CarlosV View Post
Pics from today
Thanks for the pics! Here's mine:
Which looks like it might drain around that center button area. But no.
Also, my plugs are toward the center of the door instead of near the sides as it looks like yours are. I think yours are in a better location for draining.
It also looks like your plugs fit in a square opening. Mine fit a round hole.
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Harlock is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 04:17 PM #21
MikeinNH67's Avatar
MikeinNH67's Avatar
Harlock, isn't that a square drain on the far right of your door in the 2nd to last picture? Kinda in the crease there.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-24-2020, 04:27 PM #22
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Center and one in each corner on mine for the square holes.
Have different drain plugs too, has a bit of sponge in the inside holes.
Noticed this new window seal has extra foam at the tips.
My old one was really nasty.
Was thinking a person might could put a piece of wax paper on the window/corner, then smear a bit of some kind of RTV/gasket goop to seal the corners better.
Is water supposed to get into the rear hatch/tailgate?-img_8979-jpg  Is water supposed to get into the rear hatch/tailgate?-img_8980-jpg  Is water supposed to get into the rear hatch/tailgate?-img_8974-jpg  Is water supposed to get into the rear hatch/tailgate?-img_8977-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 05:50 PM #23
The square holes ( 2) at each corner are not for the plugs (those are rounds),are 2 extra drains w/out plugs like the ones (as posted bellow your pics) , are also on one of your pics
Old 07-27-2020, 02:24 PM #24
NicoBg NicoBg is offline
NicoBg is on a distinguished road
Had same issue here, since it wasn't possible to get the spare part, i used structural silicon to seal the back glass completely and then detached the switch to prevent someone to activate it by mistake. It was not like i was winding down the back window anyhow ;)
NicoBg is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 04:25 PM #25
MikeinNH67's Avatar
MikeinNH67's Avatar
Whoa, I use that rear window all the time. One of my favorite features seeing it can be done with the fob.
Mike
03 4runner Limited
Old 07-27-2020, 07:31 PM #26
EHNWI's Avatar
EHNWI's Avatar
Any time I open it on the road, I just get my exhaust fumes rolling into my truck
Old 07-27-2020, 09:21 PM #27
Rhuwme Rhuwme is offline
Rhuwme is on a distinguished road
I just noticed (by way of hearing it) water in my tailgate late last week. I also have the same setup as Harlock, and I went ahead and pulled my solid plugs - not a ton, but plenty of water came out. I was also thinking to replaced the seal around the outside of the back window. Surprisingly, after the past few days of rain, I haven't heard any water in the tailgate... yet.
Rhuwme is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 03:28 PM #28
MikeinNH67's Avatar
MikeinNH67's Avatar
Ah, I only do that long enough for the AC to push some hot air out the back. I generally open it when the truck is off whether it be to get back there or let heat out. I probably wouldn't use it as much if my hatch latch worked properly.
Mike
03 4runner Limited
Old 07-28-2020, 07:40 PM #29
agua.fresca.viaje agua.fresca.viaje is offline
agua.fresca.viaje is on a distinguished road
Originally Posted by biv117 View Post
I had the same issue, haven't had the chance/haven't wanted to spend the money on new window rubber right now. I just removed the plugs completely and now whatever water gets in the tailgate just drains right out the bottom, which is good enough for me. I don't mind taking the plastic panel off and cleaning/blowing out any junk with compressed air a few times/year.
I would just take the plugs out completely.
+1
Had the same issue, removed the plugs out a month ago and did the trick perfectly
2005 4Runner SR5 - Chile
agua.fresca.viaje is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 05:44 PM #30
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
the weatherstripping is an easy fix, best to fix it, before water enters and damages the hatch lock mechanism.
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
clean , door , plugs , sort , water
WTB-Black 3rd Gen rear hatch/tailgate powrguy For Sale: Suspension/Wheels/Tires 0 03-01-2015 09:35 AM
3rd Gen rear hatch/tailgate for sale in CHICAGO The Black Pearl For Sale: T4R Items 6 08-05-2014 12:10 PM
96-02 rear hatch/tailgate struts 240m3srt Classifieds - buy & sell (no commercial ads please) 7 01-27-2011 09:52 AM
rear tailgate/hatch mystery problem. jackyack18 4th Gen T4Rs 3 04-01-2010 02:14 PM
