Old 01-02-2022, 08:57 PM #76
Asylvester Asylvester is offline
Asylvester is on a distinguished road
After reading your great write up (love the pictures) I went outside to check the condition of the tank straps on my 2009 4Runner. Luckily mine are fairly clean and minimal rust. I’m in NH so rust is enemy No. 1. I am going to completely DRENCH the straps with Fluid Film in hopes of never having to replace them.
Asylvester is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 04:51 PM #77
lpell7 lpell7 is offline
lpell7 is on a distinguished road
This is great thanks for posting!
lpell7 is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 04:52 PM #78
Thanks for posting this I'll definitely use this later
Old 01-13-2022, 01:35 AM #79
zameul40's Avatar
zameul40 zameul40 is offline
zameul40 is on a distinguished road
zameul40's Avatar
Would be sure to do the fuel pump while its down if you have a good amount of miles on it.
zameul40 is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 11:32 AM #80
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Replacing the straps doesn't requiring dropping the tank. If the tank had to come out, I'd think about it, but that would be a little more invasive than this project requires
y=mx+b is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 03:46 PM #81
caper caper is offline
caper is on a distinguished road
I just did this job too but , just used flat bar and bent it to same shape and welded the ends on , toyota wanted like $200 (cdn) per strap yes EACH and they were week away in US , was not paying that anyways they crazy
caper is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 03:50 PM #82
Few pics
Fuel Tank Strap Replacement Tutorial (60+ Pictures)-65a20a69-eb6c-45c5-bd5e-9e40c2a33c5a-jpg  Fuel Tank Strap Replacement Tutorial (60+ Pictures)-4c2bfbe5-f468-4493-b3d4-65257f060230-jpg  Fuel Tank Strap Replacement Tutorial (60+ Pictures)-e018d9e6-20ec-4eec-ad22-3cfaf2e69a4f-jpg  Fuel Tank Strap Replacement Tutorial (60+ Pictures)-dd4adbbf-6fe3-4b0e-93c6-ce5e72bc3d2d-jpg
Old 02-12-2022, 04:20 PM #83
Cost me like $5 in flat bar and an extra hour than if i had new straps sitting there ,
Fuel Tank Strap Replacement Tutorial (60+ Pictures)-a2d4655d-4a00-47c3-91ef-02690f3df72b-jpg  Fuel Tank Strap Replacement Tutorial (60+ Pictures)-88d8829e-4b6f-41f6-bfff-003543ea1165-jpg  Fuel Tank Strap Replacement Tutorial (60+ Pictures)-bce999c3-be16-4984-ae69-23ad2a78341a-jpg
Old 02-12-2022, 09:35 PM #84
y=mx+b's Avatar
y=mx+b's Avatar
Dude that's awesome! Great work and saving money is always great too!
Old 02-13-2022, 02:35 PM #85
maxdef maxdef is offline
maxdef will become famous soon enough
I used this guide when I was upgrading my skid to an RCI skid, and seeing how well this was put together I replaced my straps too. Mine wasn't an issue yet, with only one spot getting a little crunchy, but I'm glad I did.
I ended up breaking one of the frame bolts so now it matches the existing missing bolt head from when I bought it (1st and 3rd from front). I've considered buying a welder after seeing how y=mx+b has recovered bolts welding on a nut, but I'm not sure if the tank being right there is a concern. Maybe I just need to wrap some foil on it lol
maxdef is offline   Reply With QuoteReply With Quote
Old 02-13-2022, 04:26 PM #86
y=mx+b's Avatar
y=mx+b's Avatar
If you're welding a nut bolt near the tank, you can cover it in a leather or fiberglass fire blanket. Closet one I welded was the bolt on the rear brake line bracket right above the tank, although this one still had the head, it was just rounded off. If it is one of the tank skid bolts, it is kinda hard to weld a nut on what is left while upside down. I've found drilling the whole thing out and replacing with a flanged weld-nut is easier
Old 02-21-2022, 06:45 AM #87
onthompson's Avatar
onthompson onthompson is offline
onthompson is on a distinguished road
onthompson's Avatar
Very helpful post! May need to do this at some point soon.
onthompson is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 07:24 PM #88
I wasn't sure if doing a weld inside a nut while upside was possible- I hoped it would be at least. If drilling it out, why is a weld-nut better than just cleaning the threads and adding a new bolt?
Old 02-21-2022, 08:11 PM #89
y=mx+b's Avatar
y=mx+b's Avatar
If you don't drill it out perfectly centered, then you can eat into the threads with the drill and it won't hold the bolt as well. That's what happened to me, so my threads were messed up and it was easier to weld in a new threaded weld nut
Old 03-02-2022, 07:54 PM #90
I hadn't heard of those until now, and looking at pics they seem to have a flange. If that sits above the frame surface, won't that prove problematic for a skid to sit flush, or am I picturing this wrong?
ratchet , step , strap , straps , tank
Fuel Tank Strap Replacement. Maineiac 4th Gen T4Rs 6 04-22-2021 05:41 PM
Fuel tank strap replacement Porqupine82 4th Gen T4Rs 0 10-18-2016 09:44 PM
Replacement OEM Fuel Tank Skid Plate fdbyrne 4th Gen T4Rs 5 12-24-2015 12:45 PM
Fuel tank support strap chimpy 3rd gen T4Rs 4 06-22-2015 09:53 AM
Fuel tank replacement kendrick1961 3rd gen T4Rs 4 10-21-2014 07:14 PM
