Old 03-02-2022, 10:04 PM #91
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by maxdef View Post
I hadn't heard of those until now, and looking at pics they seem to have a flange. If that sits above the frame surface, won't that prove problematic for a skid to sit flush, or am I picturing this wrong?
Yes they have a little flange. Not really a big deal for skid or tank strap fitment. It's not something with tight tolerances like inside an engine or something
y=mx+b is offline   Reply With QuoteReply With Quote
Old 03-03-2022, 05:39 PM #92
maxdef maxdef is offline
maxdef will become famous soon enough
Good point, I'm guessing the flanges aren't all that large anyway, and I can add a washer to the 2nd bolt in between the problem spots to keep it settled.
maxdef is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 07:22 AM #93
gookies gookies is offline
gookies is on a distinguished road
Has anyone tried just knocking out the pin from the strap buckle so you don't have to attempt removing crusty bolts? Leave the old buckle attached while only changing the strap. The pin and clip that's used on the other side seems to be of a similar size and you'd be able to use it. While searching for other tutorials, ran into a Tacoma one that actually used the same set-up as on the other side (pin + clip) to secure it into the buckle instead of a crimp/press fit. Just trying to avoid any potential headaches as I've seen other individuals run into.
gookies is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 09:39 PM #94
caper caper is offline
caper is on a distinguished road
Might call me crazy but where I live if I buy a new vehicle or nearly new vehicle I put it up on my hoist and remove every bolt I can one at a time and antizeze and reinstall might take me an hour tops but saves me hours and hours of time and frustration down the road , did all the gas tank skid plate and strap bolts when it was bran new cause I knew the day would come , track bar bolts , shock bolts …. Every bolt easy pezy ya don’t even gota take em all the way out just half or 3/4 out and slap the antiseze to the treads with the little brush , goes pretty quick with a 3/8 impact
caper is offline   Reply With QuoteReply With Quote
Old 12-06-2022, 01:16 AM #95
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
What about proper torquing of these bolts?
2004 Limited V8
Old 01-02-2023, 01:00 PM #96
For anyone who ends up replacing these in the future and ends up shearing off the head of the tank strap bolts due to rust/corrosion, do not bother trying to extract it. Purchase a punch/chisel set and with a 3lb-4lb hammer and remove the welded nut instead. Then, drop in a nut with newly purchased bolts.
Old 03-27-2023, 05:15 PM #97
Originally Posted by Asylvester View Post
After reading your great write up (love the pictures) I went outside to check the condition of the tank straps on my 2009 4Runner. Luckily mine are fairly clean and minimal rust. I’m in NH so rust is enemy No. 1. I am going to completely DRENCH the straps with Fluid Film in hopes of never having to replace them.
its where ya can't see that gets ya , the bottom of the tank is where water/salt sits on top of strap under rubber cover and incubates , ya can't see it because skid plate is in way
Old 03-27-2023, 05:20 PM #98
well of course I re-torque any important bolt , ie.. track bar , control arms etc but any of the little 12mm bolts nope just finish with a wrench after impact to ensure they are snug
Old 05-11-2023, 02:39 PM #99
JohnJ JohnJ is offline
JohnJ is on a distinguished road
Well done Sir! As a technical writer for more than 40 years, I know, and appreciate, all the effort that went into this! Consumables - awesome, who does that these days!
Just this morning, I noticed the fuel tank sagging on my 2004 4Runner, it just completed it's 19th Wisconsin winter and try as I might with thorough flushings, things underneath have been causing problems the past 5 years. The first thing I did was support the tank with straps and then soaked the hardware with penetrating oil. Then, I found your tutorial and read it completely. Gotta' go now for parts but keep up the great work!
I just hope the bolts don't break!
JohnJ is offline   Reply With QuoteReply With Quote
Old 07-26-2023, 08:54 PM #100
TTucker TTucker is offline
TTucker is on a distinguished road
Terrific write up.. Thanks
TTucker is offline   Reply With QuoteReply With Quote
ratchet , step , strap , straps , tank
Fuel Tank Strap Replacement. Maineiac 4th Gen T4Rs 6 04-22-2021 05:41 PM
Fuel tank strap replacement Porqupine82 4th Gen T4Rs 0 10-18-2016 09:44 PM
Replacement OEM Fuel Tank Skid Plate fdbyrne 4th Gen T4Rs 5 12-24-2015 12:45 PM
Fuel tank support strap chimpy 3rd gen T4Rs 4 06-22-2015 09:53 AM
Fuel tank replacement kendrick1961 3rd gen T4Rs 4 10-21-2014 07:14 PM
