Old 07-26-2020, 11:08 AM #1
JBend JBend is offline
JBend will become famous soon enough
Brakes and what else?
So a few weeks ago I got some feedback from everyone about the 5th gen brake swap and have ordered the parts for it. I'm going to hold off on doing it until mid/late August (when SCS gets a restock on wheels). Since I'm hoarding parts until then(AFE filter, front and rear kicker speakers, weather tecs on order, gas tank straps, sway bar links, spidertrax's and rust prevention bits and pieces) what else should i look at replacing when doing the brakes that I can get to while I'm down there? Thanks
JBend is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 11:21 AM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
While your down there, check all front suspension bits and make sure theres no excessive play in any of the bushings, ball joints, tie rods, CV axles and boots etc.
Shameless plug for the fuel tank strap writeup I just made: Fuel Tank Strap Replacement
For rust prevention, I started out using POR15 to paint things. I found it doesn't stick well to anything that's already been painted and it is a lot of mess. I was able to peel it some of it off a a day after applying to my LCAs. Works decently on surface rust after loose crusties have been removed and clean metal has been etched. Recently I switched to using Rustoleum Rust Reformer, which I like better. I haven't had it on my test area long enough to see how it holds up, but application is much easier, less messy, and it adhered well to the surface.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 12:53 PM #3
Dylan's Avatar
Dylan Dylan is offline
Dylan is on a distinguished road
Dylan's Avatar
You could get the stainless steel-braided front brake lines. They're a good, affordable uprade to the stock brake lines. I got mine off Amazon. They are Centric brand, which as I understand is the same product as the Stoptech ones, but at a lower price.
I've had these installed for 5 years almost and had no issues. I've run them on stock suspension, as well as my current 3" lift.
Amazon.com: Centric 950.44007 Brake Line Kit: Automotive
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
Dylan is offline   Reply With QuoteReply With Quote
brakes , gas , parts , tecs , weather
Toyota Brakes Still Rolling while Brakes Applied 96bruzer 4th Gen T4Rs 7 04-01-2016 03:58 PM
Tundra Brakes vs 5th Generation 4Runner brakes. cbr400rr 4th Gen T4Rs 2 01-31-2016 02:13 AM
So I almost got raped by the Dealer today....brakes brakes brakes. DizzyV6P 5th gen T4Rs 36 04-28-2015 11:23 PM
Towing with Electric Brakes vs Hydraulic Surge Brakes PanicDog 4th Gen T4Rs 6 03-30-2010 08:16 PM
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
