Old 07-24-2020, 11:12 AM #1
Renol Renol is offline
Renol is on a distinguished road
Different sized aligned holes on front of frame
I'm beginning to hate my car. Trying to install some front recovery points but I'm finding a bolt hole that should be same size as another is 1/16" smaller. Has anyone else seen this issue?
I'm referring to on the front of the car where the radiator frame is. Towards the bottom there are two holes. One is threaded and has no outlet. The other directly above it passes through the frame and there is another hole opposite that on the inside where the radiator sits. The outer side is a 1/2"diameter hole that a bolt slides into no problem. On the other side it just won't pass through and it is basically 7/16" in diameter.
Am I the only one with this issue? At this rate I'd have to use a smaller bolt or drill out the hole.
Different sized aligned holes on front of frame-20200724_095313-jpg  Different sized aligned holes on front of frame-20200724_095410-jpg  Different sized aligned holes on front of frame-20200724_100531-jpg
Renol is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 11:24 AM #2
Derekv Derekv is offline
Derekv is on a distinguished road
2004 Sport V8. Same size holes as yours. I drilled them for recovery points.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 03:32 PM #3
So much for bolt on.
bolt , frame , front , hole , radiator
Cover holes on PRO in rear frame EmotionCRZ 5th gen T4Rs 1 03-12-2020 09:20 PM
Threaded holes on frame rails JAD 5th gen T4Rs 6 04-27-2014 03:34 PM
Holes in my frame predicament isu2014 3rd gen T4Rs 61 01-04-2014 08:30 PM
Of mufflers and rusty frame holes... farmerjon 3rd gen T4Rs 14 04-15-2013 02:30 PM
Frame drain holes. Scofco Maintenance/Detailing 2 01-11-2004 12:29 PM
