Old 07-26-2020, 04:16 PM #1
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Guess the Leak, Covid Edition
Hey all, I was installing skidplates the other day and noticed some oil reside on the underside of the engine and finally got back around to tracing the leak back. Below are a few photos, but can y'all confirm this is likely a valve cover gasket leak?
It's a V6 and the leak is on the passenger side. Driver's side is dry.
For orientation, you can see the yellow oil dipstick on the left side of the shot:
And a detail shot below the valve cover, it's pooling below and has made it's way to the underside of the engine but isn't enough that I've seen any drips on the garage floor or smell of burning oil:
If it's the valve cover, I plan on re-torquing (assuming I can find the factory specs), cleaning it up and monitoring. Any other thoughts?
Thanks in advance
eleven14 is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 04:22 PM #2
montijo505's Avatar
montijo505's Avatar
The valve cover gaskets are pretty inexpensive. It's not too hard of a job if you're so inclined. Follow this write-up.
V6 Valve cover gasket replacement - Toyota 120 Platforms Forum
And buy the gaskets here
Toyota Parts | Toyota Online Parts | Genuine Toyota Parts | Toyota Parts Online
Sent from my SM-G986U using Tapatalk
Old 07-27-2020, 04:34 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
The gaskets become hard over time and can seep. Not a terrible job but it sometimes is tough getting the bolts out without breaking them plus removing a hardened seal.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-27-2020, 05:14 PM #4
Thanks for the replies and appreciate the links. Makes me feel better about it being valve cover gaskets and NOT a timing chain cover leak (which seems like a thing and is a higher level of debauchery).
I'm going to give that one bolt a 1/4 turn, clean up the area and monitor but will eventually remove and replace both sides if it persists. And hear ya, seems like all the bolts on my truck are semi-seized and literally every brittle plastic clip snaps if you look at it wrong.
Old 07-31-2020, 09:21 AM #5
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Another thing you might want to look into, check the o-ring at the top of the dipstick. I've been fooled into think my valve cover gaskets were leaking a few months after they were replaced. Turned out it was really just the o-ring letting oil by when I was off road. Just my .02, good luck!
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
cover , leak , oil , side , valve
Traveling during COVID-19 ProLee Off Topic 78 11-30-2021 10:30 AM
Help please**Oil Leak diagnosis- take a guess! Soulman 3rd gen T4Rs 20 10-19-2017 08:19 PM
Guess it's my turn.. for a leak.. giguchan 3rd gen T4Rs 3 09-18-2017 06:59 PM
