Old 07-22-2020, 01:07 PM #1
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
Is water supposed to get into the rear hatch/tailgate?
When it rains, my rear hatch is filling up with water. When I open the door after a storm, a large amount of water will pour out a small hole at the top of the door. After searching the forum, I bought and replaced the bottom window weatherstrip, which did not fix the issue. I've also read recommendations to clean the two black rubber plugs on the bottom of the door. I've pulled mine out and inspected them, but they are clean. That said, they are solid plugs without any sort of drainage holes. No water is getting into the inside of the vehicle. So I don't know if water is supposed to get inside some part of the tailgate and I have incorrect plugs, or if I have some sort of leak somewhere else that I need to fix.
Harlock is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 03:11 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Water should not be getting inside the liftgate. Sometimes water can sit along the steel near the hinges (outside weather stripping), but ideally this should run down the sides and out.
Id start with the weather stripping around the hatch glass (particularly along the bottom of the glass) on the outside and inside. This is common to dry out and fail. Check around the top brake light (if you dont have a spoiler).
Those are my thought for starting places
Old 07-22-2020, 04:16 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
I don't think there's a way to completely stop water from getting inside the liftgate which is why there are drains at the bottom. I think I pulled my plastic drains out completely plus replaced the lower horizontal weatherstrip, I don't recall ever having water stay in there since doing this.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-22-2020, 04:33 PM #4
EHNWI's Avatar
EHNWI EHNWI is offline
EHNWI is on a distinguished road
EHNWI's Avatar
If you remove the plugs completely, it might be worth putting in some sort of mesh to stop bugs or bees from getting in there and making a nest. Mine are also regular plugs without drains. I don't think I have ever had a large amount of water in there, but there has definitely been some and some moisture buildup. The yellow vapor barrier was also not sealed when I checked on it recently.
EHNWI is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 05:45 PM #5
biv117 biv117 is offline
biv117 is on a distinguished road
I had the same issue, haven't had the chance/haven't wanted to spend the money on new window rubber right now. I just removed the plugs completely and now whatever water gets in the tailgate just drains right out the bottom, which is good enough for me. I don't mind taking the plastic panel off and cleaning/blowing out any junk with compressed air a few times/year.
I would just take the plugs out completely.
biv117 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 06:03 PM #6
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Mine has had water/dust/mud in the tailgate for some time.
Most seems to run down the bottom outer corner edges of the glass.
Then out the drains if they are not plugged.
Good 2 cups of mud came out of mine.
Not really sealed very good.
Just a car wash and there is water in the tailgate.
Just got a new seal i will try.
$30.63...about a 8 day delivery, looks OEM
68290-35031 - Genuine Toyota Parts
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 07:00 PM #7
EHNWI's Avatar
EHNWI's Avatar
I ordered that one a couple weeks ago and just installed it this week. Really simple. I did the driver and passenger strip as well because they were cracked all over.
Old 07-23-2020, 12:19 AM #8
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Those rubber plugs (OEM) do have 1 o 2 little holes in each, easy to get block with dirt. I recently cleaned mines. Also 1 metal hole at the 2 bottom corners of the gate (pics posted here somewhere)
It is my understanding after reading many posts (mainly here, thanks guys) the rear gate is designed to allow some water ingress and drained at the bottom. Fresh weatherstrip will minimize amount.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 12:25 AM #9
Harlock's Avatar
Harlock's Avatar
Thank you! As mentioned, I did replace the bottom weatherstrip, which was stupid-easy. Installing it took less time to do than taking the part out of the plastic bag. Mine was really worn out, but replacing it did nothing to stop the water.
When I replaced the lower strip, I did see some wear on the upper strip at the bottom left and right corners of the window. So, based on your advice, I will go ahead and order a replacement to install.
I did not even think about the brake light! I'll check that too!
It seems odd that the plugs at the bottom are solid since some moisture would have to get in due to the window. My 4Runner is also an 2007 (SR5 4WD). Did Toyota make different plugs with drain holes for other years/generations? If so, I wonder if they'd fit ours.
Old 07-23-2020, 12:41 AM #10
Will try to take pics of my plugs tomorrow and post. Mine is 2003.
Old 07-23-2020, 08:45 AM #11
Bigcanoe's Avatar
Bigcanoe Bigcanoe is offline
Real Name: Arn
Bigcanoe is on a distinguished road
Bigcanoe's Avatar
Real Name: Arn
Anyone have a link to the proper part to order for the weatherstripping?
2008 4Runner Sport V8
Bigcanoe is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 11:58 AM #12
Harlock's Avatar
Harlock's Avatar
You need Toyota Part# 68290-35031
Old 07-23-2020, 03:03 PM #13
Malarkey Malarkey is offline
Malarkey is on a distinguished road
Had this problem too, popped the hatch after 2-3 days of heavy rain and a couple quarts of water dumped out. New weather stripping fixed it, took 10 min.
Malarkey is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 03:06 PM #14
Harlock's Avatar
Harlock's Avatar
Did you replace the upper weatherstripping? If so, was it pull-off, snap-in just like the lower piece?
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Old 07-23-2020, 04:05 PM #15
MikeinNH67's Avatar
MikeinNH67's Avatar
I got mine from Amazon, it is OEM.
Amazon.com: TOYOTA Genuine 68290-35031 Door Glass Weatherstrip Assembly: Automotive
Mike
03 4runner Limited
clean , door , plugs , sort , water
WTB-Black 3rd Gen rear hatch/tailgate powrguy For Sale: Suspension/Wheels/Tires 0 03-01-2015 09:35 AM
3rd Gen rear hatch/tailgate for sale in CHICAGO The Black Pearl For Sale: T4R Items 6 08-05-2014 12:10 PM
96-02 rear hatch/tailgate struts 240m3srt Classifieds - buy & sell (no commercial ads please) 7 01-27-2011 09:52 AM
rear tailgate/hatch mystery problem. jackyack18 4th Gen T4Rs 3 04-01-2010 02:14 PM
